Author Topic: What Plugs To Use With Dyna-S System?  (Read 9184 times)
supersport_CB400F
« on: July 29, 2006, 10:03:30 AM »
What plugs work best with the Dyna electronic ignition and coils with copper wires?...any suggestions would be helpful…cheers
Offline cbjunkie
  • ...know what i'm sayin'?
Re: What Plugs To Use With Dyna-S System?
« Reply #1 on: July 29, 2006, 10:23:50 AM »
good question. i just completed the DynaS swap out - coils and ignition - but did not think it was necessary  to change plugs out...?
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
« Reply #2 on: July 29, 2006, 10:31:10 AM »
You'd use the same heat range plugs.  If you use 5 ohm coils use the stock gap.  3 ohm coils can use an increased gap.  Increase by about 0.005 inch.
« Reply #3 on: July 29, 2006, 10:38:35 AM »
Iridiums are very nice but expensive.
supersport_CB400F
« Reply #4 on: July 29, 2006, 12:34:25 PM »
#$%* they are :o I've not got a race engine so I'm going for stock plugs  NGK DR8ESL with a bigger gap or should I use another temp plug 3Ω Dyna coil?.......cheers
Offline jbailey
« Reply #5 on: July 29, 2006, 06:50:11 PM »
I got NGK iridiums for about $8 each.  That's $32 for 4, so it's up to you if it's worth the money.  They are cheaper than Denso iridiums.  Would I buy them again?  Probably not.  I would probably go for platinums since they are usually about $2 each and not much more than standard plugs.  I use them in all my cars.  I'm not sure if they are available for our old bikes.  The NGK website only shows standard and iridium.
1975 Honda CB550K
2005 Kawasaki ZG1000 Concours
« Reply #6 on: July 29, 2006, 09:01:23 PM »
The DR8ESL should be fine. If you have resistor caps, use the D8ESL instead.
Or, use the Denso X24ES-U, if you can find them.
I used the following plugs on my K2 over the years (resistor caps) under all sorts of conditions:
Cold weather/short-haul/strictly city riding: D7ES, X22ES-U
Mixed hiway/city, summertime driving: D8ES-L, X24ES-U.
Long-distance touring: D8ES, X24ES.
Racing: D9ES, (no longer available, D10ES often too cold), X27ES-U.
I am just venturing into the Dyna III myself. The higher voltage and wider plug gaps should help keep the plugs cleaner longer and idle better. Hopefully, better enough to allow a little richer mixture, which increases midrange torque considerably on the CB750.
« Reply #7 on: July 29, 2006, 09:19:55 PM »
If people stepped into the 90's and got digital ignitions you'd see what I mean (with Iridiums). ;)
supersport_CB400F
« Reply #8 on: July 30, 2006, 10:35:21 AM »
They're about £13 each in the UK, standard are about £3 :o
supersport_CB400F
« Reply #9 on: July 30, 2006, 10:47:54 AM »
Junkie, did you get the Dyna leads? If you did have they got resistor plug caps I never seen anything in the blurb….cheers
Offline cbjunkie
« Reply #10 on: July 30, 2006, 10:54:13 AM »
yeah - i got the solid copper wires that Jeff recommended to me (jeff from z1)
the best thing about buying these wires is the connection to the coils - they are literally made for each other with a special clip and waterproofing boot that is very secure and goes together with a satisfying sucking click sound - no need for messy silicon sealer and all that hassle.
i'm using the NGK D8ES which is what i had on before
i do not believe that these have resistor caps...
http://www.z1enterprises.com/detail.aspx?ID=209
1971 750K1
the free men.
supersport_CB400F
« Reply #11 on: July 30, 2006, 10:59:13 AM »
That's who I've ordered from.....but I'm not sure if they have resistor plug caps they must have if you use D8'S I have resistor caps on my old coils and used those...cheers
Offline cbjunkie
« Reply #12 on: July 30, 2006, 11:00:57 AM »
sorry i'm not of more help - i'm afraid i'm not much of an electrician...in this case i just did what the knowledgeable told me to do...  :-[
1971 750K1
the free men.
supersport_CB400F
« Reply #13 on: July 30, 2006, 11:08:42 AM »
No worries Junkie, I’ll find out when they arrive  ;)
Offline jbailey
« Reply #14 on: July 30, 2006, 04:34:09 PM »
I've got a Dyna S.  Is that what you mean by digital?  What do you mean with Iridiums?
1975 Honda CB550K
« Reply #15 on: July 30, 2006, 06:39:56 PM »
If people stepped into the 90S and got digital ignitions you'd see what I mean (with Iridium's).
I've got a Dyna S.  Is that what you mean by digital?  What do you mean with Iridium's?
A Dyna 2000 is digital. The ignition maps are handled electronically....no mechanical advance with their inherit limitations. I sent samcr750 a set of Iridium's for short money...even with postage. He says they work great in their drag CR.
eldar
« Reply #16 on: July 31, 2006, 07:05:04 AM »
The iridium is a high end plug. It has a smaller center electrode and has many other improvements over standard plugs and even platinum plugs, not to mention long life. On a stock bike, they can even take advantage of your weak coil ignition as they are more efficient at making a spark. they also have allowed racers to increase their CR and rpms on their race engines. There are things all over the net about them. Aside from cost, I dont know if they really have any current short comings.
Hondaman, I cant run slightly rich, makes my midrange bog out. Course I run a K8 and have an accel pump. that is probably where the difference comes in.
78CB750F1
« Reply #17 on: July 31, 2006, 08:47:31 AM »
With Dyna coils and wires, is the NGK Iridium DR8EIX the right plug?
RSV12K
« Reply #18 on: July 31, 2006, 09:13:49 AM »
I have Dyna coils/ignition and Accel graphite wires and I use DPR8EIX-9, which must be the same thing.
I don't recall the reason, but I have it in the back of my head those spark plugs did not come with the nipples on top, yet that was what the Accel connectors called for. It's been a while, but to be safe, check. I had to chase them down separately, but my memory is crappy.
supersport_CB400F
« Reply #19 on: July 31, 2006, 09:44:03 AM »
I'm using the copper wires do your graphite wires have resistance plug caps?
supersport_CB400F
« Reply #20 on: July 31, 2006, 09:45:59 AM »
What wires did you use? and what coilsl 3 or 5Ω... cheers
78CB750F1
« Reply #21 on: July 31, 2006, 09:58:53 AM »
I'm using the Dyna S ignition with 3.0 ohm coils and Dyna DW800 graphite suppression core wires.
supersport_CB400F
« Reply #22 on: July 31, 2006, 10:35:26 AM »
So your plug caps are non resistance type? I'm guessing those plugs are given the DR in the # of the plug is that correct.
I'm using the copper core wire but the information on the plug cap so I cant order the plugs in advance it's not a problem when they arrive I'll measure the resistance and get the plugs required...cheers
Hop on a Honda
« Reply #23 on: July 31, 2006, 03:55:06 PM »
I have had NGK  IRIDIUMS in my K5 for 18months and never tiughed them at all Goes first pop and goes hard Reccomend them.I also expext that there a leveler/ compensation for #$%* fuel so to speak
Dave
Offline cben750f0
« Reply #24 on: July 31, 2006, 05:53:09 PM »
i bought a set of iridiums for my CBRF4i(they wont run anything else), and it costs $100 AUD!!!, i have a dyna and just runnin the D8ES... seems ok....peace  BTW the NGK's for the CB cost $12 AUD...big difference
