FWIW, You don't want to hold it to the bar, just 16mm away is what I've read that the repair books recommend. Going all the way pulls the piston on the MC past a point it can leak at the MC piston opening the lever is moving, this causes the seal to degrade and can lead to the finish failing at that portion of the caliper, dirt collects, etc.
A small block of wood will allow you to clamp it tight with a rubber band and not pass the recommended value.
David
