No, it's not crocs, snakes or even spiders...
It's a Drop bear, just the mention of their name strikes fear into the heart of anyone who has been savaged by one of these vicious creatures.
A few ways to avoid attacks
*Avoid walking under trees. If for some bizarre reason you feel a compelling urge to walk under every tree you see, attempt to avoid the chainsaw of natural selection by lying down under trees and spitting upward. Drop Bears will typically spit back down at you. If you successfully detect a Drop Bear - Move. Quickly.
*Do not camp or pitch tents under trees. Especially trees with long overhanging branches. If the drop bears don't get you, the eucalypt's annoying habit of shedding boughs during dry conditions will.
*Rub Vegemite behind your ears. Drop Bears cannot abide the smell of Vegemite. Do not fall for the common mistake of rubbing toothpaste behind your ears: that's just silly. Stick to the Vegemite! Do not be lured by the misconception that rubbing the #$%* of an Australian politician behind your ears will prevent attack. It may stink but it's full of bull#$%*!
*Stick forks in your hat. While this may not actually prevent the Drop Bear from attacking you, it will certainly deter it from attacking you again.
*If you suspect an encroaching attack by a Drop Bear, walk on your hands. This totally confuses drop bears, as they begin to wonder if they are actually below you looking up through the ground. This is so distressing for the Bear that it often triggers an onset of sudden exploding head syndrome.
*Before setting out on a bushwalk (aka Magic Roundabout) trickle rivulets of your own urine on your footwear.
*German WW I helmets with the spikes on the head were introduced in June of 1916 when the Australian 105th Laundry and Dirty Tricks Brigade started dropping drop bears into the enemy trenches from special "eucalyptus zeppelins," and to this day a more potent deterrent has yet to be found.
*If you want to prevent a drop bear from raiding your campsite spread a 6 pack of lite beer around your campsite. The scent of the lite beer repels the drop bear away from your campsite. WARNING:do not place XXXX beer around your campsite. This will only attract more drop bears and they will stay for hours more. If beer is essential (as it often is) only bring Fosters. The smell alone will knock out a healthy adult Drop Bear for up to 4 hours.
*Wearing a cork hat after covering your face with Vegemite has been known to keep away Drop Bears. This may be because the scent of the Vegemite confuses the Drop Bears into thinking that you're Australian. Be careful though, because if the entire face isn't covered, it has been known to fail.
