Author Topic: 550 - NO SPARK  (Read 6471 times)
Offline Anton
550 - NO SPARK
« on: June 13, 2014, 10:21:00 PM »
Hey guys,
So after a looong Fall/Winter/Spring of rebuilding my CB550F I finally got everthing tied together the other day and was hoping to start my bike up for the first time. And just my luck none of the plugs have  spark >:( .
The members of this forum is the only reason I have been able to make it this far (with absolutely no experience with motorcycles at all). I feel like I'm soo close, but also very lost as to what to do next. I'm hoping someone can walk me through this and help me get this bike on the damn road already.
So like I said none of the plugs have spark. All the electrical is working that I can see. I am running Pamco electronic ignition, some aftermarket coils from DCC -(http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-electronic-ignition-parts-universal-12-volt-ignition-coil-si-165-2.html). and NGK Wires and Caps.
I also tried to set the timing with a 12V test lamp, wasn't getting anywhere with that either
I dint really know what other information I can give, any help is greatly appreciated.
Thanks
Offline cameron
Re: 550 - NO SPARK
« Reply #1 on: June 13, 2014, 11:15:51 PM »
I assume you have new plugs, yes?
Start from the battery.
Post your voltage.
Then check voltage at the spark plug WIRES. Yes? No?
If yes, how much? If no. back up. Keep backing up till you find the broken thing.
If you are sending good voltage to a good spark plug, it must spark, right?
1976 CB550F
Offline pamcopete
  • Ride. Enjoy. Life is simple
    • CB750Ignition
Re: 550 - NO SPARK
« Reply #2 on: June 14, 2014, 04:12:42 AM »
You will not see any voltage at the plug wires with a dual output coil. Check for battery voltage on the red wires going to each of the sensors with the key and kill switch on. You should also have battery voltage at each coil as well just like it was with points. Some people make the mistake of using the coil power wire to power the PAMCO forgetting that the coil still needs power. Of course, check your fuses as well. Also, because you say you are new to motorcycles, just a reminder that you only get spark at the plugs when the engine is turning over or running.
Start with the slots in the plate at their mid point. That will be close enough to get the engine started, but you must use a timing light to set the timing. You can use the timing light even when you are attempting to start the engine to show if you are getting spark.
« Last Edit: June 14, 2014, 04:15:04 AM by pamcopete »
Offline Anton
Re: 550 - NO SPARK
« Reply #3 on: June 14, 2014, 03:51:33 PM »
Hey Pete,
So just to clarify, how exactly do I check for voltage at the red wires. I have a multimeter, still not exactly sure how to use the thing. I have o set to DC and put the red lead to the red wire and the black lead to bare metal on the frame? Not getting any reading that way. Sorry for my ignorance, but electronics is just not my game.
Offline pamcopete
    • CB750Ignition
Re: 550 - NO SPARK
« Reply #4 on: June 14, 2014, 04:29:57 PM »
Hey Pete,
The red wire going to the PAMCO sensors should be connected to a source of switched battery. Switched meaning that there is only power there when the key is on.
You can get this switched battery directly from the wire that goes to the coils that has switched power, so use your meter to check for power on one of the terminals on the coils. When you find that, then connect the red wires from the PAMCO to the same coil terminal with the wire coming from the source of power, not the terminal that used to go to the points. The other coil terminal that used to go to the points now goes to the green wire to the PAMCO.
« Last Edit: June 14, 2014, 04:43:09 PM by pamcopete »
Offline Anton
Re: 550 - NO SPARK
« Reply #5 on: June 14, 2014, 04:50:00 PM »
Iv got the green wires going to one terminal on each of the coils. Iv got both red wires joined together and connected to the kill switch
Main wire and Iv got two more wires going from the coil connection from the harness to the other terminal on eAch of the coils.
Now if I put the red lead from my mulitmeter to one of the coil terminals and the black lead to the negative battery terminal should I get some kind of reading ? Nothing is coming up..
Voltage from my battery is reading 13.1
Offline DavePhipps
    • Hillside Technology
Re: 550 - NO SPARK
« Reply #6 on: June 14, 2014, 05:16:56 PM »
Have you checked for continuity at the kill switch?
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Anton
Re: 550 - NO SPARK
« Reply #7 on: June 14, 2014, 05:32:08 PM »
Yes I have continuity at the kill switch
Offline Anton
Re: 550 - NO SPARK
« Reply #8 on: June 14, 2014, 05:33:26 PM »
Anton - you're checking the switched power with the key "on", right?
