Author Topic: first time carb cleaning issues. CB750 73  (Read 9928 times)
Offline Jinsonphoto
« on: December 30, 2012, 08:45:36 PM »
The carbs & engine are from a 73 CB750K.  The bike hasnt been sitting for years or anything, but I have had issues with getting her started since the weather has gotten cold. So I pulled carbs today for cleaning. This is the first time I have ever done this so I already have some questions & have even ran into trouble right out of the gate. I have the Honda manual which Im following along. My first question is since these carbs havent been sitting for years or anything do I really need to separate each carb if Im not going to dip them? I was hoping that i could just clean the jets & make the adjustments with the carbs together. Now the manual says to separate them, but I have heard others say keep them together.
Anyways on to my first real issue. Once i got the carbs off the first thing the manual says to do is disconnect the individual choke rod & unscrew the 6mm screws. At first I wasnt going to do this since i wanted to keep the carbs together so i went to the next step which says to remove the needle set plate to remove the needle jet from the throttle valve. Now in my manual it doesn't really explain how to do this. Do I go in through the top? Because I dont see this in the bowls? Since i couldn't find the needle set plate I went back to trying to Remove the carb from the stay plate so i could get in through the top. However when I tried to disconnect to choke i got the choke slider stuck. I don't know if Im going about it the right way to remove the choke rod. The manual is vary vague. Or Im just an idiot!
I have uploaded a picture to explain what I have done.
So looking at the picture Im guessing I should have tried unscrewing the actual choke rod itself? I hope I didn't already cause my self a lot of trouble.
Any thoughts or help would be greatly appreciated!!
Thank you in advance for your time.
Best~
Tony
Offline 736cc
Re: first time carb cleaning issues. CB750 73
« Reply #1 on: December 30, 2012, 08:51:01 PM »
Just replace the pilot jets w/ new ones (#40's are $10 a set), set the air screws to 1 1/4 turn out from bottoming, clean the inside of the bowls and you'll be most likely be ok.
« Last Edit: December 30, 2012, 08:54:05 PM by 736cc »
« Reply #2 on: December 31, 2012, 05:49:29 AM »
Don't mess with those screws you have highlighted.If you want to split and remove the carbs from the rack removed the 8 large screws from the back of the rack.Slide the carb bank out and then seperate the choke linkage arms by removing the cotter pins at the two locations and seperate .Unscrewing the large ring at the top of carb will allow you to pull the slide and needle out. Don't do more than you have to and chances are if your carbs are already pretty clean a total disassemble may not be warrented.All in all though it really is pretty simple operation either way you go.
Offline RSchaefer
« Reply #3 on: December 31, 2012, 07:05:54 AM »
Removing the carbs from the rack w/large 8 Phillips screws and the choke linkage will not effect the sync.  Pulling them apart is the best way to work on them.  I took a scribe and marked each one with its # as you want to put them back in the same position.  You said something about the Needle Set Plate, not sure what that is.  You just unscrew the top collar and the slider w/needle comes out the top.  The choke plate for #1 is just stuck probably due to some twisting in the linkage.  Take apart the linkage from all four carbs and you should be able to move that stuck choke plate back.
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
« Reply #4 on: December 31, 2012, 07:42:37 AM »
"but I have had issues with getting her started since the weather has gotten cold."
Could it be the spark plugs are the issues and not the carbs? Why do you think its the carbs? Did the bike run well in summer? You could also try running the bike minus the external fuel filter.
Offline thedrewski86
« Reply #5 on: December 31, 2012, 07:54:18 AM »
Everyone else here is right, you really don't have to break the bank apart to do what you need to do. You can without affecting the sync but it's not necessary. Soaking in carb cleaner is great but it may not be necessary. If the o-rings don't leak you really don't need to replace them (unless you have spares hanging around). Take some stranded copper wire to your jets if you don't replace them, that's a real easy way to clean them out.
Good luck, if you really want to take them apart it's a great way to learn! Carbs are really simple.
1975 CB 550k
1990 CBR1000f
1995 VT1100C2 (sold!)
2009 Ninja 250 (wife's)
1994 Toyota 4x4 22RE 5 speed
Offline lucky
« Reply #6 on: December 31, 2012, 08:03:29 AM »
Don't you mean new float needles?
There would be no reason to replace a pilot jet which has no moving parts.
