Author Topic: Stripped tappet cover, any advice?  (Read 4558 times)
Offline daewon774
« on: September 17, 2013, 04:23:15 PM »
Damnit, I wasn't paying attention and I let the socket wrench strip the tappet cover.  Any advice on how to pull this off?  I tried vice grips but made it worse... :(
« Last Edit: September 17, 2013, 04:56:53 PM by daewon774 »
76' CB550
11' Ducati 848 EVO
Offline 750K
Re: Stripped tappet cover, any advice?
« Reply #1 on: September 17, 2013, 04:31:55 PM »
If you're talking about the nut cast into the cover then file down two parallel sides till an open ended wrench the next size down fits tightly on the filed down nut. It's worked for me in the past, getting a pipe wrench or vise grips to bite on the little edge never worked for me. If filing the nut doesn't work I'd gently use a chisel to knock the tappet cover till it starts to spin and unthread.
77 Cb750, 78 Kz1000
Black 750K8
« Reply #2 on: September 17, 2013, 04:41:29 PM »
Some of us will not have a clue of what part you are talking about or the bike. Maybe it is the 650 ? Are you referring to the ???
Offline daewon774
« Reply #3 on: September 17, 2013, 04:55:55 PM »
You don't know what a tappet cover is? It's on all the CB500/550/650/750s...
« Last Edit: September 17, 2013, 04:57:28 PM by daewon774 »
76' CB550
11' Ducati 848 EVO
Offline daewon774
« Reply #4 on: September 17, 2013, 04:56:31 PM »
Thanks for the reply. I'll try that tomorrow morning.  :)
76' CB550
11' Ducati 848 EVO
Offline Dave Voss
« Reply #5 on: September 17, 2013, 05:35:25 PM »
If you have a 6-point socket, try tapping that on to see if it bites enough to be able to loosen it up.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
Nic
« Reply #6 on: September 17, 2013, 06:03:59 PM »
6 point socket is the only way to go when doing them up as well, you don't tighten em down either, just nip it so you can still feel the O ring. Nuthin' worse lookin' than these things all buggered up.
Offline vma03
« Reply #7 on: September 17, 2013, 09:47:54 PM »
I had the same thing happen to me. I took a socket that was slightly smaller (it was an SAE and not metric, but I don't remember the size) and "tapped" it lightly with a sledgehammer.  It was enough to get the tappet cover off, now getting the tappet cover out of the socket...that's another story and definitely R rated.
Good Luck!
« Reply #8 on: September 17, 2013, 10:39:03 PM »
Isn't this the same size as the spark plug wrench in the tool kit? Perhaps you could get that to work.
Are you talking about the threads or the head?
Nic
« Reply #9 on: September 17, 2013, 11:05:34 PM »
spark plug 18mm, cap 17mm.
« Reply #10 on: September 17, 2013, 11:29:41 PM »
You need a new one anyway so carful use of a small chisel and hammer.
For info if buying a new one the 70cc stepthough are the same size but not polished and laquered so cheaper
« Reply #11 on: September 18, 2013, 12:36:09 AM »
get a cheap 6 side socket then grind those ramps away like the one on the left so it has a better bite,only nip them down tight.
« Reply #12 on: September 18, 2013, 01:06:39 AM »
How the fcuk do you strip those..? I've heard of the threads giving way but stripping the heads...!!!
Nic
« Reply #13 on: September 18, 2013, 02:28:23 AM »
My basket case had every nut and bolt #$%*ed by the PO using the wrong spanners/sockets. More like he used a shifter on most of em, a common tale.
Online PeWe
« Reply #14 on: September 18, 2013, 03:18:44 AM »
The mentioned file trick should be the thing.
I have done it +30 year and a few months ago.
Do not tighten these too hard, the o-ring will grip and make it more difficult to remove..
« Reply #15 on: September 18, 2013, 04:05:33 AM »
Big channel locks clamped down hard around the outside edge has always worked for me and you do not risk breaking off the top of the cap and having to fish the threads out of the holes threads or risk pieces falling in. Sometimes I will even use them before the 17mm nut is destroyed if I know they are stuck too well. Part of 'new' bike fun.
« Last Edit: September 19, 2013, 09:55:49 AM by ekpent »
Offline 750K
« Reply #16 on: September 18, 2013, 09:41:18 AM »
Prett easy to strip out, I've replaced 2 or three on my 77k. All due in part to hamfisted PO's rounding the corners of the nuts, it always strips while trying to take them off.
77 Cb750, 78 Kz1000
Offline lucky
« Reply #17 on: September 19, 2013, 07:07:29 AM »
What is stripped? Is it the tappet cover or the cylinder head cover threads or both?
Those should ALWAYS be screwed in by hand. ALWAYS.
Yeah the socket wrench did it. :-X
Offline lucky
« Reply #18 on: September 19, 2013, 07:15:11 AM »
Here is how it is done:
First they (tappet covers) are put in with a socket crooked, THEN over tightened like their life depended on that nut. (Like a quick oil change business would do)
Then when removing, a chisel takes a chunk out of the valve cover.
The bike is put in back of the house with no cover.
15 years later the owner sells the bike and tells the new
owner that the last time he rode it ran.
See....Simple.
That person now works at an oil change business. Your car is next on the rack!
Offline daewon774
« Reply #19 on: September 19, 2013, 07:47:19 AM »
See....Simple.
lol, I am now that PO.  I stripped the head.  It wasn't a 6 sided socket that I used either.  My fault.  Plus I wasn't paying attention, I was looking at something else when I went to loosen it, thus, the head gets stripped.
For everyone else... Thanks for the tips.  I ordered a new tappet cover and will be working on it this weekend.  I'll try to tap a 6 headed socket on.  If that doesn't work, I'll try the vise grip or a chisel and hammer...
76' CB550
11' Ducati 848 EVO
Offline daewon774
« Reply #20 on: September 19, 2013, 07:49:23 AM »
NICE!  This is exactly what I'll be trying out this weekend!
Thanks for the tip!
76' CB550
11' Ducati 848 EVO
Offline lucky
« Reply #21 on: September 19, 2013, 08:16:11 AM »
See....Simple.
I am still confused.
The cylinder "head" is under the valve cover so you did not damage the "head".
If the tappet cover is still on the valve cover then the cylinder head cover may not be stripped either.
So are you saying only the tappet cover hex nut  is damaged?
Make sure you tap the tappet cover very lightly with a small hammer to loosen the molecular bond THEN try loosening it.
BTW....Why does your avatar show another accident? LOL..lol ;D
« Last Edit: September 19, 2013, 08:19:28 AM by lucky »
Offline robvangulik
  • Honda Fourever
« Reply #22 on: September 19, 2013, 03:22:53 PM »
Are you Laughing Out Loud about someone else 's accident? ::)
Offline 750K
« Reply #23 on: September 19, 2013, 04:22:20 PM »
This is the most sense you've made in ages Lucky, haha.
« Last Edit: September 19, 2013, 04:23:51 PM by 750K »
77 Cb750, 78 Kz1000
Offline Old Scrambler
« Reply #24 on: September 19, 2013, 05:06:55 PM »
Good one Lucky................BTW...........I lay a used Handi-wipe over the tappet-cover to protect it from the socket-wrench...........especially if its polished.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
