Author Topic: no spark in 1,2, or 3 wires  (Read 1871 times)
Offline CBcafeJunkie
  • 75 CB750F
« on: November 23, 2013, 11:33:41 PM »
hooked up all the electrics and tried to bring the bike to life again but only fired on # 4 cylinder. I checked the wires as i started it with a timing light, the only one that would flash is #4. Any ideas? Im running a hondaman ignition and recently set the points.
  • 75 CB750F
Re: no spark in 1,2, or 3 wires
« Reply #1 on: November 24, 2013, 07:53:14 AM »
about to head out and check coil resistance any other ideas?
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #2 on: November 24, 2013, 08:43:23 AM »
remove plug boots, trim off 1/4" of the plug wires, and reinstall plug boots
  • 75 CB750F
« Reply #3 on: November 25, 2013, 08:09:48 AM »
I'll give it a try. :) thanks man
« Reply #4 on: November 25, 2013, 08:20:23 AM »
also connect your ohm-meter to your plug caps to check for resistance.
report your findings for all caps.
  • 75 CB750F
« Reply #5 on: November 26, 2013, 06:27:25 AM »
That is where i was originally going, but wanted to make sure I cover all my basis before I purchased new coils. Its exciting yet frustrating to be so close to hearing her roar just to have her choke.....no parallel intended lol
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: November 26, 2013, 07:50:57 AM »
I understand your test methods but the only for sure way to see if you have spark is to take the plug out, put it in the cap and lay it on the case when you turn the motor over and look for spark color. If you were really only sparking on one cylinder your motor wouldn't even hint at starting up. If you still have no spark then work your way back from there, coil, points, condensor, connections, etc.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
