Author Topic: CB550 cam swap valve adjust  (Read 1207 times)
Offline stereosilence
  • 1975 CB550K
« on: September 28, 2012, 01:15:51 PM »
I swapped my cam a cb650 cam which fit fine and turned around no problems. I have the head cover back on and am trying to set valve clearances. The problem is that when I turn it to TDC mark like my manual says, the rear rocker arm has no play. At all. If I go a hair past the mark, I can get some clearance on the valve. Is this bad? I thought TDC was were the rocker arms would have the most slack.
Thanks.
Offline Bailgang
  • Scott
  • Indiana
Re: CB550 cam swap valve adjust
« Reply #1 on: September 28, 2012, 02:26:00 PM »
Dumb question but assuming your cam timing is correct are you sure you're at TDC at the end of the comp stroke and start of the power stroke?
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
  • 1975 CB550K
« Reply #2 on: September 28, 2012, 02:37:11 PM »
I was following MCRiders advice on this thread: http://forums.sohc4.net/index.php?topic=100724.msg1124369#msg1124369
However, the spot that I find IN/EX both have the most play is at the 2-3 Hash. Did I install something wrong so as to get 90 degrees out of phase?
  • 1975 CB550K
« Reply #3 on: September 28, 2012, 02:48:03 PM »
Is that what would happen if I didn't line the notch up when I installed it? I can't remember what I did but I think I was struggling to get the chain on, not align the notch.
Offline Bailgang
  • Scott
  • Indiana
« Reply #4 on: September 28, 2012, 03:19:48 PM »
It wouldn't hurt to pull the valve cover off just to dbl check the cam timing and make sure. Luckily it's a 550 rather than a 750. :)
Scott
71 cb350 twin
77 cb750 F2
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
« Reply #5 on: September 28, 2012, 03:27:21 PM »
Make sure that notch is aligned and that you're at the 1-4 T mark on the timing plate. Otherwise you'll wreck it the instant it goes on.
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
  • 1975 CB550K
« Reply #6 on: September 28, 2012, 05:28:13 PM »
Yep. That was it. the chain and everything was all off. Now it is straight and back on. One step closer to being back on the road!
Offline DustyRags
« Reply #7 on: September 28, 2012, 05:59:45 PM »
Awesome! That's how it goes- two steps forward, one step back. I'm wrapping up a month-and-a-half-long, top-end rebuild myself, and this exact thing gave me issues as well.
1976 CB550K- sold
  • 1975 CB550K
« Reply #8 on: September 28, 2012, 06:07:14 PM »
Yeah. I just need to do the valve clearance. And I lost the end cap to one of my unipods. Not sure what I'll do about that.
