Author Topic: Cb400f Runs crummy when warmed up then overheats  (Read 6814 times)
Offline Icarus
    • Icarus Frames, my bicycle frame building company
« on: October 23, 2013, 04:43:05 PM »
Hey all,
     So I finished building up the 400f a couple weeks ago, finally got it plated and on the road for some test rides.  New rings, lapped valves, new gaskets and all that.  Once I got it all together, I wasn't sure which break in method to use (short and rough or long and gentle) so I opted for doing a few good pulls up a steep hill then switched to around town riding, variable speed/rpm and no highways for now.
Anyways, went for a ride over the weekend and it was running good until about 40 minutes in when I started to come to some lights/stop signs and it really wanted to die at idle and I had to rev it to keep it from dying.  Also, it had very little power when accelerating from stop, had to really rev it which wasn't the case on shorter rides.
The next day I checked the timing with a light and adjusted the timing for 2/3.  It was off and I think ,maybe they weren't firing consistently and that caused the previous days problems at idle.
So the next day I go for a ride and it seems to do a similar thing after it gets real warm.  Wants to die at idle, but then after letting it cool it runs good again.  My GF had to take it to work today because the car is getting repaired.  On her way home she is cruising fine until she hits traffic and has to sit...and sit revving because its wanting to die at idle.  This makes it get even hotter and it just gives up.  She said the kickstarter was very hard to move at that point (AWWW CRAP SEIZED?!?) but by the time I come to the rescue 30 min later, it kicks over easy and starts right up and idles easy.
What is going on?  Why does it run good then crap out?  I was thinking too rich ( I have idle screws 1.75 turns out though)  Stock airbox and 4-1 exhaust.  Seems like its overheating but shouldn't be so easy to get to that point.  When I was cruising and had problems the first day I spent very little time idling, plenty of wind over the engine.
Oh, the battery is unhealthy but I just got the new one so I can pop that in to get rid of one pesky symptom (after riding a while, and then dying at idle I would have to kick start because the battery didn't have the juice for the starter).  I tested the field coil and stator and they appear to be within the normal limits and the have a new solid state regulator/rectifier in there.
1975 CB400F
1977 CB550K
avatar is a previous moto project
Re: Cb400f Runs crummy when warmed up then overheats
« Reply #1 on: October 23, 2013, 04:47:53 PM »
good, properly charged battery, first, then let us know if the symptoms persist.
look here
http://forums.sohc4.net/index.php?topic=87086.0
Offline Icarus
« Reply #2 on: October 23, 2013, 05:12:01 PM »
Reading through that thread now.  I should also mention the carbs are only bench synced right now.  I have a synchronizer on its way, hoping to have it by Friday.
I will report back once the fresh battery has been tried out.
1975 CB400F
1977 CB550K
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: October 23, 2013, 06:12:03 PM »
What color are the plugs?  Carbs out of sync would not cause the problem you're describing.  Battery first...Larry
Offline Icarus
« Reply #4 on: October 23, 2013, 07:28:37 PM »
Momo, the plugs are sooty black.  I am guessing this is because it was sitting at idle in traffic before dying and doesn't excessive idling usually make for a rich looking plug?
1975 CB400F
1977 CB550K
Offline Icarus
« Reply #5 on: October 25, 2013, 08:17:43 AM »
OKay i have the new battery charged up and in the bike.  I was re testing all the charging stuff and I got these numbers:
green/white 4.5ohms
yellow/yellow/yellow .6-.7 ohms (my multimeter doesn't show the next decimal)
neither have continuity with the frame, the battery at idle reads 12.08V but when I increase the rpm to 3k, 4k, 5k the voltage only goes up to 12.16V.
According to the manual it should get up to 14.5v, does this mean I have a regulator problem?  Its a new unit.
1975 CB400F
1977 CB550K
Offline Matt Chapter
  • spin it up!
« Reply #6 on: October 25, 2013, 08:41:03 AM »
Yes, you should being seeing a higher voltage across the battery than 12.xx when charging.  You might have a corroded or loose connection if there are new parts involved.
