Author Topic: cb650 81 head and 80 slide carbs  (Read 752 times)
Offline RebelYankee
« on: July 14, 2013, 06:33:15 PM »
Hi Folks,
I have read that one can use the Ninja 600cc carb boots on a 79 or 80 head to attach CV carbs.  I am in the opposite situation.  I have a 81 CB650 head and slide (PD) carbs.  Anyone know if I can use the Ninja carb boots to mount these?
Thanks,
Jamie
1980 CB650C
Offline trueblue
Re: cb650 81 head and 80 slide carbs
« Reply #1 on: July 15, 2013, 03:51:47 AM »
Carbs won't fit the boots, different diameter.  Get the right carbs for your bike ;)
1979 CB650Z
Offline RebelYankee
« Reply #2 on: July 15, 2013, 06:05:37 AM »
Thanks, Trueblue.
The carbs are correct, it's a 1980 CB650C.  It's the head that is from an 81.  I had bent valves so picked up a new head not thinking about the carbs.  Looks like I'll be pulling the valves off the 81 and putting them in the original head.  What a pain in the ass.
1980 CB650C
Offline trueblue
« Reply #3 on: July 16, 2013, 03:31:02 AM »
See if you can pick up some CV carbs, you'll like the increase in low end response ;)  I think the DOHC 750 carbs have the same spacing as the CV 650's ;D
1979 CB650Z
