Author Topic: Big Brakes wire wheel for Cb750F forks.  (Read 1789 times)
« on: January 22, 2013, 03:04:58 PM »
Doing these up for a member. I think they are VFR or VTR,he will mention it later. Only one rotor in oic, there will be two, they are 295 mm.
Re: Big Brakes wire wheel for Cb750F forks.
« Reply #1 on: January 22, 2013, 03:06:37 PM »
Nice Frank...
« Reply #2 on: January 22, 2013, 03:08:38 PM »
 Another pic
Offline bert96
  • past ride
« Reply #3 on: January 22, 2013, 03:52:24 PM »
 VFR Frank....Very niiicce job!
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #4 on: January 22, 2013, 04:55:42 PM »
Those look great Frank.
Are you planning on making an upgrade kit?
« Reply #5 on: January 22, 2013, 08:53:14 PM »
 Those are for Bert, his idea, but I know that folks have asked about wire wheels on those forks..so I made a second set
Online scottly
« Reply #6 on: January 22, 2013, 08:58:43 PM »
What size pistons are in the calipers? 27mm?
Offline andrewk
  • doin' it.
« Reply #7 on: January 23, 2013, 02:13:32 AM »
Nice work Frank.  Did you do both the rotors and the caliper mount?
Think there's enough room on the rotor to lay out a 5 hole pattern for comstars? :P  I know nobody messes with 'em, but I've got a pair I'm using, and if that's an option, big brakes sure sound better than sourcing late DOHC calipers and brackets...
« Reply #8 on: January 23, 2013, 04:53:52 AM »
Looks good frank. Those F2 forks are much easier to work with than the earlier K and F pieces
« Reply #9 on: January 23, 2013, 07:02:05 AM »
 Thanks guys, the rotor came with the correct 6 hole in it from Bert. I think going 5 hole on existing 6 hole generally does not work unless the 5, is much smaller bolt circle. Many were asking about switching to wire wheels, plenty of 6 bolt ones around.
 I tucked them in close, much harder to hold the pces then, to finish machining, but they look better in close..
Offline Scott S
« Reply #10 on: January 25, 2013, 08:24:03 AM »
 What would it take to run a Brembo caliper on a stock CB550 fork/disc? I have a RH caliper from an XS650 kit I never installed. I wonder if you could make a bracket to make it work on the 550?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #11 on: January 25, 2013, 09:17:35 PM »
 The forks with the swinging brackets, are tougher to put different calipers on, The F style shown, or any fork legs with solid mounting ears are a bit easier to change calipers on.
