Author Topic: 550 cam chain tensioner interchangeability  (Read 732 times)
Offline Adam_F
« on: January 16, 2014, 11:39:23 AM »
Howdy folks!  I'm amassing parts for a top end rebuild of my '77 550F.  Once I get everything together, I'll start a thread, post pics, etc...  But one of the main reasons for the rebuild (other than oil all over my boots) is that my cam chain tensioner is cannot be adjusted (very likely stripped).  I've seen the whole assemblies for sale on DSS, but they're definitely not cheap.  Considering going the ebay route, but just wanted to clarify things:
Are the tensioners from various 550 models all interchangeable.  For instance, could I use one from a '75 550k1 in my '77 F?  They look pretty identical, but I figured it couldn't hurt to ask before I buy something.
Thanks!  You guys rule!
'77 cb550F
Offline Deltarider
  • I'm back
Re: 550 cam chain tensioner interchangeability
« Reply #1 on: January 16, 2014, 11:51:08 AM »
They're all the same.
CB500K2-ED Excel black
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: January 16, 2014, 11:53:59 AM »
I had a problem with my tensioner as well. I removed it and found the teeth were out of line due to ham fistedness. A little persuasion with a hammer and it works fine now.
Get a look at your tensioner before you spend on it.
« Last Edit: January 16, 2014, 11:58:04 AM by LesterPiglet »
Offline Adam_F
« Reply #3 on: January 16, 2014, 11:55:18 AM »
Thanks to you both!
'77 cb550F
Offline jonda500
« Reply #4 on: January 16, 2014, 04:38:09 PM »
I also reserrected my tensioner - had to bend the tabs out to dismantle it so I could straighten out the bent teeth, ran a die over the thread with the screwdriver slot in it, reassembled it and bent the tabs back down. I think the tabs will probably break off if I ever have to do this again though.. Can't hurt to try, good luck!
A starter clutch thread:
