Author Topic: The time has come - maybe...  (Read 4579 times)
Offline sparty
  • I just play one on TV
  • My engine is 100% stock... wink.
    • Gallery
« on: July 25, 2012, 08:05:54 PM »
It has been some time since I have been active on the forum.  Life and other hobbies get in the way.  I am considering selling the Hot Rod CB750 that I modified a few years ago.  Mike built a killer motor for me.  I am unsure where to begin pricing the bike.  I know that parting it out would be a sin, but that seems to be where the money is.  I guess I really need to find a fanatic that is willing to buy it.
I am looking for some advice on how to sell a Hot Rodded CB750. If you search back on my old posts, you can find out what went into this bike.
-Sparty
Here is a picture:
« Last Edit: July 25, 2012, 08:07:47 PM by sparty »
1972 CB750 K2 Cafe' Style
GO AWAY SNOW AND COLD!  Can you see the Hot Rod wants to run...
“That's thirty minutes away. I'll be there in ten.”
Re: The time has come - maybe...
« Reply #1 on: July 25, 2012, 08:53:20 PM »
Great looking bike, please dont part it.
Put it on ebay with great pics and description, and hopefully you will have a bidding war. These nice 750's are selling for good money now. Set a reserve that you won't take a bath on and you may be ok. Unless you spent an ungodly amount building it.
BTW, why you selling?
Good Luck.
« Reply #2 on: July 25, 2012, 08:56:59 PM »
 Just wait a few years, you will get into it again..
« Reply #3 on: July 25, 2012, 11:50:22 PM »
Sparty,
Good to see you're still around. Hope things are going well. Just fired mine up for the first time couple weeks ago. I remember what went into your's. Hope you can recoup a good chunk of what you spent. If I were to ask for mine what I put into it people would think I'm nuts. I must be come to think of it  ;D
Even though I've never seen or ridden your bike I'd sure as hell vouch for it.
  • Moderator
« Reply #4 on: July 26, 2012, 12:50:46 AM »
94.1bhp at 9700rpm, 55ftlb torque at 8000rpm, high 11 second quarter mile first time out. 8) 8) 8) 8) 8) 8)
The story.
Well, it was worth the shivers, but I finally made my first pass down the drag strip this evening.  It was damn cold riding home, but the warm thoughts of my run kept me going.
I went to Beaver Springs Dragway for the Friday Night Street Races.  Even though it is October, the place was packed.  I paid my $20 time trial fee and went through tech inspection.  The Hot Rod passed and I was given my number in line.  I wasn’t racing against another bike, just for time.  I was pretty nervous actually, but when the time for the run came, I was cool and collected.  I wanted to nail that light and as I was waiting in line, I watched the tree and did a mock start a few times.  I tried to visualize the start, gear changes, and line I would run.  I hoped I wouldn’t break traction or bog it off the line.  I decided to just launch the bike like I had been practicing and not try anything new or get the RPMs too high.
My turn came and I rolled to the line with a relatively cold tire.  Seems like burnouts aren’t really my thing as I tried to heat up the rear because it gained traction pretty quickly with a sideways squirt.  I staged the bike, rev’ed it to 4Ksih, the tree lit up and the next thing I knew I was out of the hole with a decent start.  9000 shift, 9500ish shift, 10000 shift, held it wide open through the trap.  I don’t remember if the front wheel “power wheelied” at all during the run, but if was smooth.  Holy cow, I can’t believe I just did that so well and the guy in the other lane was behind me!
I made my run and returned to the “pit” area to get my numbers.  I walked over to my wife, who was smiling (I was alive), and I said, “did you see that?”  “Yeah, that was loud!”, she said.  “How fast did it look?” I asked.  “Um, I don’t know, just fast and loud.  Are you going to do it again tonight?”  “No, I am freezing and I have a long ride home.” I said.
So the time slip read:
1/4 Mile ET:     11.903
1/4 Mile MPH:    118.876
1/8 Mile ET:    7.751
1/8 Mile MPH:    91.720
60 Foot ET:    1.805
Because this was a timed run the reaction time was handicapped so it didn’t matter.  I didn’t know that off the line.
I am not really sure if those are good numbers or not.  I think I could go faster if I had more runs under my belt.  I am a little mad at myself for not launching at a higher RPM and running every gear to 10000 RPM.  Best $20 I spent this year!
Sparty
A few tries latter resulted in this.
1/4 Mile ET:   11.740
1/4 Mile MPH:   120.260
1/8 Mile ET:   7.656
1/8 Mile MPH:   94.700
0-60 Foot ET:   1.895
Air temp:           79 degrees
Rider weight:      154 lbs.
In the Mike Rieck motor.