Offline 736cc
« Reply #7 on: December 31, 2012, 08:37:52 AM »
  If that #4 choke butterfly is stuck in closed position , it slipped off the arm inside the carb body and is a pita to re-install. You have to gently sneak it onto the retaining pin attached to the choke linkage. Carb top needs to come off unless you can poke in there w/ a skinny tool. Been there, done that on the earlier 4 cable carbs which have different carb tops and mechanisms. I am not exactly sure how your later carbs and the choke differ. Anybody?
  Pilots ALWAYS get clogged from dried-up fuel varnish if sitting improperly stored, or if never been replaced since 1973 or so. My experiance w/ these little buggers is if you go to the trouble of removing them, simply replace them, NOT clean them. You can soak them and poke holes w/ wires in the orifices and get them what you think is cleaner (but not really) and at $10 a set for new they'll be guaranteed 100% ready to go.
  New plugs ALWAYS make starts alot easier, too. Add some Startron in a fresh tank of gas, that stuff WORKS!
  Ahhh, new jets and spark plugs in an old CB750, such a wonderful thang.
« Last Edit: December 31, 2012, 08:45:32 AM by 736cc »
Offline XLerate
« Reply #8 on: December 31, 2012, 09:53:49 AM »
I've done an awful lot of carb cleaning on small engines and bikes, many hundreds and probably well over a thousand. I'd very strongly suggest that you don't use copper wire to clean orifices. It fatiques and breaks very easily. It can break off flush in a hole, then no way to grab it, plus the part where wire broke is all gnarled up, fatter, bent etc. Then you're stuck with trying to drill it out without doing major damage on your carb.
Over the years I've collected a set of various size hard wires I use for this or you can order a set of jet cleaning wires online, pretty cheap. Just be gentle when using them and don't ream out a jet or passageway, the aluminum is quite hard and won't easily get damaged. If you make up your own hard wires run the tips across some fine emery to smooth and slightly round them in case there's a jagged edge that could gouge the aluminum. If you do that it's pretty difficult to do any damage with them.
Offline Jinsonphoto
« Reply #9 on: December 31, 2012, 10:10:14 AM »
Wow thanks for all of the info! I wish I would have just gotten on here first when I couldn't figure out how to undo the choke linkage. Since I unscrewes the wrong screw & caused the #4 choke butterfly to slip off the linkage I guess I have no choice now but to pull the whole thing apart. - I wish the manual would have just stated to pull the cotter pin off the choke linkage arm to remove it! I hope I will be able to get the choke butterfly back on the arm!
Offline Jinsonphoto
« Reply #10 on: December 31, 2012, 10:16:56 AM »
Yes i tried changing the spark plugs. The reason i decided to pull & clean the carbs was because the petcock was leaking & when I put my finger under it I got this amber colored gas on my finger. So it seamed there was maybe rusty gas in the bottom of my tank.
Although I didnt try running the bike without the external fuel filter. Pardon my ignorance, but what wold this have shown me?
Offline Jinsonphoto
« Reply #11 on: December 31, 2012, 10:18:49 AM »
Wouldnt I have to remove the carb from the set plate to take off the top to get to the needle?
Offline Jinsonphoto
« Reply #12 on: December 31, 2012, 10:24:08 AM »
One more question. Instead of buying new jets or cleaning them with wire. Couldn't I just soak the jets alone in carb cleaner & then blow them out with a compressor?
Offline XLerate
« Reply #13 on: December 31, 2012, 11:13:23 AM »
I never had any luck at all with soaking and compressed air. The problem over time is a shellac or similar buildup that needs mechanical manipulation to move it. Only thing that's ever worked for me is jet cleaning wires, used sensibly with plenty of carb cleaner spray like Berryman's etc. Pretty much the same as washing your hands after working on the bike. You don't set a bar of soap in the palm of your hand, run some water on your hands and call it good: friction/manipulation is needed.
Offline Jinsonphoto
« Reply #14 on: December 31, 2012, 12:09:52 PM »
Do most part stores sell carb cleaning wires? Or are they a special order item. Is there anything else that works good to get down in the jets?
« Reply #15 on: December 31, 2012, 12:13:01 PM »
It would have shown you if the fuel filter was blocked and causing a shortage of gas to the carbs. However this may have been expected to occur in all temperature ranges. But it could have been a progressive thing - your filter in the photo looks quite orange so maybe a cleaning of the fuel tank is also in order. At the very least change the fuel filter or clean it.
Btw what were your symptoms of not running correctly?
Good luck!
