Author Topic: Why do some people find it necessary to respond to every post  (Read 72232 times)
Re: Why do some people find it necessary to respond to every post
« Reply #75 on: June 04, 2012, 09:14:54 PM »
HuH?
Offline Boulevard_beck
« Reply #76 on: June 04, 2012, 09:50:52 PM »
I tried to search for the answer, but the search seems broken. Is there some special trick to search for why people respond to every thread?
« Reply #77 on: June 04, 2012, 10:24:43 PM »
What's more frustrating is those who ask for help, get good advice, and do nothing  >:(
« Reply #78 on: June 05, 2012, 08:17:48 AM »
My low beam burned out what should I do? it works on high beam so I don't understand why it won't work on low. Should I get a new battery?
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #79 on: June 05, 2012, 08:26:01 AM »
Idon't know if I want to respond to that post.
Offline Gordon
  • 750K1, 550K2
« Reply #80 on: June 05, 2012, 08:42:19 AM »
Check your blinker fluid level.  When it runs low it wreaks havoc on the entire lighting system.
http://kalecoauto.com/index.php?main_page=product_info&products_id=22
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #81 on: June 05, 2012, 09:40:04 AM »
Make sure that you have enough water in the upper chamber so when it drips onto the calcium carbide there is enough to light.  Then make sure that the carbide chamber isnt packed with the slaked lime. Should be good after that.
« Reply #82 on: June 05, 2012, 10:02:17 AM »
post
« Reply #83 on: June 05, 2012, 10:15:04 AM »
Respond!!
Offline thrutheframe
« Reply #84 on: June 05, 2012, 10:24:19 AM »
Are you a coal miner or do you have a theatrical lighting background?  Those are bout the only two types of people who know how a carbide lantern works these days.
Post Respond Post Respond
Oh and spellcheck too thats a good one.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #85 on: June 05, 2012, 10:48:50 AM »
Ok I'm in too..... :-X :-X
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline MoMo
  • Ride like you're invisible
« Reply #86 on: June 05, 2012, 03:30:19 PM »
Don't some of the old headlight lanterns work that way?....Larry
« Reply #87 on: June 05, 2012, 04:02:27 PM »
My headlights are over thirty years old.  What should I do?
Offline HonderCB
« Reply #88 on: June 05, 2012, 04:04:21 PM »
so what you're saying is, any old 10W40 will work?
77' CB750F
81' CB650C - SOLD
« Reply #89 on: June 05, 2012, 05:12:03 PM »
as long as it responds, yes
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
« Reply #90 on: June 05, 2012, 05:49:06 PM »
spellcheck?
« Reply #91 on: June 05, 2012, 06:20:24 PM »
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Damfino
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
« Reply #95 on: June 05, 2012, 07:32:45 PM »
Steve O cares.
« Reply #96 on: June 05, 2012, 07:35:39 PM »
I know kare
« Reply #97 on: June 05, 2012, 08:52:30 PM »
Ok I ordered the carbide lights but where do I store the water to make them work?
Offline Spanner 1
« Reply #98 on: June 05, 2012, 09:31:53 PM »
I hate the cliffhangers....... where a poster gets 3 or 4 very good suggestions to fix their problem and they respond ' Thanks for the responses, I'll try that tonight " ..... and never come back to say what the cure was......... very annoying, nobody learns anything and just plain rude.... happens too much, IMO  ::)
« Reply #99 on: June 06, 2012, 07:14:02 AM »
You could just use the speedo or tach housing and run a nylon tube to the lamp in question. Probobly want to use some calking on the housing first. If this is for your KO, just use superglue because the housing is plastic.
(well played Don)
