Author Topic: 65 MPH on a curve.. REAR TIRE BREAKS LOOSE...  (Read 6722 times)
Re: 65 MPH on a curve.. REAR TIRE BREAKS LOOSE...
« Reply #25 on: June 18, 2012, 05:34:54 PM »
After you install that new tire make sure to wipe it down with acetone to remove the molding waxes.
Tom
Or do a small burnout.... ;D
Offline crazypj
  • I'm brill, me
« Reply #26 on: June 18, 2012, 05:47:55 PM »
Old tyre sounds like the problem.
If your interested you can find charts online to decipher the date code and find out exactly how old.
Usually more than 3~4 yrs and rubber is getting pretty hard (quicker if left out in the sun)
Cheng -Shin are not exactly soft compound tyres to start with
scrapvalue
« Reply #27 on: June 18, 2012, 06:05:55 PM »
You can check the quality of your tires,(new or old), with a simple test.
Try pushing on the tread with your thumb nail. If you can push it in a little that is good. If you break your nail when you try, it is time for it to go.
Soft tread equals traction, Hard tire equals slippery tire.
Offline Randy
  • Nothing like a banging four under my legs..
    • Mission Detail
« Reply #28 on: June 18, 2012, 06:12:19 PM »
ok..
1973 CB500k, 1972 CB750 (New Arrival), 1978 Vespa P200 (New Arrival)
Offline RFogelsong
« Reply #29 on: June 18, 2012, 09:08:29 PM »
Yeah, I went from an old dry rotted tire on the rear of my bike to a new dunlop s11 spitfire and it's amazing the grip level available now.  New tires solve (almost) everything.
-Rob
Hondas past/present:
SOHC1:'74 CB125, '78 XL125
DOHC2:'71 CB450K
SOHC4:'73 350F, '75 400F, '75 550K
DOHC4:'81 900F, '01 1100XX
V4:'85 VF1000R, '86 VF500F, '08 VFR800
Offline lostinthe202
  • Quality testing Elite 80's since 1978!
'72 CB500