Offline Jinsonphoto
« Reply #16 on: December 31, 2012, 12:25:52 PM »
Thanks!
& yeah when it was running it wasn't running good. If i pulled back the throttle quickly it would skip. But mostly It just got harder & harder to start until I couldn't get here to start. And like you said I started to see the amber color in the in-line fuel filter. Im putting a new tank on her anyways. Although I have to get the rust of out of the new tank first! ;)
Im going to try the electrolysis method.
Offline RSchaefer
« Reply #17 on: December 31, 2012, 01:40:10 PM »
OK looking through the micro fiche again I see that Honda calls, what I have been calling the rack, the set plate.  Basically the two large countersunk Phillips screws holding each carb to the set plate.  Yes you would have to removed the carbs from the set plate too unscrew the top collar and remove the slide and needle.
For cleaning the jets Hondaman recommended a pin vise which I picked up at the local arts & crafts store for $9.  The pin vise looks like say an ink pen and has an assortment of various size mini drills under its end cap.  You unscrew the tip of the pin vise, like a Jacobs chuck, and tighten in your desired drill.  I started with a small drill and worked my way up until I felt a little resistance as I worked it back and forth.  You can increase the size of these holes if desired.  Hondaman had suggested increasing the diameter of the 8 holes at the top of the emulsifier tub to around .037".  The openings at the top of the emulsifier were larger on the early Honda's and got smaller over time due to EPA restrictions.  You really only need the carb wire for the one air jet in the main throat that runs back to the needle valve seat.
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline 736cc
« Reply #18 on: December 31, 2012, 03:11:38 PM »
S'more cold-start gremlins:
-Pertcocks passages get clogged, sometimes only 2 carbs get fuel; dissassemble and poke around and blow in it (tastes awful)
-Sticky float; hit/tap carb bowl w/ a hammer (it worked for me more than once)
-Bad coil; start bike in darkened garage and watch for fireworks arcing from petrified cracked plug wires/boots; (I've seen it)
-Clogged pilot jets (replace, don't clean, spend $9.95 + postage)
-Remove mouse nests and piles of acorns from airbox (maybe it was a squierrel?)
-Remove mouse nests from open HM300/341 pipes (preferably by suprise when it starts-up)
-Crummy stale fuel mixed w/ water/rust/varnish (keep a clean, spare tank around)
-Points not grounded (wiggle/tighten every possible connectio)
Offline Jinsonphoto
« Reply #19 on: December 31, 2012, 07:05:34 PM »
Wow thanks for the great info! A question tho.. What exactly is the Hondaman you are referring to? I have the CB750 manual I downloaded here, but Im guessing thats not what your referring to?
Offline Jinsonphoto
« Reply #20 on: December 31, 2012, 07:12:40 PM »
736cc Thanks for taking the time to share this with me! This will great to refer back to. In fact i already know now that i have a float sticking & my petcock has been leaking so maybe its clogging in passages as well.
Either way with all of this great info Im bound to get to the bottom off it! Ill be sure to report back if i get into trouble.
Offline RSchaefer
« Reply #21 on: December 31, 2012, 08:17:56 PM »
Dude, Hondaman is the Man!!  Hondaman worked in a Honda shop circa late '60's to mid/late '70's and documented every change/issue w/CB750.  He sells a book which IMHO is a mandatory accessory to any CB750 rebuild/restoration.  I think he offers a discount to forum members.  His name is Mark Paris and he lives in the Denver area.  He also has a web site and offers some rebuilds, he did my swingarm, electronic ignitions, updated fuse boxes, etc.  I think if you do a search on Hondaman and his book in particular you will find a thousand threads.
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline Jinsonphoto
« Reply #22 on: December 31, 2012, 08:54:37 PM »
Thanks for the info! I guess I better get the book then. Im at the beginning of going over my cb750. And since I have no experience this might be just what I need. As I said earlier, the shop manual is pretty vague at times. It tells you what to do, but not always how!
Online Stev-o
« Reply #23 on: January 01, 2013, 10:09:46 AM »
Hondamans website and book.  The book can also be found on lulu.com and frequent discounts are offered.
http://sohc4shop.com/catalog/product_info.php?products_id=30
Offline Jinsonphoto
« Reply #24 on: January 01, 2013, 11:00:26 AM »
I have one more question this a bit off topic, but still has to do with this subject. I'm going to do electrolysis on my new tank & I'm curious after i get all the rust removed do I need to coat the tank with anything or just get it filled with gas asap?