Top End Parts and Labor:
Megacycle 125-75 Cam
Megacycle Adj. Camshaft Sprocket
Kibblewhite Ti Valve spring retainers
Kibblewhite H-D racing valve spring springs and retainers
Kibblewhite bronze valve guides
EV8 Polished SS oversized intake valves 33.5mm
EV8 Polished SS exhaust valves 28mm
New OEM Honda Rocker Arms
New OEM Honda valve seals
Tsubaki H-D cam chain
M3 Racing can chain tensioner
APE H-D Top End Studs
JMR Stage 3 Head porting, polish, and mill
Serdi valve job
Head bead blasted
New OEM Honda intake manifolds + modified air fittings
New OEM Honda Intake manifold clamps
Balanced Alt. rotor and clutch basket
Cut & polish SS allen bolt head set
Bottom End Parts and Labor:
Wiesco 836cc Piston Kit
Falicon Knife Edge connecting rods with ARP premium bolts
New OEM Honda cam bearings
New OEM Rod bearings
Swain Tech piston coatings (TBC & PC-9)
APE H-D Bottom end bolt kit
JMR Cylinder decking (total squish .053)
New OEM Honda primary chain tensioner
JMR Bore and Hone cylinders (top cut .014 and recut o’ring c’bores)
APE lightened and balanced crankshaft (balanced for sustained operation to 14,000RPM)
Barnett H-D clutch springs
New OEM Honda clutch fibers and disks
FAST by GAST undercut transmission
New OEM Honda gaskets and oil seals, dowels, misc. parts
Bead blast cylinder head
Paint engine case
Polish all side covers and cam cover
New OEM Honda bolts for engine case
Rocker arm threaded adjusters
New OEM Honda cam guide
Fuel and Ignition Parts:
Keihin CR carbs 29mm
Dyna 2000 electronic ignition w/ 3 ohm coils
Dyna suppression wires
Denso Iridium plugs
K&N Oval air pods
K&N crankcase filter
« Last Edit: July 26, 2012, 03:14:13 AM by SamCR750A »
  • Moderator
« Reply #5 on: July 26, 2012, 03:15:21 AM »
Loads of pictures on Arts home page.
http://home.comcast.net/~aentz626/site/?/home/
Sam. ;)
Offline scunny
  • don't call me expert
« Reply #6 on: July 26, 2012, 03:51:54 AM »
do not sell it unless you really really have to. once sold they are hard to get back.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline sparty
    • Gallery
« Reply #7 on: July 26, 2012, 07:25:18 PM »
I posted the bike for sale locally today.  I already had 3 emails.  I did not list a price because I am still up in the air on what I would like to get.
I put together a list of what went into the build minus the body modifications (like the seat, handlebars, modern sport bike m/c, new wiring harness, turn signals, etc.)  Holy heck, I put a lot of $$$ into this bike.  See below:
-Sparty
Megacycle 125-75 Cam - $275
Megacycle Adj. Camshaft Sprocket - $40
Kibblewhite Ti Valve spring retainers - $160
Kibblewhite H-D racing valve spring springs and shims - $80
Kibblewhite bronze valve guides - $80
EV8 Polished SS oversized intake valves 33.5mm - $90
EV8 Polished SS exhaust valves 28mm - $90
New OEM Honda Rocker Arms - $340
New OEM Honda valve seals - $45
Tsubaki H-D cam chain - $40
M3 Racing can chain tensioner - $150
APE H-D Top End Studs - $80
JMR Stage 3 Head porting, polish, and mill - $450
Serdi valve job - $240
Head bead blasted – (coved in port work)
OEM Honda intake manifolds + modified air fittings - $130
New OEM Honda Intake manifold clamps - $68
Balanced Alt. rotor and clutch basket - $130
Cut & polish SS allen bolt head set - $50
Total = $2538.00
Wiesco 836cc Piston Kit - $350
Falicon Knife Edge connecting rods with ARP premium bolts - $900
New OEM Honda cam bearings - $85
New OEM Rod bearings - $60
Swain Tech piston coatings (TBC & PC-9) - $180
APE H-D Bottom end bolt kit - $90
JMR Cylinder decking (total squish .053) – (included in bore price)
New OEM Honda primary chain tensioner - $60
JMR Bore and Hone cylinders (top cut .014 and recut o’ring c’bores) - $300
APE lightened and balanced crankshaft (balanced for sustained operation to 14,000RPM) - $300
Barnett H-D clutch springs - $15
New OEM Honda clutch fibers and disks - $140
FAST by GAST undercut transmission - $325
New OEM Honda gaskets and oil seals, dowels, misc. parts - $160
Bead blast cylinder head - $20
Bead Blast & Paint engine case - $100
Polish all side covers and cam cover - $500
New OEM Honda bolts for engine case - $30
Rocker arm threaded adjusters - $40
New OEM Honda cam guide - $20
Total = $3675.00
Keihin CR carbs 29mm w/ 8 main jets up/down size - $770
OEM Carb manifolds w/ air fittings– (priced above)
Dyna 3000 electronic ignition w/ 3 ohm coils w/ Dyna suppression wires - $500
Denso Iridium plugs - free
K&N Oval air pods - $145
K&N crankcase filter - $25
Kerker 4:1 Megaphone header with comp. baffle - $820
Total = $2260.00
Suspension and Drive Train:
YSS Z- 302 Twin w/ chrome springs - $520
530 O-Ring chain - $85
JT Front sprocket 17T - $25
Progressive Suspension fork springs - $80
Total = $710.00
Grand Total = $9183.00
« Reply #8 on: July 26, 2012, 07:32:54 PM »
Keep it or most likely you'll be disappointed in the selling price.
