Author Topic: '76 CB750K Project #3 - Long and Low - Final thoughts and pics  (Read 41831 times)
Offline Stoli
Thought I would tear down this bike to see what I had to work with.
Engine and carbs aren't too bad. Haven't cracked the case open yet but the head is useable - although, I do have a '74 head  that needs less work, so I will probably use that if it is compatible with the '76 - need to look into that.
Frame is decent and I can use the wheel hubs. Fork cases are OK but need new tubes and a new tree. Just about everything else is useless. Tank is rusted through on the bottom rear.
Total cost to date: $0
Estimated final cost:  Probably more than I could sell it for but that's not the point
« Last Edit: September 30, 2014, 10:33:21 AM by Stoli »
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Re: '76 CB750K Project #3 - Much work to do
« Reply #1 on: July 07, 2013, 09:42:46 AM »
Yes, the 74 head is compatible with the rest of the 76 engine.
Offline Stoli
« Reply #2 on: July 22, 2013, 11:29:09 AM »
Thanks for the reply. My research indicates that the only differences between my K4 engine (2338396) and K6 engine (2442357) is in the cylinder block. Specifically the K6 has knock pins and seals where the K4 just had o-rings between the cylinder and the head. I was scratching my head for a while and doubting what you said, but I think those knock pins recess fully into the cylinder block so the old head would go on the newer cylinder like you said.
Do you know if all the internals are interchangeable between the two engines?
If I had to guess at this point, I think my plan is to use most of the K4 engine with the following parts from the K6:
carbs
clutch & cover
alternator & cover
head cover
mission cover
sprocket cover
and possibly the cylinder block
« Last Edit: July 22, 2013, 11:39:54 AM by Stoli »
My Project Threads:
Offline iron_worker
« Reply #3 on: July 22, 2013, 02:35:40 PM »
Much work to do INDEED!
 :o
Good luck.
IW
Offline goldarrow
  • one day, i'll be an
« Reply #4 on: July 22, 2013, 08:35:35 PM »
wonder how much rust if any in the bottom end........
CB550 K0
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #5 on: July 24, 2013, 06:48:35 AM »
Look at those frame tubes for rust very closey. That baby has lived outside for a "few" season eh?
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Stoli
« Reply #6 on: July 24, 2013, 09:07:58 AM »
That is certainly a big concern. Do the CB750 frames have a history of rusting from the inside out? Most of the external rust looks superficial but I am worried about what's on the inside.
My Project Threads:
Offline Stoli
Re: '76 CB750K Project #3 - Long and low
« Reply #7 on: November 07, 2013, 04:17:57 PM »
My other project was at the powder coaters, so cleaned up the frame on this one and increased the neck rake by 9-10 degrees.
« Last Edit: December 15, 2013, 05:53:44 AM by Stoli »
My Project Threads:
Offline Stoli
Re: '76 CB750K Project #3 - Long and Low
« Reply #8 on: November 08, 2013, 01:58:34 PM »
Here is the neck after the wedge was closed up. Tack welded in place for now. Will get it properly welded later.
My Project Threads:
Offline bjatwood
  • 1973 CB750-K3
« Reply #9 on: November 10, 2013, 03:05:06 PM »
The place to look for rust is on the tubes under the motor. Water can collect in these spots and can cause havoc...
Brian
#24193
Online Don R
« Reply #10 on: November 11, 2013, 10:07:29 PM »
 Your honda is like my 40 chevy. The restorer crowd gave me a hard time about making it a street rod. I told them it was saved from the junkyard twice, none of those guys would have saved it, so kiss my, you know.
 You're making something special out of what many wouldn't be brave enough to tackle. So when the restorers cry after it's beautiful laugh at them. I started a long and low project but got sidetracked. It's hanging on the wall in the shop. +4" swingarm and raked too.
Offline Stoli
« Reply #11 on: November 12, 2013, 09:23:32 AM »
Thanks for the encouragement Don. There seems to be a lot of incomplete project threads of bikes with increased rake. Maybe there is a  hidden message there??
