Author Topic: 1977 CB750 K7 Resto-mod, Knoxville  (Read 115101 times)
Offline AintNoEasyWay
Re: 1977 CB750 K7 Resto-mod, Knoxville
« Reply #500 on: July 31, 2015, 05:06:37 PM »
Here's a better photo, 1 to 4 left to right.
Although #1 pipe isn't getting hot, I just checked & it still has spark.
« Reply #501 on: July 31, 2015, 05:50:05 PM »
looks badly fouled from start up. Id say clean those plugs up really well, and see if #1 comes alive.
What could cause a plug to foul at start up, cal?
Offline enwri
  • So that noise is normal?
« Reply #502 on: July 31, 2015, 08:29:32 PM »
Are those are the old plugs?, lash out and get new ones, they will show up how each carb is performing easier.
did you clear tube it or bench sync it after you had all the bodies apart last time?
Maybe just check the level in the one that's not getting hot, or try screwing the mixture screw in and out to see if it picks up and fires. As they move out it gets a little more fuel at idle, in is less, can show if idle jets are dirty, if no effect, something is blocked or its flooding. Or the plug is dead.
Or the slide on that one is closed already before the others,(not synced) give it a bit of a rev to see if it picks up.
« Last Edit: July 31, 2015, 08:38:50 PM by enwri »
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
Offline Desert-SOHC
  • It's old
« Reply #503 on: July 31, 2015, 09:47:13 PM »
Aren't PD's the other way? Out lean in rich?
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline enwri
« Reply #504 on: July 31, 2015, 11:33:33 PM »
Richer and richer until they fall out, then it goes real lean real fast.
At least that's what I found.
8? XJ 550 meh...
« Reply #505 on: July 31, 2015, 11:36:08 PM »
These are the old plugs. I figured at get new ones after the first few rides anyway. No big deal to get them now. I took the carbs back off & checked the float in #3 along with the jets in it. In the photo above, #3 plug looks really dark in comparison to the others. Everything in the carb looked fine. Idle screws are all 1.5 turns out.
I bench synced the carbs last year before putting them on & syncing them with gauges. I will go ahead & get clear tubing tomorrow & try the clear tube method for the first time.
I'm wary of running it now because of the smoke. If I let it idle, I have smoke from #4 exhaust (around the collar), along with smoke around the carbs & even some from the exhaust if I play with the idle adjuster too much. I looked down at the piston in #4 after removing hat spark plug & it looked clean. The smoke around #4 could be because I used wd40 to clean some rust off one of the collars before attaching the exhaust, but I'm not even sure if it was #4 collar. Still doesn't explain smoke around the carbs.,I don't know if maybe the engine is overheating or something?
I don't know if oil is burning & maybe that's why my oil tank needed a refill or if that oil just went down in the engine to lube everything.
Offline enwri
« Reply #506 on: August 01, 2015, 04:15:38 AM »
A little bit of smoke and smells in the beginning is almost compulsory, paint curing, oily fingerprints and wd40 burning off, as long as it's not leaking oil it will be alright.
I'm expecting that no. 3 exhaust pipe to smoke for a while until it's burnt clean as well. (from inside)
Oil has now been pumped  through the filter and gearbox and has filled all the little pockets and traps, once they fill the rest can flow back to the sump to the scavenger pump, then back to the tank, whatever got retained in the cases needs to be replaced but only once. If it all goes missing over night and it's not on the floor, the checkvalve has leaked it all into the sump. (Rarely happens)
I wouldn't worry too much about getting it too hot, they can take some punishment in the hot, stop start traffic, even a little fan will let it idle for a long while.
Once you get all the cylinders firing just ride it around a bit and let it settle in, have a look at the plugs to make sure it's running ok, and make any adjustments (cables, brakes, chains, and things)
8? XJ 550 meh...
« Reply #507 on: August 01, 2015, 07:47:56 AM »
I may be losing oil but I'm not positive. I haven't started the bike today but the dipstick measurement looks lower. I replaced the check valve in the oil pump when I rebuilt it several weeks back. Is there a way to be sure I'm not losing all my oil into the sump without just seeing if it all disappears from the tank?
