SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
exhaust gasket
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: exhaust gasket (Read 1544 times)
Jasondo
Full Member
exhaust gasket
on:
May 20, 2013, 08:57:59 AM »
Im searching around for a muffler for my 400 but finding that most will not fit with the exhaust gasket installed on the header. With the gasket it measures around 1.9" but most mufflers with reducer kits allow up to 1.75" only . Can I run a muffler without the gasket? Is there a thinner gasket option?? how do I cut the old gasket off without messing up the header...dremel tool with cutoff wheel??
thanks!!
Logged
bjbuchanan
Master
Re: exhaust gasket
Reply #1 on:
May 20, 2013, 09:49:15 AM »
I think you are talking about the collector area for a 4-1? If so a 2" ID (important part) should be just fine there. Close fit and the fact it is outside not in the pipe will reduce leakage greatly. I hope this helps because I'm not really sure what exactly we are talking about
Logged
Jasondo
Full Member
Re: exhaust gasket
Reply #2 on:
May 20, 2013, 11:09:19 AM »
Yes the collector at the end of the header where the muffler mounts. There is a gasket that measures 1.9" and prevents me from using a majority of aftermarket mufflers. My question was can I remove this and still be ok without it or use a thinner gasket material.
Logged
.RJ
Hot Shot
homebase in your airspace
Re: exhaust gasket
Reply #3 on:
April 04, 2019, 05:29:54 PM »
I'm dredging this to the top - I've got a replacement muffler & gasket from david silver spares, and struggling with the best way to remove the old collector gasket - seems to be pretty well fused onto the collector...
Logged
Madison Motorsports
03 GTI
71 CB750
71 CB350
hsas.69
Enthusiast
Re: exhaust gasket
Reply #4 on:
April 06, 2019, 04:07:04 PM »
Have pictures? Not exactly sure what your calling a gasket.
Sent from my LG-LS993 using Tapatalk
Logged
78 CB750 F3
78 CB550 K4
bryanj
Really Old Timer ...
CB500 Number 1000036
Re: exhaust gasket
Reply #5 on:
April 07, 2019, 12:02:56 AM »
If you do get it off they are rarely reusable. It is a tube of grey heat resistant material probably about2 inch long and 1/8 inch thick that slides onto the collector(when new) and the muffler slides over. If we ever ordered new collector or new muffler we always ordered new gasket as well!!
Logged
.RJ
Hot Shot
Re: exhaust gasket
Reply #6 on:
April 08, 2019, 06:40:12 PM »
I have a new one ready to go. Seems like the old one is melted to the collector and it was leaking before, I can chip away pieces of it but it was slow going and thought there had to be a better way.
Logged
Madison Motorsports
03 GTI
71 CB750
71 CB350
Gurp
I'm no.......
Master
Once was a...
Re: exhaust gasket
Reply #7 on:
April 09, 2019, 07:40:54 AM »
Take it the header and hit it with a stiff wire wheel or a flap wheel.
Logged
slow Progress
74 cb550.
Poor boy chop
73 CB500 chop
"Alley Cat" 93 sportster
.RJ
Hot Shot
Re: exhaust gasket
Reply #8 on:
April 13, 2019, 08:35:57 PM »
This is the offending gasket - I'll give the wire wheel a shot tomorrow
Logged
Madison Motorsports
03 GTI
71 CB750
71 CB350
.RJ
Hot Shot
Re: exhaust gasket
Reply #9 on:
April 15, 2019, 03:51:55 PM »
The wire wheel was the trick, it gave me enough of a lip on the edge to get under it with a screwdriver and it broke free once I knocked some of the gasket off.
Logged
Madison Motorsports
03 GTI
71 CB750
71 CB350
Gurp
I'm no.......
Master
Once was a...
Re: exhaust gasket
Reply #10 on:
April 15, 2019, 04:56:14 PM »
Glad that worked for you pal!
Logged
slow Progress
74 cb550.
Poor boy chop
73 CB500 chop
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
exhaust gasket
