Author Topic: Rear Shock Absorber Inquiry  (Read 6585 times)
Offline spiritof67
« on: May 22, 2012, 09:58:30 AM »
I have used Koni/Ikons since the 1970's on CB750s. Over the years I've seen any number of others come and go (Red Wing, Marzocchi, Marubeni, S&W, Mulholland, etc.) but the standard seems to have been set a long time ago by a shock with a steel body and good adjustability. Short of having to create a set of Ohlins, which I won't do, what are the recommended rear shocks for the standard clevis-bottom CB750 swing arm?
Spirit
Offline Doctor_D
Re: Rear Shock Absorber Inquiry
« Reply #1 on: May 22, 2012, 10:21:21 AM »
I'm very happy with every shock I've purchased from Works Performance.  They offer many different styles and all are custom made for individual applications.  Others on the board like YSS.  Hagons are a fine budget-oriented choice.  Progressive Suspension are chunky looking, but like Hagons provide good value for the dollar.
« Last Edit: May 24, 2012, 09:09:12 PM by Doctor_D »
Take care,
David
1978 CX500
1971 Norton Commando
Offline spiritof67
« Reply #2 on: May 22, 2012, 11:39:34 AM »
YSS makes a clevis-bottom shock for the CB750?
Spirit
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #3 on: May 22, 2012, 11:56:43 AM »
Spirit
Yes.
Offline Tintop
« Reply #4 on: May 22, 2012, 02:59:27 PM »
Spirit
Yes.
+1  I used a pair on my 550, you can get them in a variety of lengths.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline spiritof67
« Reply #5 on: May 22, 2012, 06:57:37 PM »
Which models have been used by posters? The attached-reservoir ones or the single bodies?
Spirit
Offline Tintop
« Reply #6 on: May 22, 2012, 07:08:19 PM »
I used the gas ones without the external reservior, but with the threaded preload adjust.  Just prefered the more traditional look.  Photo mounted -
77 CB550 Cafe build
« Reply #7 on: May 22, 2012, 07:12:11 PM »
Very cool TinTop!
Offline Tintop
« Reply #8 on: May 22, 2012, 07:32:33 PM »
One other feature of the YSS's, they are length adjustable.  The bottom clevis can be adjusted to add up to 10mm. 8)
77 CB550 Cafe build
  • Moderator
« Reply #9 on: May 23, 2012, 04:37:39 AM »
Spirit, Juha Leino used a YSS shock on his Suzuki drag bike for the first time last weekend.
I know it's for a different application but he really does rate them.
http://forums.sohc4.net/index.php?topic=107215.0
Sam. ;)
Offline turboguzzi
« Reply #10 on: May 23, 2012, 06:07:29 AM »
some folks around here are happy with these
http://www.ammortizzatori.net/kf6.htm
Offline Leino
  • Not much of an
« Reply #11 on: May 23, 2012, 11:20:39 AM »
This feature can be installed on 290mm and longer shocks.
Offline spiritof67
« Reply #12 on: May 23, 2012, 02:25:32 PM »
Turboguzzi: Si, per' qui nomme gli ammortizzatori?
Spirit
Offline spiritof67
« Reply #13 on: May 24, 2012, 04:50:07 PM »
I'm interested in why not one person said anything about Progressives. They seem to have the largest variety of CB750 SOHC shocks available, but nobody said a word about them. I've actually seen more about Ikon/Konis than them. Why? Also, who has the best Stateside prices for the YSS's?
Spirit
« Reply #14 on: May 24, 2012, 04:54:17 PM »
Spirit
Progressives are fine and used to be the first rec. i think we've all gotten bored and go with more exotic names.
« Reply #15 on: May 24, 2012, 05:33:59 PM »
Spirit
From what i have been told about progressive shocks you get what you pay for, most are fine for the average rider but not great as a performance shock. {fade quickly when pushed} I generally check out what racers use, i know plenty of guys that have used Ikon {Koni's} a couple with Hagons, some with Marzocchi's {spelling?}, S&W, and from reading on the forum , YSS, ohlins and more, i am well over spending money to be a guinea pig for some "flash" shocks, i would rather go on a more proven method, usually works out cheaper too.... ;)
Offline spiritof67
« Reply #16 on: May 24, 2012, 07:06:46 PM »
OK then, about that Stateside price for YSS's? Both my CB's have Konis now...old ones. There has to be something at ;east as good as a 40+ year old set of shocks. I'll try YSS since I'm not paying US$1200+ for Ohlins.
Spirit
Offline Tintop
« Reply #17 on: May 24, 2012, 08:28:35 PM »
Have you checked to see if the Koni / Ikon's you have are rebuildable?  Some (not all) are, and it would be less expensive than buying new.
77 CB550 Cafe build
« Reply #18 on: May 24, 2012, 10:06:39 PM »
Thats a good point Brian, i think all Koni's are rebuildable.... ;)
Offline Doctor_D
« Reply #19 on: May 25, 2012, 07:39:22 AM »
Spirit
My Works Alloy Tracker's were $500.  Not bad for a custom sprung and valved shock.
Progressives and Hagons will run you roughly half of that.
Take care,
David
1978 CX500
Offline spiritof67
« Reply #20 on: May 25, 2012, 07:41:57 AM »
Doc D, did you buy them directly from the YSS provider, or...?
Spirit
Offline Doctor_D
« Reply #21 on: May 25, 2012, 08:34:52 AM »
Apologies for the confusion, but I mis-read your interest in going with YSS.
I was talking about Works Performance "Billet Trackers" http://www.worksperformance.com/html/street.html  I have nothing but good things to say about Works products.
Take care,
David
1978 CX500
Offline spiritof67
« Reply #22 on: May 25, 2012, 04:59:14 PM »
D: Yes, I have basically settled on Works myself over the years - an excellent product. Used them on my Guzzi LeMans 1, my Suzuki GS1150ESE and they were great. I have a Fox Superbike shock on my '86 GSXR but that was a price deal, back then.
I'm already having the Works that I use on my LeMans overhauled so when that's done (and I have the money) I will probably go for them for my Honda project. Certainly a lot easier than finding out what the actua/original paint job was, I'll tell you...
Thanks for the redirect. Always appreciated.
Spirit
