Author Topic: really stupid master cylinder question..... with pics  (Read 4381 times)
Offline xsmooth69x
« on: May 14, 2012, 11:54:05 AM »
ok i thought i put together the master cylinder correctly but i guess i didnt so i need clarification.....
the kit i got did not come with directions
the reason i posted this next pic is that the kit made me put on this rubber thing on the piston. is it facing the right way?
now how do i put this thing together?
i believe the spring goes in first but i dont know which end goes in the big side or the little side first?
then i think its the smaller rubber piece?
the the piston with the bigger end that has holes and a weird flower piece of metal that is connected to the piston thing on the end
then the big washer i forgot to add in the picture then the c ring thing
then the rubber boot with the other retaining clip thing
spring (which end first)> rubber thing?> piston> washer> c ring thing> rubber boot> other retaining clip.......
1975 CB550 (FINISHED?!?!?)
Offline fmctm1sw
Re: really stupid master cylinder question..... with pics
« Reply #1 on: May 14, 2012, 11:59:00 AM »
In the top picture, take that long spring and turn it 180 degrees.  That rubber cap thing near the top center of the photo goes on the small end of that spring and butts up against that "flower." Your piston is assembled right.  Then washer, retaining clip, boot and wire clip
« Last Edit: May 14, 2012, 12:03:54 PM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline xsmooth69x
« Reply #2 on: May 14, 2012, 12:22:26 PM »
sweet thank u!
Offline lucky
« Reply #3 on: May 14, 2012, 12:32:14 PM »
Whenever you take mechanical things apart ALWAYS take notice of how they came apart, and draw a little sketch or take a photo especially if you will be waiting for parts.
It is just standard practice.
 A good mechanic lays things on a table in the order that it came apart and with a particular side facing up etc.,.
Offline xsmooth69x
« Reply #4 on: May 14, 2012, 12:39:20 PM »
ya i usually have a digital camera and take pics step by step. i did have the MC done but it didnt work
also a put the mc back together and after some pumping nothing came out the right end and it started leaking by the lever....
could the gasket on the piston be backwards?
when u pump the brake lever the brake fluid should shoot out shouldnt it?
Offline fmctm1sw
« Reply #5 on: May 14, 2012, 12:55:32 PM »
I'm pretty certain your piston is ok.  I had a hard time bleeding mine too.  My tactic was to pump slowly.  I had little bubbles come out of the small hole in the M/C for a little before it firmed up.  Once it firms up, it will shoot out and blast you right in the face if you're not careful.  Leaking past the lever is troublesome though.  Are you sure it's not just running down from the brake line connection?
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline xsmooth69x
« Reply #6 on: May 14, 2012, 01:09:36 PM »
i will clean up and try again. i was pumping without the brake line on
i did notice the bubbles i will pump slower
Offline xsmooth69x
« Reply #7 on: May 14, 2012, 01:16:36 PM »
nope it leaks at the handle......
Offline aperry
« Reply #8 on: May 14, 2012, 01:27:55 PM »
I just rebuilt my 750 MC and had the same leaking problem at the lever hinge.  Worried that I assembled it wrong I scoured these forums.  One thing I learned was that people recommended not pulling the brake lever all the way down when you're bleeding the line.  Apparently this can cause the leaking, possibly due to the alignment of the reservoir holes with the piston seal.
So I started pulling only about halfway and after a few minutes I started to feel pressure.  If memory serves, the process was something like this:  with bleeder open pump the lever a bunch of times until you see fluid leaving bleeder.  Then close bleeder and pump 4-5 more times, them open bleeder and more fluid should immediately leave the bleeder.  Then repeat this last part (close bleeder, pump 4-5 times, open) a few times.  You should start to feel pressure.  Each time you pump the handle only go half way.  Once the pressure builds, you shouldn't see any leaking at the lever.
Worked for me.
Aaron
CB750K3 with F1 frame/swingarm
Offline xsmooth69x
« Reply #9 on: May 14, 2012, 01:32:26 PM »
brilliant i will try this!
Offline xsmooth69x
« Reply #10 on: May 14, 2012, 02:26:48 PM »
another dumb question. this is the first time ive used a speed bleeder.... do u have to loosen the bleeder or do u just leave it tight and and bleeds out the air automatically.....
Offline xsmooth69x
« Reply #11 on: May 14, 2012, 02:40:05 PM »
got it!!! thanks everyone speed bleeders are awesome!