I just removed the tappet covers & am checking to see if oil is getting to the top end now.
Offline enwri
« Reply #508 on: August 01, 2015, 10:17:52 AM »
As soon as it starts it's pumping whatever has collected in the sump, back into the tank anyway. check it after it has run for a few minutes
If you shine a torch into the oil tank towards the front of the bike when it's running, you should be able to see the return oil circulating back in.
Should flick a bit of oil out of the exhaust side tappet hole when running, and be visible flowing towards the front drains if you look down towards the base of the exhaust valve springs with the torch.
8? XJ 550 meh...
« Reply #509 on: August 01, 2015, 01:28:11 PM »
Looks like my float levels may be way, way off...
Do I adjust down or up from here? I figure the float isn't allowing the bowl to fill all the way so I would need to lower the float. I set them to 12.5 mm, should I move to more like 14.5?
« Last Edit: August 01, 2015, 01:31:47 PM by AintNoEasyWay »
Offline oldhatt45
« Reply #510 on: August 01, 2015, 01:32:33 PM »
AintNoEasyWay,
Remember, there AintNoEasyWay.  (Sorry, couldn't resist.  :)  )
Looks like maybe your float valve may be hanging up on the bowl?????
Others have had the problem where the pin slides and gets stuck and others have had the problem where the pin is too long.
Check it when you pull the bowl off.
Charlie
« Reply #511 on: August 01, 2015, 01:58:04 PM »
Yep, chose the right username!
All of them are riding to this same level. I guess it's possible that they're all hanging up, but seems unlikely...
Offline Desert-SOHC
  • It's old
« Reply #512 on: August 01, 2015, 01:58:21 PM »
I started at 12mm and ended up at 14mm and it runs MUCH better there. I believe the factory recommends 14.5mm. It looks likes there is almost no fuel in your bowl and if it doesn't cover the idle jet completely that cylinder will starve for fuel.
11 Ranger S/C 2wd
« Reply #513 on: August 01, 2015, 02:12:31 PM »
Yea, I'm wondering if this is a big part of my problems!
Offline enwri
« Reply #514 on: August 01, 2015, 02:50:58 PM »
Yeah, that doesn't look quite right, the level should be just a few millimetres down from the top edge of the bowl.
The clear tube thing isn't as straight forward on the pd carbs because we block a vent to do it. We somehow have to get rid of the air bubble in the tube, without pushing fuel back up the overflow.
    It's hard to explain how though, I'll try anyway..
If you drop the open end of the tube down a bit (to make the loop bigger) with the drain screw open, it should allow more fuel in the tube, let it fill a little, close the drain. When the bubble is at the base of the overflow opening again, lift the open end up slowly until the air has just been pushed back up into the carb, open the screw slowly and slowly drop the open end a little, if more air appears, do it again.
When there is no bubble and the screw is open the fuel level should rise to almost the top edge of the bowl, if you slowly drop the end again, it should rise back up to mark again. If it floods and keeps rising the upper body vents may be blocked.
The 12mm float level will fill the bowl in theory 2mm higher than the 14mm level, It's the buoyancy of each individual float that detemines the fuel level at any given measurement.
We assume that all the floats have the same buoyancy as brand new standard floats when we set them by measurement alone.
Trouble is they often aren't quite exactly the same.
 So we check the actual fuel level and adjust the float level measurement to reach the desired level instead.
I'm pretty sure you were getting way too much fuel on yours though, the jet that fell out slows down/meters how much fuel it could pull in, without it , it was pouring in, so much it couldn't set it alight in the cylinder.
8? XJ 550 meh...
Offline enwri
« Reply #515 on: August 01, 2015, 04:55:59 PM »
went and tried it out again, clear tube video.
It's a little difficult to see the level sometimes, but you can see what I mean about the air bubble bit.
And set the resolution to hd to see better
« Last Edit: August 01, 2015, 05:04:12 PM by enwri »
8? XJ 550 meh...
« Reply #516 on: August 02, 2015, 06:08:34 AM »
Enwri, that was an excellent explanation. Thanks for taking the time to share the video & write that out. I had to play with the tubing like you did in your video but the levels came out right after all. One less thing to be concerned about & now I'll move on to trying to find out why cylinder #1 isn't firing & whether or not in losing oil.