Also, no, I don't think that in a stock setup the plugs should be very sooty after idling. Sounds like to me you really need to have the carbs synched.  Have you cleaned and rebuilt them?
'86 R65 '76 CB400F
Offline Icarus
« Reply #7 on: October 25, 2013, 09:08:19 AM »
Matt, yeah I rebuilt the carbs going to vac sync them as soon as I have the meter.
I am charging the battery again because it sounds like it should be reading higher than 12.09 at full charge.  Also took apart the battery and reg/rect connections and they're nice n tight with dielectric grease.
1975 CB400F
1977 CB550K
Offline Tim2005
« Reply #8 on: October 25, 2013, 11:13:08 AM »
Could it be that your new solid state reg/rect is faulty? Do you still have the original parts to swap back and try?
I'd certainly fix this problem before investigating the running rough thing, as that may well just be caused by low volts & weak sparks.
Offline Icarus
« Reply #9 on: October 25, 2013, 11:32:40 AM »
Yes, I am wanting to get the whole charging system sorted to see if that fixes things.  I am in contact with the regulator/rectifier maker and doing more tests once the battery is ready.  I have the OEM regulator and rectifier but since the bike was sitting for 20 years before I got it, I do not know if they are in working order.
this thing sure is fun when its running nice.  Its my first 4 cylinder and its so dang smooth compared to my old triumph.
1975 CB400F
1977 CB550K
Offline vames
« Reply #10 on: October 25, 2013, 12:31:42 PM »
Also, make sure it's running well before you send your girlfriend out into dangerous traffic on it!
Offline Icarus
« Reply #11 on: October 25, 2013, 12:33:35 PM »
haha she was warned!  She rides a lot and new what kinda guff it was having but wanted to ride it anyways.
1975 CB400F
1977 CB550K
« Reply #12 on: October 25, 2013, 12:46:54 PM »
When you installed the rings, what end gap did you set?
Rings too tight will bore seize when hot and expanded.
Check the voltage across the Green and white when the engine is at idle and again revved.  Battery voltage level there make the alternator work the hardest.   But, you should be checking the charging system with a known good and fully charged battery.
Charging issues won't make the kick start lever tight or cause the engine to seize.  Engine seizure, o approach to that will make the starter motor draw a lot more power from the battery.
Offline Icarus
« Reply #13 on: October 25, 2013, 03:24:29 PM »
Okay further battery report:
Charged to 13.03V, let it sit for 2 hours and it measured 12.74V.
At idle the battery voltage read 12.26V and upon revving it only went up to 12.31V.  This is with headlight off.
TwoTired, for the measuring of the green/white at idle and revved should I disconnect them from the regulator/rect or keep them hooked up and just expose a small part to measure?
My ring gap for the top two rings was .010" which was right in the middle of what the manual said it should be.  I am blanking on what the oil rings were.
I agree that the charging situation wouldn't lead everything tightening up.  Trying to figure out I need to take the engine all apart again.  guhhhh
1975 CB400F
1977 CB550K
« Reply #14 on: October 25, 2013, 04:11:55 PM »
This an "in operation" test.  You want to see what the regulator is feeding the alternator field when the battery is demanding power.
At idle, the alternator can't make much power even if the field is given full battery voltage.  However, when revved, there should be plenty of power, provided the voltage regulator drives it as it should.  The vreg really should only trim back voltage to the field when the battery gets to 14.5v, (or at least 13.8V).
Offline Icarus
« Reply #15 on: October 30, 2013, 10:15:32 AM »
Solved one of the problems.  Thanks to your white/green wire running check.  I found that the green wire from the regulator had a crappy ground.  I extended the wire and bolted it straight to the (-) battery terminal and then did another volate test and at higher RPMs it was definitely getting more juice.
