Author Topic: Dual disc cb750 spacer question?  (Read 2891 times)
Offline 88blkiroc
« on: June 25, 2012, 11:55:34 AM »
Can anyone show me a picture of how you spaced out the caliper arm pivot mounts from the fork on the right side of a CB750 dual disc conversion? My bike had dual discs on it when I got it but I dont think they installed them correctly as the right side was binding hard. I rebuilt the calipers already and mounted them up yesterday but when I snug up the bolts on the right side the wheel binds. After looking at it I can see the caliper arm isnt parallel to the disc as it is on the left side of the bike. Any pics you have would be very helpful. I was going to just space it out with washers but I need an idea of how many or if there are any alternatives to the washers that work better.
74 CB750K slowly turning cafeish
74 CB750K parts bike
70 CT70 Trail 70
07 Yamaha PW50 (kids 1st bike)
Former:
01 Shadow Spirit 1100
88 NX125
68 S90 Dream
Online HondaMan
Re: Dual disc cb750 spacer question?
« Reply #1 on: June 25, 2012, 12:23:09 PM »
This installation depends on whether you're using the mirrored "C"-shaped hanger, or the "T"-shaped one. Both will interchange. If you have my book, or know someone who does, there's a section in the Front Brake chapter that shows the details. If you use the post-1972 "T" shaped pivot hanger, it is easier to install the right side disc.
Offline 88blkiroc
« Reply #2 on: June 25, 2012, 12:49:35 PM »
Im assuming its the T type. The bike is a 74 CB750K4 and both side caliper assemblies look the same so I assume its whatever is stock for that year. The pivot consists of a pin that takes one bolt at the bottom, goes through the caliper arm and then into a bracket at the top with a hole in the center for the top of the pin and a bolt hole to secure it to the fork on either side. I dont have your book nor do I know anyone with it unfortunately.
That's the only pic I have at the moment that shows the caliper at all.
70 CT70 Trail 70
Former:
88 NX125
68 S90 Dream
« Reply #3 on: June 25, 2012, 12:55:48 PM »
Trial and error. I used old nasty washers.
Then I used a chrome spacer from ACE Hardware (they had them in Metric in the Chrome drawers) with a chrome washer to make up the dif.
Yoshimura made them (whole brackets) from scratch out of magnesium, IIRC. A little pricey.   ;)
Offline george
  • Back To My Roots !
  • K8 The Project
« Reply #4 on: June 25, 2012, 02:54:46 PM »
I had this stashed back, never did it though, I'm in the process of switching to a DOHC front end.
Hope it helps, good pics .
http://www.salocal.com/sohc/tech/dual_disks/dual_disks.htm
Found this bike in completely stock condition in Feb. 08. Paid over twice what my new one cost 30 years ago. Am trying to re-create the look of the late 70's Drag Bike styling.More later. 4-2-10 It ain't stock any more and I have no idea what I am trying to create !
« Reply #5 on: June 25, 2012, 03:10:02 PM »
I copied this from the forum:
  Turn the adjuster screw until it draws the "B" pad (the "passive" pad that does not have the moving piston behind it) to within  5thou of the disc. Yes use a feeler gauge. Lock it in place with the nut. Now pump the brake until it is tight, then release. If the A pad is withdrawing properly, and the Master Cylinder is allowing it to withdraw as it should, you'll be able to measure your 5 thou clearance on the B pad once again. Smoothly, with no hitches.
Hope it helps :)
Offline spiritof67
« Reply #6 on: June 25, 2012, 03:33:23 PM »
The Yoshimura/Checkered Flag Customs (CFC) magnesium brackets might be a little expensive but they are the way to go. But bear in mind, Honda had spacers for almost the whole mounting system, so even in normal use, there can be clearance problems....
Spirit
« Reply #7 on: June 25, 2012, 07:37:16 PM »
Yes, that sounds like a "T" bracket. To make it align vertically, you need to either add spacer washers under the top 2 "T" bracket mounts, or remove the same amount off the bottom fork-leg boss. If my memory is correct, the difference is something like .090".
If you have new pads, you might try mounting the caliper VERY loosely, and apply the brake; with pressure holding the pads square against the rotor, look at the mounting points. Any gaps need shims, any tight spots may need material removed. This will help make the pad faces parallel to the disc in both the horizontal and vertical axis.
Offline cben750f0
« Reply #8 on: June 26, 2012, 05:15:09 AM »
sweet that write up is still around, i wrote that up about 8-10 years ago...lol
yup, you either remove metal off the lower boss, lil, by lil, then use a straight edge to check the caliper arm mount surface is parallel with the disc face. once it is parallel , then you shim the top mount to suit.
hope this helps
