Bungy lever to bar.
Put bike on side stand, turn forks full lock left , leave a couple of hours, turn full lock right and do the same. Tap brake lines with a screwdriver handle
When you remove bungy, hold lever and allow it to 'flick' out suddenly, it tends to pull air up and out of piston bore
You people are not shaking the bake fluid before using it? If you do you get 'micro-bubbles' in it which take at least 48 hrs to dissipate
