Author Topic: piston freeing cocktails?  (Read 3820 times)
Offline turboguzzi
« on: February 12, 2012, 02:17:13 PM »
Typical humidity standing for ages in the cylinder thing, no heavy rust, but piston somewhat stuck.
head is off, left it with brake fluid inside for now, but willing to hear about other piston freeing cocktail ideas....
tnxs
TG
Re: piston freeing cocktails?
« Reply #1 on: February 12, 2012, 02:24:01 PM »
Acetone & ATF, 50/50.  Not shaken or stirred, just pour!
Worked for me
Offline cookindaddy
  • I sure love this bike!
« Reply #2 on: February 12, 2012, 02:31:43 PM »
I used the grease gun method. Worked great.
http://forums.sohc4.net/index.php?topic=15059.0
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline turboguzzi
« Reply #3 on: February 12, 2012, 02:52:55 PM »
engine piston, not caliper ;)
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #4 on: February 12, 2012, 02:55:23 PM »
ATF/Acetone mix...it's proven to be the best.  The ATF is slippery, and the Acetone thins it enough to penetrate the stuck bits.
Offline 1974cb550k
« Reply #5 on: February 12, 2012, 03:29:44 PM »
Marvel Mystery Oil. Pour it in a steel coffee can and heat it with a propane torch. Pour it down into the cylinder or drop a piston in to free up stuck rings. As a disclaimer I would suggest not to pour hot MMO into a plastic funnel FYI.
Offline splitt
« Reply #6 on: February 12, 2012, 03:52:23 PM »
Worked for me
+3
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #7 on: February 12, 2012, 04:39:07 PM »
Worcestershire sauce.
MCN DTF
Offline Imago
  • 1978 CB750F
« Reply #8 on: February 12, 2012, 04:44:57 PM »
« Reply #9 on: February 12, 2012, 04:58:11 PM »
Worked for me
+3
One last thing. The acetone really thins out the ATF so it can creep in easily. Once the Acetone evaporates the ATF becomes a lubricant again.  The problem is the Acetone evaporates very quickly.
You can help it get a better result of you can cover the cylinders with Saran wrap to slow down the evaporation and allow the mixture to creep in further.
72500john
« Reply #10 on: February 12, 2012, 05:47:32 PM »
go to kanolabratories.com and order some "kroil" with a "Little heat" works wonders. my 2 cents.
Offline Danno
« Reply #11 on: February 13, 2012, 12:19:05 AM »
I use both the acetone atf mix and on real bad ones that the atf acetone does not want to work on i use gun oil made by winchester it will creep in and derust at the same time but takes up to a week and is very exspensive 14oz is about 17 dollars and it has to be applied everyday till it is unstuck usually it takes 2 or three days but I do it with the head on and the plugs out and just try the kickstarter periodically  the saran wrap idea may be good with the heads off if you are desperate enough to go get gun oil wallmart carries it
Offline Blasbo
« Reply #12 on: February 13, 2012, 04:39:47 AM »
ATF/acetone, a little heat from a propane torch, a 2 x2 and a hammer worked for me.
Offline 750K
« Reply #13 on: February 13, 2012, 04:43:22 AM »
Will have to try this, I have a stuck 78 750 motor sitting on my bench I want to free up.
« Last Edit: February 16, 2012, 08:20:09 PM by 750K »
77 Cb750, 78 Kz1000
Offline Dave K
« Reply #14 on: February 13, 2012, 05:51:07 AM »
I didn't use the acetone with the ATF, but probably should have as it would have worked faster. The piston on my XL 350 was free, but the rings were stuck. While I worked on other parts of the bike, the ATF soaked in the bore/piston for about 2mos. One day I turned it over and compression was back. It didn't take long to hook up a gas line and she was running.
Offline turboguzzi
« Reply #15 on: February 13, 2012, 05:53:58 AM »
ok, will try ATF/Acetone today.... update in a week
« Reply #16 on: February 13, 2012, 06:23:25 AM »
Boiling Deisel fuel oil, but be carefull.
Sam. ;)
Offline chewbacca5000
  • I polish covers!
« Reply #17 on: February 13, 2012, 06:32:18 AM »
After feeding her enough ATF cocktails to be agreeable try gently turning her over by hand.  Avoid kicking you will get better results.
Offline turboguzzi
« Reply #18 on: February 15, 2012, 08:36:23 AM »
OK,it's free!
tnxs for the tips
TG
Offline Randy
  • Nothing like a banging four under my legs..
    • Mission Detail
« Reply #19 on: February 15, 2012, 08:39:03 AM »
A couple of shots of Jack, before I write the check to the mechanic
1973 CB500k, 1972 CB750 (New Arrival), 1978 Vespa P200 (New Arrival)
Offline lone*X
« Reply #20 on: February 15, 2012, 11:17:20 AM »
TG, what of the suggested processes did you use?  How much force was required when it broke free?
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
« Reply #21 on: February 22, 2012, 08:39:46 AM »
OK,it's free!
tnxs for the tips
TG
So the Worcestershire sauce worked, eh?  ;) BTW, I didn't just post that to be funny. Believe it or not, I got that tip from a friend who develops American Honda's in-house training modules. He heard it from one of their techs. I've never tried it, and no - I don't believe it, either.  ::)
MCN DTF
Offline Really?
« Reply #22 on: February 22, 2012, 08:54:11 AM »
OK,it's free!
tnxs for the tips
TG
If it actually works, maybe it will be good for constipation!
The Wife's Bike - 750K5
The Kid's Bike - 750K3
« Reply #23 on: February 22, 2012, 03:51:30 PM »
It could work. The ingredients of a traditional bottle of Worcestershire sauce sold in the UK as "The Original & Genuine Lea & Perrins Worcestershire sauce" are malt vinegar (from barley), spirit vinegar, molasses, sugar, salt, anchovies, tamarind extract, onions, garlic, spice, and flavoring. The "spice, and flavouring" is believed to include cloves, soy sauce, lemons, pickles and peppers.
The molasses is known to work against rust.
« Reply #24 on: February 22, 2012, 05:15:25 PM »
At least you'll smell good if it shoots on you!
