Author Topic: Anyone tried the $120 CB550 big bore kit yet?  (Read 47245 times)
Offline FastCB550
    • Classic Honda Bulletin Board
Re: Anyone tried the $120 CB550 big bore kit yet?
« Reply #100 on: September 23, 2013, 09:51:24 PM »
Just a quick update on my Big Bore Kit.
About 150 miles so far on the fresh build and she is running like a sewing machine. Just still trying to find the right jetting. I feel I'm getting a little lean from 3/4 throttle to WOT.
I'd recommend these kits to anyone looking to do this modification. You will come out cheaper on the kit (pistons, rings, wrist pins & head gasket) but have a bit more cost in machine work compared to a standard .25-1.0 step up.
1978 - CB550
600cc Overbore, Velocity Stacks, 4 into 1 Carpy Exhaust, Seat & Electronics by Kott Motorcycles, PD46C Carbs with 42 idle jets and 115 mains.
www.HondaBB.com
Offline Duke-Nukem-Dan
« Reply #101 on: September 24, 2013, 12:52:29 AM »
If you live near the central coast of Cali, the shop i mentioned is Rural Machine. Guy sounded like he knew what he was doing, said he had to have the pistons in hand before boring. So that's comforting.
Sent from my Nexus 10 using Tapatalk 4
1974 CB550k
Offline Tews19
  • I am no
« Reply #102 on: September 29, 2013, 02:35:16 PM »
I ordered my set about 2 hours ago.. I will post updates when the time comes
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
1970 Honda CB750 survivor.
« Reply #103 on: October 03, 2013, 03:47:46 PM »
For anyone that cares. My replacement ignition plate works great.  So my old martek 440 was, in fact broken. I also got my adapter for compression testing, will post my readings tomorrow.  Will also be trying my new homemade carb synchronizer, does ATF fluid work well?
1974 CB550k
Offline Tews19
  • I am no
« Reply #104 on: October 03, 2013, 05:07:01 PM »
I knew it wouldn't need to have the cylinders redone. . Congrats.
Offline KrautKoffin
« Reply #105 on: November 17, 2013, 07:50:51 PM »
Anyone else got some input? I'm pulling the trigger on this tomorrow.
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Offline FastCB550
« Reply #106 on: November 17, 2013, 09:27:35 PM »
I got about 1000 miles on mine so far and there running great.
1978 - CB550
www.HondaBB.com
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #107 on: December 03, 2013, 08:35:38 PM »
Mine just needs to have the head installed....and the whole bike put back together, but so far, so good.
I like berries.
Offline KrautKoffin
« Reply #108 on: February 15, 2014, 11:38:30 AM »
What's the total cc's on these kits with the 63mm pistons and stock stroke?
74 cb550
« Reply #109 on: February 15, 2014, 06:43:21 PM »
These are 61.5mm unless I missed something. Works out to just a tad over 600cc.
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #110 on: February 15, 2014, 07:45:18 PM »
I hate to jinx it. 200 miles and it's pretty quick (compared to normal cb550).
I have cb650 cam in it too
Offline Psychonaut
« Reply #111 on: February 16, 2014, 05:22:57 AM »
I know, old post but ATF is too thin. I used gear oil. I did a write up on making a home made sync.
« Reply #112 on: February 16, 2014, 05:31:04 AM »
It was pretty thin, and I sucked up a little into the cylinders because of that. But damn I've got those things synced really close. There was a tear in one of the Pre carb boots so after replacing it they were WAY out of sync.
Sent from my SCH-I535 using Tapatalk
1974 CB550k
« Reply #113 on: February 16, 2014, 06:40:15 AM »
I think your math is off:
PI r squared  x stroke x cylinders(4)
Over bore with 61MM = 3.14 x 30.5 x 30.5 x 50.6 x 4 = 592 (rounding up from 591.207)
the stock 550 bore is 58.5 = 544
61mm =592....but if you check the original post these pistons are 61.5mm.
Offline underachiever
  • Squandering my potential since 1989
  • 77 CB550K
« Reply #114 on: February 16, 2014, 08:06:40 AM »
Works out to 601.22.
or thereabouts.
Offline alacrity
« Reply #115 on: February 17, 2014, 07:19:47 PM »
Did a really fun 200 mile ride yesterday. It definitely FEELS like 601cc.
pdq for an old bike, that's for sure.
Offline KrautKoffin
« Reply #116 on: February 18, 2014, 05:07:29 PM »
Aren't they 3mm over, making them 61.5?
74 cb550
« Reply #117 on: February 18, 2014, 05:32:48 PM »
The overbore pistons which are the topic of the thread are 61.5mm whereas the Henry Abe kit piston is a 61mm. Either are possible overbore candidates and both leave thin liners. They are adequate. The HA kit is known for bad rings. For the HA kit, Widen the oil control ring slot and use std cb750k rings and they give a trouble free solution.
The cb500 requires a set of cb550 cylinders for the HA overbore or the HA cylinder liners are used with the stock cylinders replaced and bored.
Ensure your machinist align bores the cylinders.
« Last Edit: May 24, 2018, 11:25:56 AM by RAF122S »
Offline P.abrera
« Reply #118 on: June 24, 2014, 09:06:35 PM »
Digging up an oldie.
How do you determine correct ring end gap on the 61.5 kit?
Any associated overheating concerns with running big bore kits? Adding an oil cooler kit would help yes?
Offline Tews19
  • I am no
« Reply #119 on: June 25, 2014, 05:43:43 AM »
The kit comes with everything you need in regard to pistons. Rings and pins.
Offline P.abrera
« Reply #120 on: June 25, 2014, 06:08:47 AM »
So end gap is set already?
Offline Tews19
  • I am no
« Reply #121 on: June 25, 2014, 06:55:42 AM »
Yes. I had mine balanced when the head was done.
Offline P.abrera
« Reply #122 on: June 25, 2014, 03:43:36 PM »
Balanced? How you doin in terms of managing temps? Does it in fact run hotter?
« Reply #123 on: June 25, 2014, 05:29:40 PM »
The rule of thumb is 0.004" end gap per inch of bore. 0.010-0.012" should be good.
Offline P.abrera
« Reply #124 on: June 25, 2014, 05:37:00 PM »
Cool. Thanks!
