Author Topic: tire on backwards  (Read 3837 times)
Offline thelowmax
tire on backwards
« on: July 09, 2013, 04:28:35 AM »
I recently had my front tire replaced. When I got home I realized the guy had put the tire on backwards. Since I won't be able to get it changed for several days, I'm wondering... how sketchy is this situation? Am I in danger? Due to the design of the tread (designed to direct water away from the tire), I'm avoiding riding on any wet surface, but am unsure of just how this will effect road grip. Any comments?
What am I doing and why am I doing it? Those are excellent questions.
'72 Amen Savior/'77 CB750K Chrome/Da Bhudda(project)
'73 CB750K Green/El Verde (beat)
'76 CB750K Red/The Cinnabomb (sweet)
'77 CB750K Black (frame and parts) CANNIBALIZED
'77 CB750K Dark Purpley/Scooty Puff, Jr. (la beast)
'78 CB750K Black (struggling) SOLD
'78 CB750K Blue Flake/CiocioSan (minty)
'81 CB750C Poiple/Barbie'sDreamMotorcycle SOLD (darnit!)
'89 Trek 21" 21 speed Green/YaBiatch (the wife)
Converse One Stars size 8.5 Black/Sneaks (suede)
Offline LesterPiglet
  • 1977 CB550F2
Re: tire on backwards
« Reply #1 on: July 09, 2013, 04:47:51 AM »
Sorry no experience of this but I'm sure as long as you don't do any extrememe riding in the meantime you could manage a couple of days with it like that.
Offline toytuff
  • "watching the pinheads"
« Reply #2 on: July 09, 2013, 04:49:06 AM »
Just makes you shake your head huh?  ::)
tt
Offline dhall57
« Reply #3 on: July 09, 2013, 04:56:08 AM »
Get it remounted so it will be in the correct rotational direction. That's how the tire was designed to run. I had one installed wrong on my 750KO and Cycle Gear remounted it at no charge.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline surveywaters
    • My Project Photos
« Reply #4 on: July 09, 2013, 04:56:20 AM »
It will wear fast and start to cup, may also be a bit grabby. I would just pop it off and flip it real quick, if you ride it to long you'll sacrifice tire life big time.
1972 SL125,1974 XL125,1975 CB125,1978 CB750k,1978 KZ650,1978 XS650,1985 VT1100,1986 VF700, 2005 XV1700,2003 DL1000,1982 XR250R,1986 ATC70,1987 BW80,1987 XR250R,1999 Z50r,2002 DRZ400s
Offline Stoli
« Reply #5 on: July 09, 2013, 05:10:02 AM »
I read an article that I will try to dig up about this subject. The rotation direction of tires is more about tire construction than water diversion. Has to do with the stress on the particular tire - front is used for stopping and rear for accelerating. That is why if you notice the tires that can be used for front and rear (Avons for example) are mounted in opposite directions. So if you are riding your bike in the mean time, instead of avoiding water, you should be more concerned with avoiding fast starts and hard stops.
« Last Edit: July 09, 2013, 06:04:53 AM by Stoli »
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
« Reply #6 on: July 09, 2013, 08:23:26 AM »
It has to do with the direction the cord is wound, but also tread..re squeezing water out.
 I had one put on backwards in SLC, rode back before I realized it.  A split line formed across the tire, and it was very easy to lock up the tire.. It was a cheap rear tire. The line across tye tire never got worse, i think I turned the tire around, but I had well over a thousand miles on it when I noticed..
« Reply #7 on: July 09, 2013, 09:06:12 AM »
http://www.americanmotorcyclist.com/Riding/Street/Resources/TireDesignations.aspx
This will tell you what youneed to know about tires andthere is a section on rotation direction. One reason may surprise you.
Online Don R
« Reply #8 on: July 09, 2013, 09:19:07 AM »
Thanks, that's usefull information.
Offline Powderman
« Reply #9 on: July 09, 2013, 10:38:52 AM »
How did you determine it was on backwards? Is there a directional arrow on the tire? Did you go by the tread pattern compared to the rear tread? Was it the installers fault or did you not tell him what direction the wheel was?
The directional ply of the make up of a tire was made evident in the F1 race 2 weeks ago when several cars had left rear tire delaminations. They immediately changed the direction the plys go on the next race. This is explained briefly in the link below.
« Last Edit: July 09, 2013, 10:46:19 AM by Powderman »
Offline Johnie
« Reply #10 on: July 09, 2013, 10:43:33 AM »
Had a dealership do that to me a while ago. Keep in mind the yellow dot on the tire is where the valve stem should be located. I say this as if the guy did not know about rotation he maybe does not know what the yellow dot on that side wall is for either.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline thelowmax
« Reply #11 on: July 09, 2013, 01:27:34 PM »
There is a directional arrow on the side. I bought it on eBay, rim and all. Nice rim, new tire on backward. I didn't notice until I put it on. I'll switch it when I get home from my trip. Thanks for the info.
  • 1977 CB550F2
« Reply #12 on: July 09, 2013, 02:08:15 PM »
That made for an interesting race, I didn't know that was the problem.
Offline Stoli
« Reply #13 on: July 09, 2013, 08:42:58 PM »
Here is the article. In Avon's case, the water dispersion (tread pattern) takes a back seat to the tread splice. Why they make tires that fit both front and rear is a mystery to me, but I can only assume it is to save a buck.
http://cyrilhuzeblog.com/2009/08/23/tires-directional-arrows-explained-by-avon-tyres/
My Project Threads:
Offline lucky
« Reply #14 on: July 09, 2013, 08:48:03 PM »
If a dealership puts your tire on backwards do not do any more business with them.