This project was a perfect candidate for me to get more creative with since there were so many parts that were going to come from salvage yards and internet sites. Not sure exactly where I am going with it but one way or another I hope to have it on the road next summer.
My Project Threads:
Offline Stoli
« Reply #12 on: November 15, 2013, 12:53:48 PM »
Starting to take shape. Scored the tank off ebay. Shipped to me with gas in it. Gotta love that. Thanks to Stevo for the triple tree and Tom W. for the 650 swing arm. The tank isn't as long as I had hoped for this bike but this F model is the longest stock tank made, I believe, and the price was right.
The swingarm gets me an additional 2" in length and the rake mod about 4". Even more if I go with longer tubes. I just stuck on these tubes from one of my other projects to see what it looked like. I think I might stick with the stock length as it will drop the bike 2.5" if my math is right. I will be going with a slightly bigger tire radius, so the net drop won't be quite that much.
My Project Threads:
Offline BPellerine
« Reply #13 on: November 15, 2013, 02:42:11 PM »
looks good so far.bill
1978 CB 750K ard and webers
another anfob
« Reply #14 on: November 15, 2013, 02:46:56 PM »
I am partial to Super Sport tanks over the K tanks.
Offline Stoli
« Reply #15 on: November 16, 2013, 04:46:41 AM »
I think I may have to move the petcock bung. I am moving the tank back an inch or two to accommodate the mod to the neck and I think the petcock will be hitting the #1 carb body.
My Project Threads:
Offline Stoli
« Reply #16 on: December 15, 2013, 09:16:26 AM »
Bought a new 16" Harley rim (Drag Specialties). Kind of a pos but for $72 delivered, couldn't expect much more. Took me a little while to lace up (Buchanan's pre-packaged spoke kit) since the pattern was a little different than the stock rims  but in the end it came out pretty good. True enough.
My Project Threads:
Offline Stoli
« Reply #17 on: December 15, 2013, 09:38:34 AM »
Wish I could say the same for the front wheel. It appears that unless you send Buchanan's a sample of the exact spokes you need (or ship them the hub and rim), they have a hard time making a custom set for you.
I bought a new 19" Harley rim for the front wheel. Drag Specialties again ($95) but this one is a lot nicer quality than the 16" rear. This required a custom spoke set and after a few emails to/from the Buchanan's tech support folks, they said all they needed was a few dimensions of the rim and we'd be good to go ....  Not so fast.
Maybe I laced it up wrong, but the spokes are too long. If someone sees something wrong with my pattern, please let me know and I'll offer up a big mea culpa to Buchanan's. Otherwise, I'm a bit disappointed with them as this is the 2nd custom spoke set from them that I've had a problem with. They got the bends wrong on a set I ordered for my first project bike.
My Project Threads:
Offline G3
« Reply #18 on: December 15, 2013, 01:42:51 PM »
I think the worse they are to start with, the more satisfaction you get in the end right?
« Reply #19 on: December 15, 2013, 01:43:54 PM »
That's a rough one!
Offline USCG_C130
« Reply #20 on: December 15, 2013, 01:52:17 PM »
wow looks like  you have a handful there, wish my balls would have been big enough to cut my frame, i love the long and low look! best of luck!
Offline Stoli
« Reply #21 on: December 15, 2013, 02:52:56 PM »
Something to be said for that. It would be more impressive if I was keeping more of the original bike but most stuff is just too far gone. If the soul of the bike lives in the frame and engine, then this project is certainly a worthwhile endeavor.
My Project Threads:
Offline MoMo
  • Ride like you're invisible
« Reply #22 on: December 15, 2013, 04:38:04 PM »
You are a brave man attacking that rust pile.   Subscription sent in....larry
Offline BPellerine
« Reply #23 on: December 16, 2013, 06:23:08 PM »
hope you are the one to finish a raked bike and get it on the road.bill
another anfob
Offline KB02
« Reply #24 on: December 21, 2013, 06:08:44 AM »
Check out my build thread. They can be brought back from worse. ;)
I will be interesting to watch this unfold.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
