Author Topic: weak brakes after most every upgrade.???????  (Read 8877 times)
Offline CBGBs
    • Ride or Rot vintage motorcycle event in FTW
Re: weak brakes after most every upgrade.???????
« Reply #25 on: August 13, 2013, 07:36:09 PM »
Success! I used the strap the lever over night trick and its night and day better! Great technique!
Thanks to everyone who responded. This forum is amazing.
'66 CB77 Superhawk  '73 CB350G Cafe  '75 CB400F '65 S90  '78 CB750 SS
Offline CBGBs
« Reply #26 on: August 13, 2013, 07:40:53 PM »
This is my bike. I know its not an sohc four but I do own one and you know the brakes are all the same on these.
Thanks again!
« Reply #27 on: August 13, 2013, 08:12:57 PM »
Sometimes brakes are a breeze to bleed, and sometimes they are a total #$%*; we've all been there once or twice.
Nice looking bike! Please post more about it on the "other bikes" board.
« Reply #28 on: August 13, 2013, 11:26:02 PM »
Tap the SS lines with a wrench, work from bottom up..knocks off clingy bubbles...
Offline MoMo
  • Ride like you're invisible
« Reply #29 on: August 15, 2013, 01:39:25 PM »
Nice to be able to stop, isn't it?  :D....Larry
« Reply #30 on: August 15, 2013, 02:43:47 PM »
Sorry but I was informed here that doesn't work. You must be mistaken. LMAO. Seriously, it worked for me too on my double disc bike.
Offline CBGBs
« Reply #31 on: August 15, 2013, 06:56:18 PM »
I still can't believe that it works! I have a decent amount of braking but it is still spongy. I'm going to try it again since I've been riding and see if I can get more out of it.
Anyone understand the science behind this?
Offline MoMo
« Reply #32 on: August 15, 2013, 07:16:41 PM »
I have left a bike sit with the lever held in to the depth of a finger for several days to get the last bit of air out...Larry
« Reply #33 on: August 15, 2013, 08:03:49 PM »
I'd like to hear about that as well.
Offline crazypj
  • I'm brill, me
« Reply #34 on: August 15, 2013, 10:16:13 PM »
From what I've learned, you get something called micro bubbles in the fluid, particularly if some idiot shakes bottle/can
If you leave fluid sit, the bubbles may eventually work out but under pressure they combine and float to the top
in about 12~24 hrs
 May be total BS but it works so sounded logical to me
 It's a good idea to keep pressure on lever when you remove strap, bungy or whatever then allow lever to flick out quickly as it seems to cause any air to be sucked out of piston bore
« Reply #35 on: August 15, 2013, 11:20:48 PM »
From what I've observed while bleeding brakes, if you put pressure on the large bubbles in the system they break up and turn into very tiny ones that have difficulty moving though any viscous fluid.
