Author Topic: Need Torque Values for Brake Line Banjo Bolts  (Read 7913 times)
Offline bharvey60
  • Adolescent mind stuck in an adult body
« on: March 09, 2012, 03:29:40 AM »
Hello all...
Anyone have the correct torque value?  I understand the heads can break off easily, but I found I had to tighten them down pretty hard in order to avoid leaking.
Bill Harvey
CB750K3
85 Yamaja FJ 1100
98 BMW R1100RT
State College, PA
Hinomaru
Re: Need Torque Values for Brake Line Banjo Bolts
« Reply #1 on: March 09, 2012, 05:18:35 AM »
Is this for your 750 K3?  If so, Honda terminology calls the brake line banjo bolts: "oil bolts". The CB750 shop manual supplement lists the brake oil bolt torque spec as:
kg-m  3.0 - 4.0 /  lbs-ft 21.7 - 28.6
(not to be confused with the oil drain bolts or oil filter center bolt)
« Reply #2 on: March 09, 2012, 05:29:34 AM »
Thats helpful, i always do it the germanway - guttntight :D
BTW the unit in metric for torgue is Nm - Newton on meter lever. Does Honda use kgm?
Offline bharvey60
« Reply #3 on: March 09, 2012, 06:55:42 AM »
Thanks Hinomaru. This was for the K3 "oil bolts".
Bill Harvey
CB750K3
85 Yamaja FJ 1100
98 BMW R1100RT
State College, PA
Offline CycleRanger
  • No comment about being an
« Reply #4 on: March 09, 2012, 07:20:11 AM »
Hello all...
Always use a fresh washer/seal, they're really only made for single-use.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #5 on: March 09, 2012, 08:33:22 AM »
No, that is a misprint, the modern metric units for torque are Newton Meters.
« Reply #6 on: March 09, 2012, 12:06:41 PM »
I don't doubt that is what it says, but WOW, that's really high. That's higher than cylinder head nuts on hardened studs.
I put it in the category of "squishables". You tighten it till the washer/ORing squishes (drain plugs, spark plugs, tappet covers, oil filter bolts, brake banjo bolts) then a tad more. Run it, if it leaks, give it a tad more.
Hinomaru
« Reply #7 on: March 09, 2012, 02:59:25 PM »
MC, the torque spec is higher than I originally thought it would be also. Truth is, I have never paid any attention to the “oil bolt” torque spec until I looked it up for the OP. (good question, by the way) The info that I posted in reply #1 comes from my Honda shop manual w/supplements dated 1977. I’ve attached those images below.
Perhaps we can compare specs to be 100% sure a discrepancy does not exist, what torque does your shop manual show?
Click on images for a larger view:
« Last Edit: March 09, 2012, 03:04:55 PM by Hinomaru »
« Reply #8 on: March 10, 2012, 09:32:48 AM »
Hino: My Clymers doesn't list it. But my goto chart confirms your numbers:
http://www.salocal.com/sohc/tech/torquetable.htm
Along with the "oil bolt" all my other "squishables" are pretty high torque values. For instance i would never take the oil drain plug to 25ft/lbs!
To each their own, I'll stick to my squishable rule, not because i am "right" but because it seems right to me.
PS: Oh look at that! My goto chart is the same as the one you posted.
Tappet hole cap at 10ft/lbs! No way!
