Author Topic: 77-78 CB750 F2-F3 Reproduction carb boots and other Honda rubber bits!  (Read 13618 times)
Offline brandEn
Just found this site and he offers some rare hard to find Honda rubber bits including the very hard to find 1977-1978 CB750 F2 carb insulators for only $89. They are towards the bottom of the page.
http://www.claussstudios.com/id45.html
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: 77-78 CB750 F2-F3 Reproduction carb boots and other Honda rubber bits!
« Reply #1 on: October 16, 2012, 09:17:50 AM »
Ooh, and the rubber tube that connects the carb to airbox on a Dream. Nice find!
Offline brandEn
« Reply #2 on: October 16, 2012, 07:06:43 PM »
nice
Offline 750K
« Reply #3 on: October 16, 2012, 08:33:52 PM »
Anyone know if the 77-78 f carb boots are the same as the 77-78 k's? I know the part numbers are different but not sure if the boots can be used between models.
77 Cb750, 78 Kz1000
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #4 on: October 17, 2012, 07:32:43 AM »
'Anyone know if the 77-78 f carb boots are the same as the 77-78 k's? I know the part numbers are different but not sure if the boots can be used between models.'
No they are not the same, the K7/8 ones are shorter and of a slightly different profile. However they can be used on a F2/3 if you are using aftermarket filters, but will not work with the standard airbox set-up.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline brandEn
« Reply #5 on: October 31, 2012, 08:08:11 PM »
Bump for another member
« Reply #6 on: November 01, 2012, 03:05:36 AM »
A related question.  What boots to use for F2 engine and K style carburetors?
Offline madScientist
Has anyone tried these insulators? If so, what's the quality of them? Are they as good as the OEM?
I figured I'd open this thread back up instead of start a new one...
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
Offline bytio
I have ordered some and expect delivery this week, I will report back when fitted.
Offline ZanVooden
  • I don't need no stinkin' title
  • This was suppose to be a quick one month job...
Yes, I just replaced these on my 78F. They are great quality. They fit exactly as they should. Easily as good as OEM in my opinion.
Offline Foolproof
« Reply #10 on: March 28, 2013, 10:03:25 AM »
Nice to hear. I have some otw.  :)
« Reply #11 on: March 28, 2013, 10:57:32 AM »
My only question is is the material fairly stiff. I ask because I have dealt with other reproduction insulators that were to flexible and really pulsed at idle. There were vacuum leaks and if you attempted to tighten the clamps more the leaks would become worse. The insulators I used were NOT from this company that is why I ask.
Offline cb750f2Mtl
  • Honda CB750F2 1978
I have bought those , from Clauss Studio , and after 1000 km , they have melted..... Carb disconnected while riding ... ...
Sent an email the Clauss studio, will see with them.
Offline nolaw09
« Reply #13 on: February 01, 2014, 05:49:40 PM »
Hey first time posting because I tripped over this article searching for carb boot options.
I had also bought Clauss' carb boots too and the things roasted. Called him up and he basically said "yeah these thing have been a pain and I had to stop making 'em" and he gave a full refund.
Went out again to scour the web for some alternative and found that one of those CB750 supply kind of websites just started selling some... Its the only option I've seen in forever so I just placed an order. $99... we'll see how they perform. Hoping they're the answer.
http://www.vintagecb750.com/products/86/new-items
I'll try to report when I get em in.
Offline harisuluv
« Reply #14 on: February 01, 2014, 05:55:32 PM »
I was just about to say that its easy to make the form fit exactly right, it's the material they are made out of that's important.
KayOne
« Reply #15 on: February 01, 2014, 06:12:57 PM »
I purchased a set a few weeks ago from Vintage CB750.  The packaging has a small sticker indicating that they were made in Taiwan.  The castings appear to be identical to the stock isolators except the cylinder number characters are smaller.  I have never seen new Honda isolators but this set is extremely shiny.
Offline cheftuskey121
  • Super Newbie
« Reply #16 on: February 01, 2014, 06:55:31 PM »
I know it isn't much, but I've put 850 miles on my 78F with these new boots from the original link. nothing warped or roasted so far. it has been cold though, hasn't been running in the hot sun. hopefully they hold up
Offline nolaw09
« Reply #17 on: February 01, 2014, 10:55:26 PM »
On that note, would anyone know what would be a good material would be to make these out of? I would be down to replicate some new ones with a mold and make em with the correct rubber...?
Shiny kind of worries me, are they super soft? Plan on installing mine within the week when they arrive in mail
Offline jmac851
« Reply #18 on: February 02, 2014, 03:10:26 PM »
There is a Japanese company selling them on ebay for 35 dollars and 12 dollars shipping.
Offline bytio
« Reply #19 on: February 02, 2014, 03:23:32 PM »
Do you have a link to the item?
KayOne
« Reply #20 on: February 02, 2014, 05:04:12 PM »
They are at least as firm as the new boots I bought from Honda for my DOHC a couple of months ago. Who knows what thermal cycles will do to them though.
KayOne
« Reply #21 on: February 27, 2014, 08:03:42 PM »
Mocked up my F3 PD42 carbs to the K1 head today with the F2/3 boots from Vintage750. As expected, no mismatch problems to the smaller K intake spigots but no so to the carbs. Check out the area to the left and lower right to see the extent on the mismatch. All holes had similar mismatches of approximately 260 degree around the circumference.
BTW  I am planning on running the PD keyhole carbs on my 836 build for the accelerator pump option. I'm also hoping the waist shape of the Keyholes give me better throttle response down low...after reading all the anti cam threads lately. The Honda K intake clamps do a good job sealing the larger F boots to the smaller K spigots.
« Reply #22 on: February 28, 2014, 03:09:54 AM »
That looks like a pretty bad performance stopper, K1.  However, the stockers are not much better.  Rubber is easy to trim with a sharp razor and or a dremel/die grinder.  If you are familiar with the earlier round tops, I doubt you are gonna realize any gains or benefits from those pds.
Black 750K8
« Reply #23 on: February 28, 2014, 08:17:53 AM »
This is the link from the OP.
I thought they stopped selling them maybe you got them before they stopped. Or did you get them from here?
http://www.vintagecb750.com/products/73/featured-products#product-48-0757
KayOne
Update:
 I now have the bike running and only have put on less than 20 miles (spring will not come!). They seem to seal well but while I was synching the carbs I observed that the boots are so soft, that you could actually see them pulsating with each induction cycle. They are so short that I doubt that they would collapse at WOT though. They seem to hold the carbs OK so hopefully they will last.
 BTW, I also bought a set of K0-K6 isolators from Vintage CB750 and could not get them to seal with the round top carbs. The recess for the band clamp on the engine side is too far out and only captures the very edge of the spigot...$100 down the drain.
