Author Topic: Not what I wanted to see..  (Read 8044 times)
Offline toytuff
  • "watching the pinheads"
« on: August 11, 2013, 07:53:57 AM »
Dang! Doing a routine inspection/cleaning on the 750 this morning. Wasn't planning on this but better on the lift than on the street.
Looks like a ride is on hold. Can't trust this.
Looks like a Dunlop F24 tire shop today.  ::)
tt
Re: Not what I wanted to see..
« Reply #1 on: August 11, 2013, 08:27:35 AM »
What is those marks on your rotor?
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: August 11, 2013, 08:31:43 AM »
A reflection of the diamond plate the bike is on.
« Reply #3 on: August 11, 2013, 08:35:26 AM »
How old are the tires ? Wasn't there a recent thread about new Avons cracking also ?
Offline toytuff
« Reply #4 on: August 11, 2013, 08:39:03 AM »
Well this is interesting. Tires were replaced by PO. I just noticed on the back is a tubeless tire running a tube.
The only size I can find is a 110-90-19. It has a 110-80-19 on it now. Would the (90) be wider?
tt
Offline toytuff
« Reply #5 on: August 11, 2013, 08:40:34 AM »
I have no idea but there should be a date on them. I'll take a look.
tt
« Reply #6 on: August 11, 2013, 08:41:57 AM »
Taller
Offline toytuff
« Reply #7 on: August 11, 2013, 08:44:18 AM »
Taller
Got it! Thanks. I can never remember. 110 is the width.
Well, that should work fine.
tt
Offline crazypj
  • I'm brill, me
« Reply #8 on: August 11, 2013, 08:55:39 AM »
tt
It should fit rim better as the 10% taller sidewall can flex into place easier May need slightly higher pressure
« Reply #9 on: August 11, 2013, 09:04:41 AM »
Yes, and I read it right after buying Avons for the Z1.
Toy - the date of manufacture will be after the letters DOT, week and year made.
How long have you had that bike?
Offline toytuff
« Reply #10 on: August 11, 2013, 09:05:43 AM »
Got it.
The rear tire says tubeless or tube.
tt
« Reply #11 on: August 11, 2013, 09:07:09 AM »
Got it.
tt
Not a problem running a tubeless tire with a tube
« Reply #12 on: August 11, 2013, 09:25:42 AM »
Common practice to fit a tubeless tyre, with tube, to a spoked rim. But never a tube type without tube to a solid rim
Offline toytuff
« Reply #13 on: August 11, 2013, 09:29:10 AM »
These tires were on it when I bought it. History unknown.
Never noticed before as I keep an eye on tires. With the heat out here I'm not surprised. I have had wiper blades stuck to the windshield in the past.
tt
Offline lone*X
« Reply #14 on: August 11, 2013, 09:39:25 AM »
So, that's an 11 year old tire.  No wonder it's cracking.  Definitely time for new rubber.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline toytuff
« Reply #15 on: August 11, 2013, 09:54:37 AM »
What did you come up with? 2002 I assume. Only thing I can make it out to be.
At any rate new tire, tube and rim strip ordered. I'll take it off later in the week when the new tire gets close.
Could of been a very bad day if out on a ride huh?
tt
« Reply #16 on: August 11, 2013, 10:25:26 AM »
tt
Not really, prolly was like that last time you rode it. Not recommended though.
What tire you order?
Offline toytuff
« Reply #17 on: August 11, 2013, 11:02:52 AM »
tt
Same. F24 Dunlop.
tt
« Reply #18 on: August 11, 2013, 11:10:49 AM »
tt
Same. F24 Dunlop.
tt
Not familiar with that model, put Dunlop 404's on my K8 last year.  You buy a set?
Offline toytuff
« Reply #19 on: August 11, 2013, 11:46:09 AM »
Nope.
tt
« Reply #20 on: August 11, 2013, 11:57:18 AM »
Offline toytuff
« Reply #21 on: August 11, 2013, 12:29:15 PM »
Didn't look. No cracks, looks fine. Think it might be newer.
No worries.
tt
« Reply #22 on: August 11, 2013, 12:43:55 PM »
Better to find it on the lift and on the street as you pick the gravel out of you backside...
Sorry to read of the misfortune.
There goes some Tequilla money, or beer money...
David
« Reply #23 on: August 11, 2013, 12:54:06 PM »
the date code should be four numbers only?try and find another set of numbers like that.
« Reply #24 on: August 11, 2013, 01:10:05 PM »
The date code is four numbers. The numbers preceding it is the North American ID number...
http://www.xrv.org.uk/forums/wheels-tyres-tubes/62278-can-anyone-translate.html