It is a sign they do not know or care what they are doing.
They should not be working on motorcycles.
Ask yourself this question.
IF YOU were putting the tire on the motorcycle would you check
 to see that it is facing the proper direction?  OK then.
« Last Edit: July 09, 2013, 08:49:37 PM by lucky »
Offline Powderman
« Reply #15 on: July 09, 2013, 09:32:59 PM »
The belts are wrapped essentially like a watch spring. When under power you want the spring to wind tight not unwind. The Pirelli's where wrapped the wrong way.They immediately started to wrap them the opposite way using kevlar belts for the next race.
Offline reddyvv
« Reply #16 on: July 09, 2013, 09:42:45 PM »
I posted a question about this in June's best bike contest. I saw that two of the bikes had the front tire tread backwards where water would be directed into the tire rather than away from it. It was explained that they were universal tires for front and rear. I would never buy such a tire with the tread working against me in the wet  ::)
« Last Edit: July 09, 2013, 09:46:14 PM by reddyvv »
« Reply #17 on: July 09, 2013, 10:31:50 PM »
I've seen several tread designs that appear to be backwards based on traditional "water shedding away from the center" type tread patterns.  I would guess there is more than meets the eye involved here as all these tires are modern designs by reputable tire companies that certainly spend plenty designing tread patterns that work in the wet.  Also, most of these tires have recieved good results from independant testing and customer feedback...unless you are some kind of tire engineer, all you can really do is buy quality tires and mount them with the arrow pointing in the right direction, and if they don't work good. don't buy 'em again.
Offline Powderman
« Reply #18 on: July 09, 2013, 11:34:23 PM »
You would think the tread pattern would take water from the center of the tread and direct away to the outside. My new tire was mounted and I questioned why it was backwards but they showed me the directional arrow on it showing it was correct. The rear is suppose to direct water away under exceleration while the front takes the water from the outside during cornering and directs it to the center.
Offline lucky
« Reply #19 on: July 10, 2013, 06:01:46 AM »
If you took a wheel in without the bike and did not supply direction to the tech or the bike make/model I would not blame him if he copied an existing error. How would he know what side of the bike the rotor is on? Just sayin is all and we are only human.
It is up to the tech to ASK you which is the drive side. Which bike. It should be on the work order.
The mechanic when mounting your tire should be thinking, how will I know what direction the drive side is? Then he would call you. OR Google it. But like I said a good service writer or mechanic would ask you when you drop off the wheel,
"We are only human" is not an excuse for a mechanic.
BTW .. If you take the wheel in to get the tire change and you drop wheel spacers in the parking lot or their car, that is not the mechanics fault.
If I was the service writer or mechanic I would write that on the ticket. "Came in WITH or WITHOUT wheel spacers" Drive side is the side with the sprocket or drive missing. LOL..lol Duh CB 750.... left side.
Offline Vinhead1957
« Reply #20 on: July 10, 2013, 11:57:49 AM »
If you take a tire off the rim you should know which direction it should be put back on!   Just saying?
Offline petercb750
« Reply #21 on: July 10, 2013, 02:08:02 PM »
Some tyres can actually be reversed, we did it back in the 70s when racing on low budgets on mainly right hand corner tracks.....only problem I ever had with that was an avon, and it hurt :(
But you'll notice that K81s have arrows pointing in both directions.....one way for front, other way for rear.......
Why? I don't know.
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
Offline pangloss
  • CB500 K2 1975 NZ model
« Reply #22 on: July 10, 2013, 02:26:27 PM »
YEP...Entirely correct.. The K81 was used front and rear .Every Commando I owned used 4.10 x 19 k81 front and rear....rotation was important as even the puny 35-40 hp would unfold the laminate if incorrectly fitted. AND heavy braking did the same to an incorrectly fitted front.
DH
« Reply #23 on: July 10, 2013, 07:46:21 PM »
Recently, a local dealer did a re-balance on the front tire of my cbr600rr (weights flew off). The mechanic reinstalled the WHEEL/TIRE
assy. on backwards (yes, it is possible), and as a result, the tire was rotating in the wrong direction.... Only thing that made me suspicious was that the front brakes seemed to be dragging slightly
when jockeying the bike around to park it, etc. After a hundred miles and a few high speed blasts, something was ever so subtly different
in the way the bike handled. That's when I discovered the reversed directional arrow. Keeping a cool and friendly demeanor, I talked to the shop service manager, who handled the situation very well
from start to finish, and directed one of the younger techs to
fix my bike. I WILL do business there again. But lesson learned,
ALWAYS make sure your tires and wheels are correctly orientated,
SOHC 4 or modern sport bike. :)
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #24 on: July 11, 2013, 09:49:37 AM »
Bobbr has it all:
The other big reason for noting wheel direction has to do with the manufacturing process. The tread rubber is initially a flat strip that's cut to length, at an angle, and then spliced together with the two ends overlapping, creating a hoop. Under acceleration, a tire mounted backwards will try to peel back this splice. The opposite is true for the front wheel, where directional forces are reversed under hard braking.
the PO had my front tire mounted backwards. I was always concerned about it but I'd heard that its fine the directional/power driven direction was mostly for the rear tire. I never felt a problem with the way it performs so I left it. Now I know for sure.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
