Author Topic: Cams,tensioners,cam chains,cam sprockets  (Read 2877 times)
Offline Bill/BentON Racing
    • BentON Racing
« on: January 31, 2013, 05:32:16 PM »
Been digging in batcave! ;) ;D Thought we could start a topic on cams,tensioners etc. What was original,mods for CR's,early aftermarket,what's available now? For instance,slotted cam sprockets,early RC not slotted,but had 5 & 8? degree alternative holes,Jay,APE sells a nice slotted one Heres a pic of stock
RC
APE's
Now heres a few used/new cams for CB750's! ;D
A stock tensioner.what wear? ::)
A modified assembly,both wheels different? Who made?
A KOS style M3 Racing,but I believe a copy
Also H/D cam chain
Stocker
Another way of replacing,without splitting cases.......beware!
Stock early K sprocket,later F style,I believe.
Stocker slotted by owner?
We also have stock tensioner adjuster and fixed like APE sells! No pic rt now. Bill
BentON Racing Website
BentON Racing Facebook
Re: Cams,tensioners,cam chains,cam sprockets
« Reply #1 on: February 01, 2013, 05:57:58 AM »
That "home made" slotted sprocket looks a little rough Bill. ;D ;D ;D
Offline Jim F
  • go baby go
« Reply #2 on: February 01, 2013, 12:06:26 PM »
I slotted my own but used a rotatory table and a Bridgeport mill
the material is tough to mill though.
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
  • Moderator
« Reply #3 on: February 01, 2013, 02:21:32 PM »
I had one of those so called "ROUGH ones"  :-[ just took a small round file to it till it was right, worked a treat.  ;D ;D ;D ;D ;D ;D ;D
Sam. ;) ;D ::)
« Reply #4 on: February 01, 2013, 04:06:53 PM »
 I think the solid roller one is a yoshi, got one here somewhere.. Bill is the Camfather..lol
Offline Big Jay
    • CBRzone
« Reply #5 on: February 02, 2013, 02:05:21 PM »
I'say!! :) :)
    • BentON Racing
« Reply #6 on: February 02, 2013, 04:38:52 PM »
Coming from two of the best machinists around...I agree.heres more!!These real rough!Material is tough as previous owners found out!! ::)I will admit my first attempt on 590 roadracer wasn't a whole lot better!!! ;) ;D
All came out of bikes or parts picked up! ;D Bill
« Reply #7 on: February 03, 2013, 06:12:15 AM »
I'm no real machinist Bill. I certainly know some. ;D ;D
Offline spiritof67
« Reply #8 on: February 04, 2013, 02:22:18 PM »
Yes, but back to the original thread which really needs some talking about.....
So I'll posit un tesis: The M3 full replacement is the safest high performance setup currently available.
Contention?
Spirit
    • BentON Racing
« Reply #9 on: February 04, 2013, 02:58:22 PM »
I was wondering about the Yosh, did it also sling oil off high rpms? The rest of it sure looks better than oem! Didn't people adapt sprocket from CB 450's?  I believe the one in Samauto is Mark's. But I thought there was one or two out similar design? Anyone know for sure? Bill
Offline cbr954
« Reply #10 on: February 04, 2013, 04:37:39 PM »
I am running the tensioner from Cycle X but its the same thing as the M3 setup, sure looks like it should be easier on the chain.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
    • BentON Racing
« Reply #11 on: February 04, 2013, 05:26:39 PM »
Aha, one in Samauto probably from CycleX, I'd venture to say. ;) ;D Bill
« Reply #12 on: February 04, 2013, 06:37:03 PM »
Is the CycleX version a KA Performance part also?
Offline cbr954
« Reply #13 on: February 05, 2013, 06:30:17 AM »
Yes mine had KA Performance on the side of it.
  • Moderator
« Reply #14 on: February 05, 2013, 08:19:31 AM »
I'm no real machinist Bill.  ;D ;D
but I'm $hit hot with a Rollex  ;D ;D ;D ;D ;D ;D
Offline Kickstart
« Reply #15 on: February 10, 2013, 07:50:24 PM »
Does anyone know if the APE adjustable sprocket is balanced weight wise?  It appears that it might be.
Also, does anyone know which weighs less, the Dynoman or APE adjustable sprocket?  Neither one looks lighter than the stock F's.  But I need an adjustable sprocket and I don't think the F's has enough room to slot it.
- Chris
75' CB750F Blue (Project)
No Reserve Racing #171 AHRMA
« Reply #16 on: February 10, 2013, 08:13:38 PM »
You selling any of these parts Bill ?, if yes, and you haven't sent my parts off yet i would like that M3 style tensioner and HIPO cam chain please {if the chain is unused} , if no, just ignore this.... ;D ;D ;)
Offline sohc boy
« Reply #17 on: February 11, 2013, 02:13:47 AM »
second  pic is multi adjust ,which i purchased long ago ,blueish colour like been hardened  dont know made it ?,first one slotted , purchased not rat tail filed ,hard to see in pic , it has been wiggling arond where bolts tighten on it , ..... sprocket is quite soft , i personally dont like the slotted , maybe APE ones are hardened , dont know
« Last Edit: February 11, 2013, 03:45:27 AM by sohc boy »
i live by the voice inside my head
    • BentON Racing
« Reply #18 on: February 11, 2013, 03:47:19 AM »
Lower one looks RC upper late model F that was slotted, I believe.Bill
Retro, Ill  PM in a hour or so. Thanks Bill
Offline lordmoonpie
    • Moonpie
« Reply #19 on: February 11, 2013, 04:31:09 AM »
I've got a bit of a mix of these - KA Special slipper tensioner different to M3 as I'm running a hy-vo camchain from my DOHC crank so the runners on the slipper are at the edge and not at the centre. The cam sprocket is a custom made job created by mixing a slotted race CB750 sprocket with a CB700 hy-vo sprocket, end result being fully adjustable hy-vo sprocket! The front camchain slipper blade is also custom made using a CB250 tensioner arm that is then cut down to fit the CB750 SOHC tunnel. The combination of all of these seems to offer less cam chain turning resistance than using a high performance chain and slipper tensioner on my CB350 or 500 twins
It all works real nice :D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