Next test will be going on a bit of a ride to see how the charge holds up and if there is still an overheating issue.  I am hoping that the low battery charge that forced revving to keep it going at idle just caused too much heat while sitting in traffic.  Of course, the other possibility is that the bike gets hot, and the rings get tight making idling difficult so it takes more power to keep things moving.
I will let you know what I find.  I worry that the thing is seizing up but I don't know why it would.  I took out the worn rings and measured the cylinders only to find they were still well within standard bore limits, so I put new standard sized rings in after a quick hone.
1975 CB400F
1977 CB550K
Offline lucky
« Reply #16 on: October 30, 2013, 11:08:30 AM »
It does sound like it was seizing up.
That is standard in that situation to not want to turn over and then when it has cooled off to be easy to turn over.
You did not tell us if the it has the stock air box and stock air filter or the exhaust configuration.
Good thing your GF did not get killed or hurt by being hit from behind with a stalled bike. Just think if that did happen.
Offline Icarus
« Reply #17 on: October 31, 2013, 04:16:37 PM »
Stock airbox with new filter (intake system is old so might have some leaks around the ports.  The headers are the stock 4-1, not sure if the muffler is OEM or not.
Lucky dun worry, my GF knows how to ride a bike.  She isn't out there in high heels and shorts.  Her bike stalled while sitting stopped in traffic, surrounded by others cars also sitting still in traffic.
1975 CB400F
1977 CB550K
Offline Icarus
« Reply #18 on: November 20, 2013, 07:39:27 PM »
So after further test riding, the charging system is now working great!  Unfortunately the bike still doesn't want to idle once i've been on the road for ~15minutes.
I have tested for fuel flow, one by one I drained each carb bowl and then opened the petcock to see how readily the fuel came from each one.  Seemed good.
The bike idles good while cold.  I use a bit of choke when I first start it and it takes just a minute or so before I can un-choke and get on my way.
Does anyone have ideas for things to test to maybe try and zero in on the issue?  Oh, I installed new condensers and coils but that had no effect.
1975 CB400F
1977 CB550K
Offline Icarus
« Reply #19 on: November 20, 2013, 07:45:07 PM »
Also, when its wanting to die at idle I can rev the throttle to keep it alive and then the RPMs slowly settle back down to 1200-1400 and then it stumbles to nothing (if I don't keep revving).  When the light turns green I have to give it more throttle than usual and ease of the clutch slower.  Seems like maybe not all cylinders are firing? Then they all kick in and it runs good again once the RPMs increase.
I would think timing but then why would it run good for a while then get crummy?  Possible AAU sticking open?  I have timed it with a strobe but I guess I can always do it again.
1975 CB400F
1977 CB550K
Offline MoMo
« Reply #20 on: November 21, 2013, 01:35:18 AM »
I forget if you said the carbs have been cleaned, what you are describing sounds as though the pilot  and midrange emulsifier jets are blocked...Larry
Offline Icarus
« Reply #21 on: November 21, 2013, 06:00:11 AM »
I did rebuild them but its possible one of those didn't get perfectly done.  I have sprayed some carb cleaner through the idle circuits.
I must admit I don't exactly know how to clean the mid range emulsifier jets.  Is that the tube that the needle is in?
1975 CB400F
1977 CB550K
Offline MoMo
« Reply #22 on: November 21, 2013, 06:44:59 AM »
Yes, and jets are most always clogged.  I remove the slides to service them but I have seen people remove the tubes without removing the slides...Larry
Offline Icarus
« Reply #23 on: November 21, 2013, 07:53:01 AM »
Sounds like I need to take my carbs off again!  Well at least I can do it quicker each time.  Now I just need to decide if I should mess with my needle heights while I have the slides out.
Does the idle becoming crummy once heated make sense with dirty emulsifiers?  I had thought that if the idle circuits or something were getting clogged, it would always have trouble idling until they were cleaned.
1975 CB400F
1977 CB550K
Offline MoMo
« Reply #24 on: November 21, 2013, 09:33:04 AM »
If everything is stock, needle jet heights should be ok.  Make sure you clean the chamber that the emulsifier goes in...Larry
