Author Topic: Bosch H4 conversion - done with pictures  (Read 11324 times)
Offline brandEn
« on: May 26, 2012, 05:28:59 PM »
I was looking for a Tri-Bar H4 conversion but during my research I started reading up on the Bosch European Motorcycle conversion P/N 0 301 600 118. I just ordered one so we will see. Here is some great info. Apparently they like to use them in VW Bus'
http://www.ratwell.com/technical/BoschH4.html
« Last Edit: June 02, 2012, 03:59:51 PM by brandEn »
Offline brandEn
Re: Bosch H4 conversion.
« Reply #1 on: May 27, 2012, 01:41:41 PM »
Just changed this thread from a tri-bar thread to a Bosch MC H4  thread...
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #2 on: May 27, 2012, 02:50:53 PM »
If you're referring to the Bosch H4 reflectors that Candlepower is selling, they're great. I've installed four of them in various bikes. The beam pattern and coverage is outstanding.
MCN DTF
Offline brandEn
« Reply #3 on: May 27, 2012, 05:23:52 PM »
Not sure, got any links?
« Last Edit: May 27, 2012, 05:26:07 PM by brandEn »
« Reply #4 on: May 27, 2012, 07:09:11 PM »
My experience with converting DOT sealed beams to European H4s in cars has been positive and much superior lighting.  Just don't overload your stator output with too high a wattage bulb or your Battery won't be happy with the lower charging levels.
Offline brandEn
« Reply #5 on: May 27, 2012, 07:25:22 PM »
what do you consider to be a to high wattage bulb? I have some  Philips X-treme Power H4 12V 60/55W.
« Reply #6 on: May 27, 2012, 07:48:55 PM »
I wouldn't want to go higher than 60/55W ...what's so special about those bulbs? That's a standard auto wattage ..
I used to run 80/100w h4s (Cibie glass lenses eurospec  H4s) in my cars. The better optics controlled the beam pattern with little scattering and sharp cutoffs on the beam pattern so it could be aimed below most people's side mirrors and not blind opposing traffic or someone in front of you.
You want to run relays and heavier wires for the headlamp. It makes a noticeable difference.
« Reply #7 on: May 27, 2012, 08:11:19 PM »
I took a look at my Candlepower unit that Stu mentions. While the $47.99 Candlepower unit I have been using for ~ 10 years is a great improvement it is different than the pictures in BrandEn's link show. My Candlepower unit has a CPi logo molded into the front center of the lens. It also has an arrow molded on the lens pointing to the right and it says motorcycle. Motorcycle specific manufacture. Without taking my headlight unit apart on my ALMOST completed restore I'm thinking I'm running the 60/55 bulb. And yes, my old electrical (NOS electricals now and ALMOST finished electrical system) system was taxed BUT in speaking with Dyna they feel that problem is mainly associated with my 3ohm coils. Of course, the bulb would further tax a weakened system. The 60/55 is a BIG improvement anyway. BrandEn if you decide to try a larger bulb please document before/afters with stock, H4 60/55 and H4 BMF.
Offline srbakker
  • Spam & Eggs
« Reply #8 on: May 27, 2012, 08:53:03 PM »
Anyone got a picture of how they plugged that Candlepower unit into the headlight ring?  I have one waiting in my basement but for the life of me, can't figure out how the tabs line up.   :-[
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
« Reply #9 on: May 27, 2012, 09:06:00 PM »
I've been running a Bosch H4 conversion with a 55/60 watt bulb on my 750 since 1979. 8)
« Reply #10 on: May 27, 2012, 09:56:28 PM »
Will a sealed beam auto round lamp fit our bikes? I'm thinking the 6024 bulb if I recall the number correctly,  reason I ask is the Sylvania/Philips Xtravision model has the 55/60w bulb in an improved optics package that is like the Euro H4 but with a flat cutoff pattern (horizontally) without the "finger " of the pattern lighting the right shoulder for us Americans driving on the right side of the road. So it is a motorcycle and car friendly pattern if it works in the headlight bucket. Not quite as good as a real H4 with glass lens but nearly as good for about 12$.  FWIW
« Reply #11 on: May 27, 2012, 10:54:24 PM »
How/what do you mean?
Offline tweakin
  • tear down
« Reply #12 on: May 28, 2012, 07:21:17 AM »
B,  I have been running this on the 915 for the past year, works great and I picked it up at baxters auto.
« Reply #13 on: May 28, 2012, 07:36:49 AM »
+1. Step into the light.  ;D
My wife rode a 400F for many years and honestly that small sealed beam was useless. She always rode behind so my 750 would light the way. When I finally finished her 550 I installed one in it and she was more excited about the headlight than the new ride. Do install relays and heavier +12V wire.
« Reply #14 on: May 28, 2012, 11:13:00 PM »
You can install a LED compatible electronic flasher and convert to wide viewing angle LED bulbs and lower the turn and brake light load on the electrics and have brighter bulbs with modern LEDs.
Offline srbakker
  • Spam & Eggs
« Reply #15 on: May 29, 2012, 05:29:23 AM »
I'll try to snap a few pics tonight.
1975 CB750 K5
2007 Triumph Tiger
« Reply #16 on: May 29, 2012, 11:02:37 AM »
Good, I have a spare I can use for help.
Offline brandEn
« Reply #17 on: May 29, 2012, 05:44:51 PM »
I drew this up. Does this look right? Almost seems to easy. Thanks for any comments on this.
Offline Tews19
  • I am no
« Reply #18 on: May 29, 2012, 08:13:58 PM »
It should be simple. Maybe you have the wrong headlight bulb?
1970 Honda CB750 survivor.
Offline mrrch
Re: Bosch H4 conversion- REVIEW my wiring diagram
« Reply #19 on: May 30, 2012, 09:28:23 AM »
I think you will need 2 relays (one for each beam). I found a wiring diagram online and wired mine with 2 relays.
my build
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #20 on: May 30, 2012, 09:38:29 AM »
If you have a 55/60 bulb in there you should not really need relays for a 750, that is what is on there stock.
Offline brandEn
« Reply #21 on: May 30, 2012, 10:55:45 AM »
Needed? No not really. But I want to get what I can out of my parts. Relay ads that for full h4 potential!
Offline mrrch
« Reply #22 on: May 30, 2012, 11:34:19 AM »
The relays are more for taking the strain off of the old switch gear and old wiring.
Brighter output due to full power is a bonus.
my build
Offline srbakker
  • Spam & Eggs
« Reply #23 on: May 30, 2012, 04:59:11 PM »
Yeah, it turns out I'm an idiot.  Please disregard and sorry for the thread hijack.  I'll go bury my sorrows in beer.
1975 CB750 K5
2007 Triumph Tiger
« Reply #24 on: May 30, 2012, 05:17:49 PM »
BrandEn, as always I'm a few steps behind you guys and I'll be watching. I've been running mine direct - no relay. My understanding WAS that the relay is a switch protector. The left side switch is not available from Honda (75/76F) so that may be a good idea if only for that reason.