I filled the oil tank yesterday & as far as I can tell, it's still full this morning. I'll go get some new spark plugs today & then start up the bike to see if/how oil is flowing.
Offline Desert-SOHC
  • It's old
« Reply #517 on: August 02, 2015, 10:22:09 AM »
YUP.....that looks much better
11 Ranger S/C 2wd
« Reply #518 on: August 03, 2015, 06:52:11 AM »
All the local shops are out of NGK D8EA spark plugs so I just cleaned up my old ones last night & checked the valve clearances. When I get home tonight I'll try another start, watch the rocker arms & check the oil tank while it's running.
« Last Edit: August 03, 2015, 08:14:37 AM by AintNoEasyWay »
« Reply #519 on: August 03, 2015, 06:06:55 PM »
Alright guys, I got #1 firing again. I guess the plug was just fouled. I'm not sure.
I let the bike idle for about 5 minutes just now. I can't get it to hold idle for under about 1500, otherwise it starts to spit & sputter. I've got smoke coming from my exhaust though. Here's a video:
Is this to be expected somewhat during first few start ups?
« Last Edit: August 03, 2015, 06:11:55 PM by AintNoEasyWay »
Offline Desert-SOHC
  • It's old
« Reply #520 on: August 03, 2015, 06:22:37 PM »
With pretty much a new top end a little smoke is expected. You need to get it out and run it for a bit and then see whats up. JMO
11 Ranger S/C 2wd
Offline enwri
« Reply #521 on: August 03, 2015, 09:58:43 PM »
That sounds pretty good, hopefully that's just the wet crud in no3 and the silencer drying out. Like Desert says, get it out moving and loaded, no drag starts but just use it a bit, there's different opinions about bedding new rings but just vary the load and go up and down the rev range rather than just idling. Some people swear by babying it for ages, others say load it up throttlewise, not necessarily redlining it, but just keep varying speeds and loads.
I'm pretty sure more than a couple of people would have rolled them out the shop brand new, and found out if they really could do 120mph the first chance they got.
It wasn't bored was it? Just rings? Look up a break in thread, lot's of opinions.
Personally if was new rings in an old bore, the clearances aren't as tight as new pistons and rings, I'd just be a little easy on it in the beginning, and end up riding it fairly normally in a day or two.
Change the oil and filter after a while, before it's due the normal service interval anyway.
You'll have to ride it to see if it the carbs are working ok anyway. Plugs will probably just go black idling.
8? XJ 550 meh...
Offline enwri
« Reply #522 on: August 03, 2015, 10:09:08 PM »
I'm also assuming the you had oil flicking out all over your headers and new paint when you had the caps off. More smoke but it'll burn off quick when you're moving, or fill up your garage pretty quick too. It is well ventilated down there isn't it? It'll probably idle on for a fair while after you get your lethal dose of carbon monoxide.
The idle thing,,, once it's out and about up to temp. it may just be mixture screw adjustments it needs, they pretty much control the idle and off idle running. That sounds like mine with the choke out . (a little rich)
You can try moving them all in or out 1/4 turn at a time and listen for the highest idle. (then back off the idle speed adjuster)
I think you richen them a touch after the best idle is found. That could also be BS, two strokes hate being lean, it might just be them.
« Last Edit: August 03, 2015, 10:23:41 PM by enwri »
8? XJ 550 meh...
« Reply #523 on: August 03, 2015, 11:01:17 PM »
Great. Yes, it only had a hone, no rebore. New rings of course. I removed the tappet covers as you suggested & did have oil flinging out all over the front of the head & onto exhaust, so all of that was burning off. My mixture screws are all just 1.5 turns out at the moment.
I'll do as you recommend & try riding it easy to see what happens. My oil is exremely dirty by the way. I'll probably change it out very soon. I think it's because of the oil tank,which I didn't clean out during top end rebuild.
Offline Restoration Fan
  • My wife will never call me
« Reply #524 on: August 04, 2015, 05:22:43 AM »
The dirty oil may be your problem with the smoke.  Once you change the oil, you might find the amount of smoke diminishing or disappearing.
