Author Topic: 1974 CB350F - First Restoration  (Read 26745 times)
Re: 1974 CB350F - First Restoration
« Reply #100 on: May 28, 2014, 07:44:29 PM »
Sounds like it needs valve lash and cam.chain adjusted.
Just use the choke to get it started, and as the rpms climb as it warms up, take.the choke off.  Your idle set screw should be turned in more than it is to hold the idle.....
Offline trent
« Reply #101 on: May 29, 2014, 03:43:08 AM »
Mark, feel free to send me some info, I'd like to get together with some locals. trentbrendel@hotmail.com
Offline mark9331
  • 1974 CB350F
« Reply #102 on: May 29, 2014, 08:45:44 AM »
Question on carburetor slide gap. I gapped them by using wd40 straw for spacing. Should I have left more of a gap?
Offline HondanutRider
« Reply #103 on: May 29, 2014, 09:28:32 AM »
The amount doesn't matter, just that they are all the same and a slight opening is left.  That gap determines how much mixture is allowed through the carb when no throttle is applied.  It then would be adjusted during the synchronization procedure so that each cylinder draws and works the same.  The synchronization would also set the base idle speed which is also governed by the choke (should increase it when applied) and also the idle stop (which advances the speed by turning the whole rack mechanism at the idle stop).  When doing a synchronization, the choke advance should be off as also should be the idle stop.  You might want to set the idle stop slightly on when doing a synchronization, so that the idle speed could be lowered some more after the synch.
Offline jamesv220820
« Reply #104 on: May 29, 2014, 10:21:58 AM »
looking good so far!  Hey if you find yourself in the garage can you do a couple measurement for me? ( since my bike is in boxes)
Can you measure the distance from the top of the headlight bucket to the the gauges, where they hit?
And Also the front of the headlight to the gauges.
I ask because I was thinking about getting this little headlight shield and getting it painted the bikes color.
I need to see if the guages will clear it or if I need to get a small coupler nut to life the gauges ever so slightly.  thanks
-cheers
-james
There is nothing to fear but fear itself . . . and trying to restore a cb350f
« Reply #105 on: May 29, 2014, 11:04:52 AM »
You really can use anything to set the gap, but just verify your slides completely close when turning your idle set screw OUT and its tip loses contact with its tang....
Offline mark9331
  • 1974 CB350F
« Reply #106 on: May 29, 2014, 04:13:19 PM »
So I think something in the carb is not perfectly clean.  It does not want to idle and when I open the throttle at low idle it simply dies.  So I think it could be a problem with something not being clean since it appears that it is able to run off the gas from the choke and not really getting any gas when I open the throttle or close the choke.  Suggestions on what I should be looking at or cleaning?  I am going to have to tear the stupid carbs off again... Oh well I am getting really good at this!  It is just a pain to get them back on with the air box....
Offline mark9331
  • 1974 CB350F
« Reply #107 on: May 29, 2014, 04:14:30 PM »
-cheers
-james
I will when I go down a little later.  That guard would look nice painted!
Offline mark9331
  • 1974 CB350F
« Reply #108 on: May 29, 2014, 04:15:59 PM »
Started watching Long Way Round and I am absolutely convinced I need a BMW now!  Maybe in a couple years.
« Reply #109 on: May 29, 2014, 08:00:01 PM »
thanks mark
« Reply #110 on: May 29, 2014, 08:43:01 PM »
I'm feeling the need for a new BMW S1000R naked bike!
« Reply #111 on: May 30, 2014, 12:16:04 AM »
Admit it, you just feel the need to be naked, Don.
I spent the day Tuesday with my brother who was out from Riverside at the dealership. Still have a woody over the '14 K1300s. Putting some of my older bikes up for sale to squirrel away some dough for that dude- I just hope that fund doesn't get eaten up with the R90 project  :-\
Pardon the thread jack. I'm feeling the serious pull to sell my beloved RC51 to start a S1000R fund. Absolutely amazing bike, and a more comfortable riding position, and it out-performs the RC51.
Anyone interested in a pristine RC51 SP2 with less than 6800 miles?
Offline mark9331
  • 1974 CB350F
« Reply #112 on: May 30, 2014, 08:25:55 PM »
I could have told you that! SOHC bikes are great. But BMW bikes are amazing. It would be a very complement to your 350
I think it would be a nice balance to have the 350, the 600 RR and the BMW... Just my opinion.  I will see if I can convince her of that lol.
Offline mark9331
  • 1974 CB350F
« Reply #113 on: May 30, 2014, 08:43:59 PM »
-cheers
-james
Let me know if I did not get something measured right!!
« Reply #114 on: May 31, 2014, 10:23:46 AM »
you are the best mark!  I appreciate it!
cheers
-james
Offline mark9331
  • 1974 CB350F
« Reply #115 on: May 31, 2014, 10:51:40 AM »
cheers
-james
Let me know if you need more measurements! No problems at all!
Offline mark9331
  • 1974 CB350F
« Reply #116 on: June 09, 2014, 07:38:46 PM »
Uhh...  I have been bad about posting for awhile.  First I was getting prepared for the trip to the vintage races in Wisconsin and I also took a weekend off from working on the bike.  The trip to the races was great!  I saw a couple other CB350F and one was for sale at $1200 not restored and seemed to be in a little rougher shape than mine so that was nice.
Either way I jumped back in today.  I am still having major problems with my idle.  I am not sure what it is.  When the choke is on it seems to run like it is supposed to.  I let the engine warm up and then turn the choke off it still wants to die.  I just replaced the slow jets with "stock" new ones.  No difference.  I also checked my idle screw.  I ended up screwing it in pretty far just to be sure that I did not have it out too far.  Still nothing was working.  With the choke on I am able to put it into first and walk it around fine.  Not sure what else could be causing this.  Any suggestions?
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #117 on: June 09, 2014, 07:40:40 PM »
Points adjusted ?  Mess with the throttle cables at all?
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
« Reply #118 on: June 10, 2014, 04:41:43 AM »
You probably need to adjust the idle stop position to give it more gas when idling.  Study how the choke mechanism pulls the throttle on slightly and how the idle stop prevents it from returning.  You should be able to observe these linkages when you activate the throttle and choke without the motor running.
Offline coal909
« Reply #119 on: July 01, 2014, 08:26:40 PM »
hey you might find these videos pretty helpful, the guy does a great job on explaining and filming plus it's the same model
https://www.youtube.com/watch?v=QlEW3q7eYEU&list=PLBfq8Rf4JUQoor8yv3uyMdadpXoksUDHY
