Author Topic: Will the early model (pre '74 CB750) brake rotors fit a '78 CB750K?  (Read 1856 times)
Offline hevykevy420
Eldar- do you know the answer regarding brake rotor interchangeability?  Buying parts to set up a dual caliper set up...
1978 CB750K - 836 Wiseco kit, 4-1 Kerker Exhaust, Web cam (63b grind), HD valve springs, polished stuff.  Comfortable.
1975 BMW R90/6 - tight
2002 RC51 - Jardine slip ons.  Uncomfortable.
Austin, TX
eldar
Re: Will the early model (pre '74 CB750) brake rotors fit a '78 CB750K?
« Reply #1 on: July 14, 2006, 01:47:58 PM »
Well I have not done it myself but I am inclined to think they are the same for all the k models or at least k1 - k8. F models are different though.
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #2 on: July 14, 2006, 03:39:34 PM »
Watch out some are 5 bolt others are 6. And try to get them with the bolts that came with them, there is a size issue. but that is always the case. HEEHHEHEHEHEEHEH!
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Online bryanj
« Reply #3 on: July 15, 2006, 03:58:15 AM »
F2, F3 and anything with comstars is different!
Offline hevykevy420
« Reply #4 on: July 17, 2006, 07:41:54 AM »
THANKS ALL!!   :) :)
Austin, TX
Offline Clyde
« Reply #5 on: July 17, 2006, 09:18:37 PM »
Just to be clear 75F and 76F1 will also fit.
Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
eldar
« Reply #6 on: July 18, 2006, 08:27:03 PM »
I prefer to not mention the f rotors as so many ebay seller label them wrong and unless you know EXACTLY what your part looks like, you could get stuck with a rotor that does not work. If you stick with the K designation, then you are ok in most areas.
Offline hevykevy420
« Reply #7 on: July 20, 2006, 09:13:13 AM »
So very true Eldar...the naked eye seems to be the best test, and also asking on this forum!!!!
Austin, TX
