Author Topic: Mongrel  (Read 44912 times)
Re: Mongrel
« Reply #175 on: May 20, 2024, 07:30:50 AM »
I would think that painted spokes would eventually shed the paint just from flexing during use
Re: Mongrel
« Reply #176 on: May 20, 2024, 03:04:47 PM »
I've tried it, & yes they eventually do;I polished them first,which was a mistake.
Cadmium,zinc? plating may be cost effective,although I've never personally done it at home.
I saw a YouTube on it once and it mentioned glass bead blasting them prior to soaking them in the cadmium. I watched them 'do it yourself' coating the spokes at home,but it's been a while.
I would rather get used,OEM spokes coated compared to buying cheap china spokes..
« Last Edit: May 20, 2024, 03:07:21 PM by grcamna2 »
Offline Damage Inc
Re: Mongrel
« Reply #177 on: June 09, 2024, 08:10:13 PM »
Yes, I think there is a good chance you're right. TY
There is nothing Man makes, that Man can't break.
Offline Damage Inc
Re: Mongrel
« Reply #178 on: June 09, 2024, 08:13:51 PM »
I've still got the original spokes, so I might try blasting, good metal etched primer and paint. In the end it'll be a lesson! TY
Offline Damage Inc
Re: Mongrel
« Reply #179 on: June 09, 2024, 08:17:23 PM »
Just been checking on Ebay for an after market speedo/tacho.
Is there anything I need to be mindful of, when it comes to compatibility?
Do we have a painting guru in the forum? As far as body work goes I've got to prepare and paint plastic, aluminum and steel. Was wondering if there is a process that is the same for all? ie order and types of fillers, primers and paints?? Spent hours on youtube already...
« Last Edit: June 09, 2024, 08:22:37 PM by Damage Inc »
Re: Mongrel
« Reply #180 on: June 09, 2024, 08:19:04 PM »
Do you know someone who will vapor blast them!:Bling  8)
Offline Damage Inc
Re: Mongrel
« Reply #181 on: June 09, 2024, 08:24:27 PM »
I know of sand, soda, bead and ice. Whats in vapor?
Re: Mongrel
« Reply #182 on: June 09, 2024, 10:43:22 PM »
A very fine abrasive,that imo gives a nice shiny finish.. to cast aluminum.
I've never used or owned a vapor blast cabinet before.
Take a look at member DME's XV1000 Virago project in 'Other Bikes' and look at the engine.
« Last Edit: June 09, 2024, 10:45:26 PM by grcamna2 »
Offline Damage Inc
Re: Mongrel
« Reply #183 on: June 10, 2024, 04:32:12 PM »
Ok. Thank you. I’ll take a look. I’ve only ever used sand or soda in my cabinet.
Re: Mongrel
« Reply #184 on: June 10, 2024, 09:06:48 PM »
I use steel wool or Scotchbrite, followed with Simichrome polish (to seal against future corrosion) when I have to make them pretty.
Tedious...
Offline Damage Inc
Re: Mongrel
« Reply #185 on: June 11, 2024, 01:55:36 PM »
A standard blasting cabinet is not suitable for vapor blasting. Aside from using pressurized water, it uses a variety of media. And not all services offering vapor blasting are the same and their results vary widely. Properly done, it leaves a peened finish on cast aluminum, but that will not withstand time without regular maintenance.
In your cabinet, glass bead for stripping and prepping the pieces for paint is likely best. It will strip paint and oxidation but not tear up the base material especially if you maintain an acute angle with the gun to the work piece.
Fair enough calj, mine is a home made cabinet so even less suitable. Thank you
Offline Damage Inc
Re: Mongrel
« Reply #186 on: June 11, 2024, 02:03:57 PM »
Tedious...
That would be for a nice polished finish HondaMan! I have a few motor parts polished so far. Mainly looking at a painted finish on bodywork. TY
« Last Edit: June 11, 2024, 02:07:29 PM by Damage Inc »
