G'day Brian,
I'm back on deck again. (Thank God!)
How's the chair going?
Feel free to drop me a line if I can help.
Brian
Great to have you back on line Brian.  The chair is moving along, although not quite as fast as I would like.  I just booked into a track day May 12th, so that's the 'get it done by' date.  It'll be the 1st chance for my passenger & myself to start getting our timing down.  I'm sure you'll hear from me after that session, as the 1st race is June 2nd.
Good looking floor man. You've got a lot of work to do huh?   Did you reach Mr. H?
I finally fired & rode mine, all is good. Had a bit of an issue with the law................so cut the ride short.
Rims / hubs / spokes went off to Brian H today.  He'll get them tomorrow.  Frame goes out to have some tabs added, and refinishing next week.  It's a lot closer than it looks right now.  Biggest holdup right now is getting a 750 big bore kit, but I think I have a solution lined up.  So the PQ police aren't supportive of your practicing, that's not very friendly.
  As I'm only a block from the Kingston's HQ, not planning any local road tests.
Any luck getting Weber parts yet?
Looks like I'll be getting all the bits I need from Pierce Manifold.  I P/U the new manifold tomorrow from the welder, and drop it off for port matching.  I'll take some photos.  Going to go with 34 chokes, 45F9 idles, 50 accels (& short rod), and 175 needles.  F11/F9/F16 tubes to choose from, airs from 170 to 180, and mains from 120 to 140.  Should be able to find a sweet spot with that to work with, and it will give me some alternatives to deal with weather changes & different tracks.  ITG is supplying (as sponsorship, thanks Andy!) a Megaflow filter, and I'll use their 13mm 'stubbies' as stacks.
