Author Topic: Tires. I hate the word cheap but  (Read 6502 times)
Offline davidtime
Re: Tires. I hate the word cheap but
« Reply #25 on: June 08, 2013, 01:13:12 PM »
if you are still looking, I have a set of
 NEW DURO FRONT AND REAR TIRES
3.50-19 + 4.00-18
Part# 97-012 & 97-143
Brand new still in box, I just didn't use them... Paid $120 plus $27 shipping.
I'd take less for them if you wanted them
I probably am not getting them for a few weeks. I am just figuring out my budget on the bike. Right now I am in the slow process of prepping the engine for paint (what a drag).
Offline davidtime
« Reply #26 on: June 08, 2013, 01:13:42 PM »
Offline Dave Voss
« Reply #27 on: June 08, 2013, 01:31:55 PM »
I have to ditto on the 712's. I'm on my third rear and my second front right now ... Personally,I get about 4k miles out of a rear (at best) and the fronts last me about 10k.
A half-price tire that only lasts half as long seems like false ecomony, unless you perform your own labor to install and balance, or really only ride occasionally where the rubber in the tires would harden long before the tread wears out.  Maybe 4k miles is not typical life for others?
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
« Reply #28 on: June 08, 2013, 01:40:21 PM »
I thought 5.1 was a typo. Don't think I've seen one that wide on a stock rim.
Got a pic?
Offline davidtime
« Reply #29 on: June 08, 2013, 02:00:02 PM »
I just double checked and that's what it said.
Offline crazypj
  • I'm brill, me
« Reply #30 on: June 08, 2013, 04:46:33 PM »
Doesn't matter what size is on tyre, the rim is what you need to look at.
1.85x18 means you shouldn't fit anything wider than a 110 section and to be honest, even that is really too wide for rim
 I'm sure someone will post link to 'correct' tyre width chart, if not I'll find it later
« Last Edit: June 08, 2013, 04:54:27 PM by crazypj »
« Reply #31 on: June 08, 2013, 05:03:42 PM »
4k miles is about right for a soft compound tire on a cb750...I get about 4-7k miles out of what ever tire, ride hard, and usually leave a back tire on quite aways past what is prudent  ...because yeah they are expensive.  I think I got the most miles out of a Metzeler.  Dunlop seem to wear out the fastest but are great in the process.  One thing if you don't mount your own tires...if you have a decent bike shop in the area, they will usually mount and balance for cheap/free if you just pay a little more and buy the tire from them...
Offline Powderman
Offline davidtime
« Reply #33 on: June 08, 2013, 05:47:29 PM »
Good to know.
Offline davidtime
« Reply #34 on: June 08, 2013, 05:52:34 PM »
Thank you for the info.
Offline crazypj
  • I'm brill, me
« Reply #35 on: June 08, 2013, 09:10:45 PM »
Here's link, grey blocks are  max/min size/rim width
http://www.mtsac.edu/~cliff/storage/gs/Motorcycle_Rim_Width_Tire_Size_Chart.pdf
Personally I've had tyres wear out in as little as 1,800 miles on 550 (Pirelli Phantom)
 They give zero warning when they are about to 'let go', Michelin or Continental are way more 'forgiving' although any modern tyre will be superior to original equipment
« Last Edit: June 08, 2013, 09:23:07 PM by crazypj »
Offline Dave Voss
« Reply #36 on: June 08, 2013, 09:37:06 PM »
Personally I've had tyres wear out in as little as 1,800 miles on 550 ...
Really?  You guys must really be pushing these 550's around!  The worst tire mileage I've ever had was 4K miles on a set of Dunlop D204s (known for not lasting long, but they sure were sticky) on a sportbike that I used primarily for 'Sunday morning rides' around the local twisty back roads.  The highest mileage tires that I had were ME33/ME99 Metzlers, but they were a little sketchy when cold.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
Offline crazypj
  • I'm brill, me
« Reply #37 on: June 08, 2013, 10:09:43 PM »
Really
Offline shinyribs
« Reply #38 on: June 10, 2013, 08:23:14 PM »
I am hard on tires.Especially the rear. Some of my riding buddies hate to be behind me because they say I'm constantly spinning and tossing up gravels. ;D My buddy owns a bike shop so I buy tires from him,but mount and balance is free since I help him out on odd jobs and m&b my own rubber. ;) On his machine of course. Helps to have buds in the right places!
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
Offline crazypj
  • I'm brill, me
« Reply #39 on: June 11, 2013, 11:42:38 AM »
I never did 'burn outs' or deliberate wheel spin, tyres just don't seem to last me very long
It could well be because of stiff suspension though, that suited my riding style
Often, the tyres would wear out towards the edges before the center (when I lived in Britain, lots of real nice 'lanes' to thrash through  ;D)
Footrests don't last long either  ;) ;)
Offline LesterPiglet
  • 1977 CB550F2
« Reply #40 on: June 11, 2013, 01:39:10 PM »
Over 2200 miles on my cheapie Cheng Shin 130x80. No problems so far in all weathers.
Offline Vinhead1957
« Reply #41 on: June 11, 2013, 02:27:38 PM »
I only worry about tires is when it rains! Do I go into a corner hard? Not with suspect rubber
« Last Edit: June 11, 2013, 02:33:03 PM by Vinhead1957 »
Offline crazypj
  • I'm brill, me
« Reply #42 on: June 11, 2013, 04:22:26 PM »
I use those Cheng Shin 'Arrowmax' copies on my XS650, get around 4~6,000 miles OK in the wet but not spectacular, better than the Dunlop 491 front though
Offline Bankerdanny
  • Endeavor to persevere
« Reply #43 on: June 12, 2013, 07:43:28 AM »
Conti is rolling out a new radial designed for classic bikes like ours. I really want to put them on the 550 I'm building, but they will be rather spendy, so I may have to pass for this set.
Offline nccb
  • 1974 CB750 Four
« Reply #44 on: August 04, 2013, 05:49:15 PM »
so to the PO, did you get the tires and how are you liking them?  I am about to purchase a Shinko 712 rear to replace a worn down Dunlop 404.
Offline davidtime
« Reply #45 on: August 04, 2013, 06:31:45 PM »
I haven't gotten any yet. I was researching to add to my list.
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #46 on: August 04, 2013, 07:01:24 PM »
i had the cheng sing barracudas (100/90-19 front and 120/90-18 rear) for 5 years and 7k miles roughly.  there towards the end the bike was really getting squirrely in corners and had that "want to slide away" in long sweepers.  never did wear into the cords but the rear was most definitely done for.  i have the bridgestone spitfire 11's bow in 110/90-19 and 130/90-16 mounted on '82 kawasaki kz750 enkeii mags.  i believe my front rim is 2.15 and the rear is 4 something.  the front fills the '76 gl1000 front end and fender nicely.
MATT
Offline nccb
  • 1974 CB750 Four
« Reply #47 on: August 04, 2013, 07:03:59 PM »
Thats what is occurring with the 404, pretty unnerving.  I have been hesitant to break or accelerate when on painted surfaces of the road, or cross those lines for that matter in a turn.
Offline phil71
« Reply #48 on: August 04, 2013, 07:10:33 PM »
don't put used tires on a motorcycle.
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #49 on: August 04, 2013, 08:21:57 PM »
I like my Shinko's too....but if you want some stock size Bridgestones....then maybe you can work out shipping....they have been for sale for a while.
http://greensboro.craigslist.org/mcy/3932206485.html
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
