Author Topic: Drying gas tank after derusting  (Read 11634 times)
Offline Djfob
« on: April 03, 2014, 08:03:24 PM »
Been soaking my tank with evaporust, seems to be working well so far. Final step is to rinse with water, plan on using it asap. My question is what's the best way to dry it out?
I was thinking about just sticking a blow dryer into it but would it flash rust before I get a chance to fill it with gas?
78 CB750k
KayOne
Re: Drying gas tank after derusting
« Reply #1 on: April 03, 2014, 08:10:00 PM »
Rinse it with methanol (gas line antifreeze) , it absorbs water and evaporates very quickly with compressed air.
« Reply #2 on: April 03, 2014, 08:11:49 PM »
Djfob,
I've lined a few tanks and we used a low pressure,high volume air pump;it's been a while so I can't remember the brand.I stuck the hose in the tank and let it sit like that around 24 hrs. to completely dry out those tanks,it was required for the liner to stick well to the inside of the tanks to Completely Dry every inch of the inside.The problem was I couldn't see in there so better safe than sorry and I just left that air pump on for a long time...more if it was humid.
« Reply #3 on: April 03, 2014, 08:13:08 PM »
Would Rubbing Alcohol work also ?
Offline Garage_guy_chris
« Reply #4 on: April 03, 2014, 09:35:59 PM »
I have used a hair dryer in the past to dry out the tank, right down the filler neck.  another thing i have been doing is spraying in WD40 next to a compressed air blow gun to mist the tank thus stopping rust.
« Reply #5 on: April 03, 2014, 10:09:33 PM »
I've used alcohol and then a hair dryer. I didn't even blow it up. Then gas with 2 stroke oil.
Offline Djfob
« Reply #6 on: April 03, 2014, 10:35:41 PM »
Doesn't look like I can get denatured alcohol here in Canada. Though methanol ( methyl hydrate ) can be acquired easily.I'll go this route with compressed .
I've seen 2 stroke oil/fuel mix mentioned a few times from my google searches. Would it still be recommended even if I plan on using the tank right away?
78 CB750k
Offline ziltoid
« Reply #7 on: April 03, 2014, 11:01:45 PM »
This might be a good or bad way, I dont really know, but I think petrol and then inhouse ventilation works fine.
Make sure your tank is room temperature. Wash with water, pour it out and directly fill a liter of petrol in the tank. Wash it around, pour it in a container and repeat one more time.
Then put your tank by a ventilation-OUTLET from your building and let it lie there for a few days.
Its what i did and it worked perfectly :-)
Online PeWe
« Reply #8 on: April 04, 2014, 02:37:25 AM »
Use strong Vodka....
Reuse it later, mix with orange juice and you have another tool for the toolbox. :o
Offline 750K
« Reply #9 on: April 04, 2014, 02:48:26 AM »
Methyl hydrate works fine, I use it as my last step to flush out left over rinse water and follow up with compressed air till dry. Gas if I'm using it right away or 2stroke oil if its going to sit empty for a bit.
77 Cb750, 78 Kz1000
Offline solo 2
« Reply #10 on: April 04, 2014, 04:41:25 AM »
Just go to Canadian Tire or Rona, you can buy Methyl Hydrate in 1 liter and 4 liter, it's also great for cleaning paint, grease etc. off of paint. I'm sure you know but it is highly flamable so be aware of ignition sources.
You know you've achieved perfection in design, not when you have nothing more to add, but when you have nothing left to take away.
« Reply #11 on: April 04, 2014, 04:56:45 AM »
I have a Craftsman shop vac that also blows in reverse for use as a blower that dries out tanks very quickly with "165" mph wind. Even when dried a preservative is wise unless loaded with gasoline right away.
« Reply #12 on: April 04, 2014, 05:17:00 AM »
165 MPH WOW  ;D  ;D That's a Strong Wind.
Offline Gearheadgreg
  • Jamestown Rhode Island
« Reply #13 on: April 04, 2014, 06:02:09 AM »
Just had my son in laws Honda Shadow coated , stopped by to see if it was done , They did have a hair dryer stuffed in it to dry it,,,It came out nice !
2001 Honda Supercharged Valkyrie   <iframe width="480" height="360" src="http://s1218.photobucket.com/user/meloafer/embed/slideshow/"></iframe> Just having some fun
Offline Airborne 82nd
« Reply #14 on: April 04, 2014, 06:35:32 AM »
After it is dry I use fogging oil from the pressure washer section at HD or Lowes. with the tank upside down it covers the best every nook & cranny. Be carful what you use to dry depending on paint.
Offline jason405
« Reply #15 on: April 04, 2014, 07:15:52 AM »
Just did the tank cleanse and installed POR-15 liner. I dumped a whole quart of Acetone in once I drained as much water as I could out, setup a hairdryer to blow hot air in the filler whole. 20 minutes later, bone dry.
Offline Cevan
« Reply #16 on: April 04, 2014, 07:42:04 AM »
I'm about to use acetone to remove an old liner and then Evaporust to de rust the tank.
The tank will sit for a month or two without gas in it as I want to sandblast the exterior and paint it.
Any suggestions on how to prevent flash rust long term?  I'm hesitant to recoat it, especially given it's an F tank with a recessed fuel filler.
1972 CB500/4
1974 CT70
« Reply #17 on: April 04, 2014, 08:00:53 AM »
Think I would strip/ blast whatever the outside first then clean the inside incase grit etc gets inside. Also check carefully for pin holes etc on the bottom as that may have been part of the reason for the liner.
« Last Edit: April 04, 2014, 11:13:46 AM by ekpent »
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #18 on: April 04, 2014, 11:09:18 AM »
I don't think I would sand blast it. try the spray paint remover from Home Desperate. Works like a charm even on the flake layer.
I used my wife's haridryer. She wasn't too happy when I burned it out drying a tank. I'm sure you can get a really cheap one at the thrift store. They do work.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline dohcdelsol93
« Reply #19 on: April 04, 2014, 11:12:30 AM »
acetone...then hit it with redkote once it's been dry for 24 hours...let redkote cure for another 72 or so hours.
Never worry about rust again.  With ethanol fuel water is always a possibility.
i'd rather be sailing
Offline Jimsun
« Reply #20 on: April 04, 2014, 11:13:40 AM »
Im not sure if you've read the back of the evapo rust but it says that if you want to let it dry without the rust effect, you have to rinse with evaporust. This means using clean evaporust for rinsing the inside of your tank.
Btw, did you happen to find a cheap place, aside from crappy tire, to get evaporust?
74 cb550
« Reply #21 on: April 04, 2014, 11:21:27 AM »
I can't afford Caswells & I've heard about por15;I have experience w/ Redkote and highly recommend it !
                                     Prep is Everything  ;)
Offline Djfob
« Reply #22 on: April 04, 2014, 11:54:46 AM »
I read that but wanted it completely dry before I added gas to it.
Crappy tire now carries metal rescue for $25/gallon. Wish they had this when I needed it, would have saved quite a few pennies.
78 CB750k
Offline Jimsun
« Reply #23 on: April 04, 2014, 11:58:12 AM »
you can completely dry it too. It might take awhile.
74 cb550
