Author Topic: Swapped head from 74-77 which oil jets should i use? 74 750k  (Read 1194 times)
Offline 1974cb550k
« on: March 31, 2012, 09:53:20 AM »
I put a 77k head on my 74k (750) I am using the stock cam blocks from the 74. Should i use the 77 oil jets or put the 74 oil jets in the 77 head? Im talking about the oil jets in the head under the cam blocks. thanx
Re: Swapped head from 74-77 which oil jets should i use? 74 750k
« Reply #1 on: March 31, 2012, 09:56:09 AM »
Are they different? I didn't think so.  I'll go check some microfishies.
Offline 1974cb550k
« Reply #2 on: March 31, 2012, 10:29:58 AM »
Yep same #. I must have got confused because Hondaman is making over sized jets. Looks like a classic case of being lazy on my part.
« Reply #3 on: March 31, 2012, 10:42:14 AM »
No problem. If clean, and you have no high performance need, then no need for oversize. Though they would be neat.
