Don't Cut away the gasket . Also don't re use o rings , especially the ones that supply oil to the head . You should be able to find a o ring supplier in your area without
too much trouble . Use on line views like the 2 above posted by branden to find the right sizes then take the list with you . # 15 in the second pic is another important
ring that seals the oil passage between the upper and lower case halves ( i see your cases are already together ) . There are 4 rings that go between the cam tower and the head . One goes around each oil jet and the others go in depressions in the head at the outer end of each tower . These rings are essential in providing oil pressure to the towers . If they leak you'll destroy ( not an exageration ) your towers , cam , and rockers . You've done a lot of work . Don't skimp on a handful of rubber bits that will cost less then a burger , fries , and drink .