Offline sparty
    • Gallery
« Reply #9 on: July 26, 2012, 07:58:19 PM »
I know very well that I will not get anywhere close to what I have invested, but hey I have had fun with the build and the bike - that is worth something more than money alone.
« Reply #10 on: July 26, 2012, 08:08:03 PM »
Damn straight.  ;) Still, hope you get a fair price.
« Reply #11 on: July 26, 2012, 09:51:24 PM »
 If you ride it about a hundred times, you probably get the same money for it.. but YOU get a better deal...  you may regret it...
Offline Jim F
  • go baby go
« Reply #12 on: July 27, 2012, 01:23:44 PM »
start at $7500.00 and see what you get
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
« Reply #13 on: July 27, 2012, 06:23:45 PM »
Jim
+1 and add that list you posted, anyone that knows what they are looking at will appreciate that list...
« Reply #14 on: July 27, 2012, 06:30:53 PM »
If you guys ever saw the polished cam cover you would S your pants. My good friend Alister did the cover work and he is an artist. He polished my JMC swingarm (because those guys did not even though I paid them too. I did eventually get that money back) which I just mounted. F'ng beautiful work. Welds perfectly polished but never compromised. Amazing. He was looking for some work but he does not work cheaply.
  That engine in Art's bike has a lot of love in it.
Offline sparty
    • Gallery
« Reply #15 on: July 27, 2012, 06:41:33 PM »
Mike,
Check your forum messages.
-Art
Offline sparty
    • Gallery
« Reply #16 on: July 28, 2012, 09:09:15 AM »
I listed it locally and already have had 12 emails and an offer of $6K.  I think $7k takes it home. I am confidant I can get it.  The bike will come with a lot of extra original parts, tools, manuals, etc.
-Art
Online Don R
« Reply #17 on: July 31, 2012, 08:47:17 AM »
Breaking my heart. I wish I could own it. Good luck.
Offline sparty
    • Gallery
« Reply #18 on: August 05, 2012, 07:30:19 PM »
Six people have made a trip to see the bike.  I have had four acceptable offers, but after talking to each person a bit more I have reservations selling it to someone who doesn't really know these bikes well, especially a hot rodded version.
One person wrote this to me after he visited, "Your bike is too nice for me. I mean that as a compliment. I would want to ride it daily to work and on the weekends. It deserves better than that. You have an incredible bike and I wish you luck in finding someone who will take great care of it." I feel the same way.
-Art
« Reply #19 on: August 05, 2012, 08:04:23 PM »
Agreed. It would be a shame to use your bike as a daily rider. It is far above that.
Would not want to ride it in rain or leave it parked in a lot all day.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #20 on: August 09, 2012, 06:12:34 AM »
Any buyers?
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline sparty
    • Gallery
« Reply #21 on: August 11, 2012, 12:04:11 PM »
A buch of interest, three acceptable offers.  I didn't take any of them for various reasons, mostly I want the new owner to have a knowledge and appreciation of these CBs.
-Art
Offline sparty
    • Gallery
« Reply #22 on: December 18, 2012, 02:42:37 PM »
It has been a while since I posted this initial thread.  Just for an update.  I found a buyer that I was happy with, local guy with knowledge and appreciation of these machines.  Willing to pay my asking price.  Wanted to add my bike to his collection.  Told me I could visit it on weekends - LOL.
I was ready to sell it to him and had a restless sleep the night before he was going to get it.  Decided to keep my bike, something just didn't want me to sell it.  Probably the fact that it is so damn cool and fun to ride and I would hate myself within an hour of letting it go.
When I told my wife she said, "Good, I am glad you came to your senses.  I know you love that motorcycle because you never had any of the others longer than a year or two before you sold them."  So true.  I hate to admit when my wife is right about my stupid ideas.   ;D
Now, if I can just stop treating my bike like a garage queen....
-Sparty
« Reply #23 on: December 18, 2012, 02:53:43 PM »
Welcome home Art. Guess it's time to start another one!
Offline sparty
    • Gallery
« Reply #24 on: December 18, 2012, 05:53:07 PM »
Thanks.  No more bike projects planned.  I am onto a vintage Ford truck project.  Like my bike, not going stock.  Instead a mix of pro-street and hot-rod.
-Art
