Author Topic: There is a God......and I believe, whole heartedly.  (Read 3065 times)
Offline WhyNot2
  • I'm finally an
« on: February 06, 2013, 02:27:34 PM »
I ride the 750 to work this morning...........no problems.
Go out, at 3:30 pm to go home. Fire it up, pull out, got to stop at the end of the row.....no rear brake.
Damn......use front brake that squeals like hell.........stopped.....whewwww.
The hardware that connects the brake rod to the brake pedal is missing.
Geeeeeezz......wtf.........rode it home on the back roads......made it.....otherwise, I wouldn't be typing this right now.
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: There is a God......and I believe, whole heartedly.
« Reply #1 on: February 06, 2013, 02:31:12 PM »
Worth checking on that pre-ride walk around.
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
« Reply #2 on: February 06, 2013, 03:48:20 PM »
Glad you're still here!
Remember your basic rider course? Squeeze- push. Step- pull. Check, and check. Off you go. :)
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
Offline Johnie
« Reply #3 on: February 06, 2013, 04:02:39 PM »
Sounds like someone was pulling a cruel joke. Do you have enemies at work? With the 750 it is pretty much impossible for that bolt to unscrew itself on that rear brake system at the hub.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline WhyNot2
  • I'm finally an
« Reply #4 on: February 06, 2013, 04:32:31 PM »
It wasn't the one at the hub, it was the on that connects to the brake pedal itself under the swing arm pivot.
Got enemies.....none smart enuf to do something like that.
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #5 on: February 06, 2013, 06:49:27 PM »
weenie little cotter pin let go?
searching for a dr350se
Offline Johnie
« Reply #6 on: February 06, 2013, 09:35:16 PM »
Gottcha...that little pin let go. Those are buggers to get back on too.
Oshkosh, WI  USA
Offline Viktor.J
  • Breaking in the forum
« Reply #7 on: February 07, 2013, 03:26:13 AM »
Why do you use the rear brake in the first place ?  :-*
I don't mean you don't need a rear brake, but if using the 80/20 rule there should not be much problem.
glad everything worked out for you !
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
« Reply #8 on: February 07, 2013, 03:46:53 AM »
Glad you safe, man!
Offline WhyNot2
  • I'm finally an
« Reply #9 on: February 07, 2013, 03:54:07 AM »
Thanks everyone........I do the 80/20.
My front brake squeals like the dickens, so I tend to squeeze it lightly and apply the rear slightly at the same time.
I do a walk around.............just never really thought to check that.
Mind you....it will be from here on out.
Now I just have to find something to put in there.
Offline WhyNot2
  • I'm finally an
« Reply #10 on: February 20, 2013, 05:48:52 PM »
Man.....this is an understatement........finally got that little bugger in.......................whew, took some doing.
But, back on the road again.
Offline 736cc
« Reply #11 on: February 20, 2013, 07:28:14 PM »
When was the last time you removed your rear wheel? Or did somebody else work on your bike?
Offline WhyNot2
  • I'm finally an
« Reply #12 on: February 21, 2013, 01:36:52 AM »
The last time was back in december when I installed swing arm bushings, I just never figured looking at that pin.
As I was installing the new pin, the one that I thought fell off the bike fell out from somewhere. The little cotter pin is still in it but both ends have been broken off.
« Reply #13 on: March 16, 2013, 08:36:40 PM »
bumpa.
am in the middle of a full refresh on my cb350f and tonight i was installing all the rear brake hardware, including the brake stay and brake rod.  on disassembly i noted the brake rod connector pin can't be removed (or installed) unless the shocks are disconnected and the swingarm is raised fully and the tire contacts the underside of the frame.  the cotter pin hole is on the outside, opposite the swingarm.
this means that when installed properly, the brake rod connector pin is trapped and can't back out even if the cotter pin fails.  this designed-in safety feature makes sense to me, and thought i'd pass it along.  might be cb350f only, no idea.  might be worth a look tho.
Offline WhyNot2
  • I'm finally an
« Reply #14 on: March 17, 2013, 08:32:24 AM »
bumpa.
Hey, thanks man...................not sure it's that way on the 750.
I was able to install the pin and another cotter pin, just a bear to do.
Did not have to remove anything.
I do have a 350f too, I'll check that one out now, as soon as I get back from Daytona....................
Offline phil71
« Reply #15 on: March 17, 2013, 11:18:10 AM »
I'm confused. Are you saying God took the cotter pin out?
« Reply #16 on: March 17, 2013, 12:00:14 PM »
God saved him from becoming a greasy bloody spot by having the problem appear before the ride and speed commenced...
Offline WhyNot2
  • I'm finally an
« Reply #17 on: March 17, 2013, 07:44:29 PM »
EXXXXXActly!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
