Author Topic: Marine gas. Ethanol free. Anyone tried it?  (Read 10994 times)
Offline bender01
« on: April 11, 2012, 04:58:45 AM »
We just had a gas station on my commute start selling 89 ethanol free gas. My 750 k-4 absolutley loves it. Anyone else tried it and noticed a difference? The bike is better from a standing start right up through the gears . I noticed the difference especially after a tank of 87 and back to the ethanol free. Try it. Its 4.18 a gallon though. Im going to test the mileage long distance this weekend on a trip. Both 87 and 89 E free.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline stereosilence
  • 1975 CB550K
Re: Marine gas. Ethanol free. Anyone tried it?
« Reply #1 on: April 11, 2012, 09:50:32 AM »
You should get better performance. Ethanol just waters down the gas and is also corrosive. I'm jealous you can get the good stuff. The enviro-nazi idiots have it outlawed in my neck of the woods. Use it in all small engines, by the way.
Offline jamanred
« Reply #2 on: April 11, 2012, 10:47:04 AM »
Check out Startron's fuel enzyme treatment.  Not the easiest stuff to find, but works great in my truck and car..  Will be using it in my bike as well, when I get it fired up in a few weeks.  Makes my vehicles run like they are ethanol free.
73 Honda CB500 K2 = open wallet, slide card, hide from wife
Offline Teatimetim
« Reply #3 on: April 11, 2012, 11:05:44 AM »
Lot of times it is marked racing fuel.  though the octane where I can get it is 94.
Bikes I own:
1974 CB550K
1971 CB450
« Reply #4 on: April 11, 2012, 11:16:08 AM »
There is a web page listing stations for every state, it comes out on google search. I just found one in Marshall, VA and wil give it a shot.
pure-gas.org
Offline phil71
« Reply #5 on: April 11, 2012, 11:18:52 AM »
last summer, I brought back 94 octane 'real gas' from mid ohio. Put it in the 750k1... the difference was instantly noticeable.
   Ethanol benefits farmers, but I'm dubious about what it does for the environment. Even if there is a slight reduction in emissions,  each charge has fewer btus, and therefore less power, so you're going to use more of it to go the same distance, and thus, be belching the more crap into the air.
  Not all conspiracies are theories.
Offline Teatimetim
« Reply #6 on: April 11, 2012, 11:28:34 AM »
Mark that benifits corn farmers.  Actually Ethanol's growth has more to do with fuel stability and the banning of MTBE, which has been leaking from Fuel tanks into water supplies.
Ethanol can be a fine fuel, but engines must be tuned specifically for it in order not to feel a loss of power and the miliage is a bit lower I believe.  A 40 year bike is most likely going to run on the Fuel it was designed for.
Oddly enough, if the country were serious about using Ethenol as a fuel instead of a farm subside, they would be promoting forms of ethenol production that yelds much higher amounts, things such as sugar beats, switch grass, and Sorigum Caine.
Bikes I own:
1974 CB550K
1971 CB450
Offline nayto550
« Reply #7 on: April 11, 2012, 01:07:48 PM »
There's two stations where I live that have no ethanol fuels.  One has 86, 87, & 91 octanes, the other has 87, 89, & 91.  The only two places I go to fill up my motorcycles.
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: April 11, 2012, 03:17:21 PM »
Yep, the world is still flat. Ride like hell to you get to the edge then turn around and ride like hell till you reach the other edge.  ::)
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Rob69
« Reply #9 on: April 11, 2012, 04:32:55 PM »
I don't know where I could get Marine gas in my area, if anywhere. I add Startron fuel stabilizer to my fuel to counter the harmful effects of ethanol.
« Reply #10 on: April 11, 2012, 04:40:20 PM »
http://pure-gas.org/index.jsp?stateprov=PA
Offline fmctm1sw
« Reply #11 on: April 11, 2012, 05:27:40 PM »
Yep, I use it.  Couple stations around here carry it.  I honestly didn't see that dramatic of a difference in my bikes or my truck though.  The rubber parts in my carbs probably knew the difference though.  I made it a point to stop in the last station I was at and thank them for having it.  I told them, "Don't let this stuff go anywhere."
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline RatBikeRandy
  • Yes I Can
« Reply #12 on: April 11, 2012, 05:37:53 PM »
To the guy in Atlanta.
There are some stations selling no ethanol gas.  There is one definitely in Whitesburg, GA not far from Carrollton.  Last check was 89 octane for $3.95 gallon.  It runs better and I get better mpg.
« Reply #13 on: April 11, 2012, 05:41:21 PM »
http://pure-gas.org/index.jsp?stateprov=GA
Offline Rob69
« Reply #14 on: April 11, 2012, 08:00:32 PM »
Thanks for the link. I bookmarked it. Unfortunately, the closest ethanol-free gas station to me is nearly 30 miles away.
  • 1975 CB550K
« Reply #15 on: April 11, 2012, 08:10:55 PM »
I am fairly certain it is outlawed in the metro-Atlanta counties. I did some research on it a while back. They should make an app for those gas stations.
Not even Al Gore thinks it's good for the environment anymore. On the other hand, when I find myself agreeing with Al Gore, I take some time to sit down and re-evaluate my life...
« Reply #16 on: April 11, 2012, 08:31:22 PM »
It is a good product.
Offline mitch500
« Reply #17 on: April 11, 2012, 08:44:42 PM »
Is ok to run 91 octane ethanol free in my 78 CB550k ? Thats the only ethanol free gas I can find in my area.
Offline Rob69
« Reply #18 on: April 11, 2012, 08:50:44 PM »
Without question, yes.
« Reply #19 on: April 12, 2012, 03:03:41 AM »
I am in the same boat. The closest is 20 miles and off my typical riding patterns. Seems like it is mostly Mo and Pa shops, but Liberty sells it in rural areas but not near DC metro.
« Reply #20 on: April 12, 2012, 03:24:22 AM »
Some of the gas stations here sell fuel with Ethanol in it, mostly it's 95 RON and a little cheaper than our standard 91 RON unleaded, but mostly I use 98 RON Shell or BP fuel, or occasionally 100 RON when I can get it. Two of my bikes are running relatively high compression pistons, and the 98 RON fuel works very well with them. (as does a cup full of Acetone in each tankfull) Cheers, Terry. ;D
Offline Psychonaut
« Reply #21 on: April 12, 2012, 05:04:37 AM »
Ethanol is a better fuel. You do need more of it though compared to gas. Google it. Higher octane, higher latent heat of evap. Many people run water/alc inj to make big power with boost.  You can run more timing, compression or boost. I ran 26- 28 psi with alc inj and 91 octane, 18-20 psi on just 91 octane. True it is less friendly as far as corrosion though.
« Reply #22 on: April 12, 2012, 05:30:32 AM »
70CB750,
      I'll be driving South on I 81 soon and wondered if I'll be able to encounter any Liberty Fuel stations on my way through VA. that sell the Good fuel...or is it just Liberty stations around where you are ??
« Reply #23 on: April 12, 2012, 06:28:56 AM »
Check the web page, there should be plenty around 81. In winchester there are two Liberties but Harrisonburg lists 6 stations.  You should be able to fill eth free most of the ride on 81 from what I see here.
Offline bender01
« Reply #24 on: April 12, 2012, 06:39:22 AM »
Sunday I will run one full tank of each on the highway and post MPG results.
75 550 K1
74 750 K4
74 750k 836 project
Good luck!
Two Tired Quote !
