Author Topic: SANDCAST ALERT!  (Read 15568 times)
Re: SANDCAST ALERT!
« Reply #50 on: December 21, 2013, 03:06:39 PM »
My brothers plans for the sand cast are a SOHCzone.com 1000cc kit with a custom billet cylinder block.
Anyone familiar with this company and there products?
http://www.cbrzone.com/sohc.html
Thats APE engineering mate, I have the 1000cc kit and their 970cc kit, Big Jay is a member here {company owner} they've been around since the 70 and if i'm correct, Jay was the one that originally had Wiesco make the original 836 kits, top shelf people, I also have a billet1000cc block with Nikasil bores.... ;D 8)
Offline Powderman
Re: SANDCAST ALERT!
« Reply #51 on: December 21, 2013, 05:33:17 PM »
Apparently they are only 20 miles from my brother.
« Last Edit: December 22, 2013, 01:48:10 PM by Powderman »
Offline Tews19
  • I am no
1970 Honda CB750 survivor.
Offline markb
  • When I finish my current project I might be a
Re: SANDCAST ALERT!
« Reply #53 on: December 22, 2013, 07:14:22 AM »
If he's going to do that he could starting with a much cheaper engine and sell the sandcast one to finance everything.  Maybe even come out money ahead.  That way he wouldn't ruin the value of the sandcast engine either.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Re: SANDCAST ALERT!
« Reply #54 on: December 22, 2013, 09:07:37 AM »
Well that d pendant on a few things..
 We're the cases ever cut for bigbore, and have they been welded?
 He said yes the filter mount had been broke, and welded.
 I guess as long as nothing shows externally it still will look ok for a restore. I am all for early hot rod engines, but not sacrificing a minty one. I got a set of diecast cases 10,*** that had a 1080 in it makes nor rod break damage.. That will be hotrodded, and I do not have an early frame for it..
Online Don R
Re: SANDCAST ALERT!
« Reply #56 on: December 22, 2013, 12:07:09 PM »
We shall see. Decent ones have been selling well I think.
Offline Powderman
Re: SANDCAST ALERT!
« Reply #57 on: December 22, 2013, 07:06:25 PM »
How different are the cases from year to year? I recommend using a different top half case to bore so that the SC can be put back to original if need be. Is there a different year top half that would bolt to a lower? Heck for that matter CB750 cases and motors are not so expensive that I wouldn't try and do the 1000cc build from anything other than a sand cast. He feels that having a 1000cc sand cast would be valuable, but I doubt it would be as valuable as a good restored stock sand cast motor, am I right?
Re: SANDCAST ALERT!
« Reply #58 on: December 22, 2013, 07:52:43 PM »
You can't swap upper and lower cases, period!
Offline Powderman
Re: SANDCAST ALERT!
« Reply #59 on: December 22, 2013, 07:54:23 PM »
Elaborate please.
Online Don R
Re: SANDCAST ALERT!
« Reply #60 on: December 22, 2013, 08:02:01 PM »
They are machined as a unit. If you mix and match uppers and lowers from different engines the machining will never be correct. Cases are marked for bearing size to maintain clearances.
 Has it been done? Probably yes, but that doesn't mean it ever ran well or for very long.
X2
Offline Powderman
Re: SANDCAST ALERT!
« Reply #61 on: December 22, 2013, 08:13:11 PM »
I see separate case halves on Ebay all the time including a sand cast top half right now for $3000. You're saying that it's basically useless without it's matching half?
Offline kmb69
Re: SANDCAST ALERT!
« Reply #62 on: December 22, 2013, 08:40:02 PM »
That is correct. And...that Seller is dreaming. He always asks at least 4 to 5 times what most stuff sells for. In this case, pardon the pun, that top case is essentially worth $0.
Re: SANDCAST ALERT!
« Reply #63 on: December 22, 2013, 08:41:52 PM »
Yup. Think of connecting rods: would you put a cap from one rod onto another, or a main cap from one block to another without line-boring?
Offline Powderman
Re: SANDCAST ALERT!
« Reply #64 on: December 22, 2013, 08:47:04 PM »
Understood.
Offline markb
Re: SANDCAST ALERT!
« Reply #65 on: December 23, 2013, 05:43:09 AM »
$9K for that?    It it worth it??
It's been up for a couple of days and hasn't sold for that price.  Sandcast listings don't go unnoticed for long.  If it hasn't sold yet I think the price is a little high but eventually someone may pay that.
Re: SANDCAST ALERT!
« Reply #66 on: December 23, 2013, 05:49:20 AM »
Thanks for the insight.  The sandcast selling prices sometimes blow my mind...
Re: SANDCAST ALERT!
« Reply #67 on: December 23, 2013, 09:00:08 AM »
An upper sandcast case has some value,if you want to build a non rider museum piece
 Spare the sandcast case, and grab another engine to hotrod
Offline Powderman
Re: SANDCAST ALERT!
« Reply #68 on: December 23, 2013, 09:02:34 AM »
I know it's a hard question to answer but what is a good sand cast motor alone worth?
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
Re: SANDCAST ALERT!
« Reply #69 on: December 23, 2013, 10:02:43 AM »
Depends greatly on the VIN, but a complete motor without chain break damage, the correct cylinders and head should bring $2K-$4K, IMO.
Offline Powderman
Re: SANDCAST ALERT!
« Reply #70 on: December 23, 2013, 10:25:22 AM »
It's #1644. Only damage welded was the oil filter that was rewelded and I'm not sure if any of the repair shows or not.
I was born in Berkeley.
Offline Greggo
  • Somebody's
Re: SANDCAST ALERT!
« Reply #71 on: December 23, 2013, 10:49:37 AM »
It's a cool town.  The college girls, and the culinary scene are among the best around ;)
If it was a solid repair that doesn't show, that shouldn't make any difference to the value.
Re: SANDCAST ALERT!
« Reply #72 on: December 23, 2013, 08:35:06 PM »
I was born in Beserkley.
Fixed it for you. ::) ;D
Offline Powderman
Re: SANDCAST ALERT!
« Reply #73 on: December 23, 2013, 08:37:42 PM »
That's how i have referred to it for 50 years. Born at Alta Bates Hospital and lived on Edith St.
Offline Prospect
Re: SANDCAST ALERT!
« Reply #74 on: September 09, 2014, 08:02:36 PM »
I'm not sure if only half of the cases would be a complete waste. Could you get a second nonmatching case and have the cases line bored? Then you would have to get custom bearings to match the crankshaft.  Expensive but doable.
« Last Edit: September 09, 2014, 08:16:54 PM by Prospect »
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