Yes checking power with the key on Cal
Offline Anton
Re: 550 - NO SPARK
« Reply #9 on: June 14, 2014, 05:34:46 PM »
All other electrical components at working
Re: 550 - NO SPARK
« Reply #10 on: June 14, 2014, 05:42:11 PM »
How are you checking for spark?   You have plugs out of the engine, connected to the plug wire, resting on the cyl head and hitting the starter button?
Offline pamcopete
    • CB750Ignition
Re: 550 - NO SPARK
« Reply #11 on: June 14, 2014, 05:44:12 PM »
Did you check the fuses? Are you getting +12 on the red wires that come directly from the kill switch? There is something very basic here that you are not seeing. Take a deep breath and another look at the wiring. It's going to be something really simple.
Offline Anton
Re: 550 - NO SPARK
« Reply #12 on: June 14, 2014, 05:49:46 PM »
Yes but no start button, just kicking over. An I only have one plug out
Offline Anton
Re: 550 - NO SPARK
« Reply #13 on: June 14, 2014, 06:00:32 PM »
So I just realized I had no power going to the kill switch.
From my left hand controls I have two kill switch wires. White and blue(kill switch main) with a female and a male connections and a black and white (kill switch ground) with the same two connections.
Origianlly I had the main wire from the switch connected to the kill switch connection from the harness and the kill switch ground connected to the ground wire from th harness. But I need power into the kill switch to power the coils right? So I took the male connector from the blue/white(kill switch main) and plugged it I to the power wire from The harness and connected the red wire from the Pamco unit to a power connection from the harness as well, turned on the power and blew a fuse...
What am I missing?
Offline Anton
Re: 550 - NO SPARK
« Reply #14 on: June 14, 2014, 06:38:32 PM »
Is the kill switch a ground switch like the neutral oil pressure switches?
Should I have the kill switch main wire grounded and the kill switch ground wire plugged into the kill switch wire from the harness?
Offline Anton
Re: 550 - NO SPARK
« Reply #15 on: June 14, 2014, 08:12:39 PM »
Have blown 5 fuses now, any thoughts guys?
Offline goldarrow
  • one day, i'll be an
Re: 550 - NO SPARK
« Reply #16 on: June 14, 2014, 08:51:01 PM »
CB550 K0
Offline Anton
Re: 550 - NO SPARK
« Reply #17 on: June 14, 2014, 10:31:59 PM »
Never mind, got it!
Thanks for all the input guys!
Re: 550 - NO SPARK
« Reply #18 on: June 15, 2014, 06:34:42 AM »
Never mind, got it!
What was it?    Plz post the solution for others to use this info in the future.
Offline pamcopete
    • CB750Ignition
Re: 550 - NO SPARK
« Reply #19 on: June 15, 2014, 08:20:31 AM »
Never mind, got it!
Anton...Anton...wait wait! Don't go away! We are all wondering what it was and how you fixed it. Others may have a similar problem, so you could help by sharing your experience.
Offline Anton
Re: 550 - NO SPARK
« Reply #20 on: June 15, 2014, 10:36:52 AM »
So like I said in an earlier post, I realized I didn't have any power going to the coils. After trying many different wiring configurations with the kill switch wires (main and ground), power wire from the harness and the red wires from the unit and about 6 or 7 blown fuses, I got an email from my saviour Matt from Sparckmoto (who I had emailed earlier in the day but hadn't heard back from). He had built me the new wiring harness and has offered some of the best tech support/customer service I have ever experienced in my life (highly recommended if your looking for some brand new wires for your bike, and he'll customize it to exactly what you want).
Anyway, he suggested trying the Blue/white wires (kill switch main) from my left hand controls connected to the power wire from my harness and the red wires from the PAMCO unit tied into that and the black/white wires (kill switch ground) to the coils. BINGO we have spark!
So f*#^kin easy right??
Now it was time to start her up, I kicked her over a few times and i was just getting backfires every other kick with some flames out the exhaust , didn't sound like she was going to go at all. So I switched the green wires at the coils coming from the Pamco unit and after a few kicks she started up! only ran for about 5 seconds and backfired again and shut down, it was pretty late at this point and sounded like there was a shootout  in the garage so I left it at that, I was just soo happy to hear some life out of her after this long! Back at it again today!
Offline Anton
Re: 550 - NO SPARK
« Reply #21 on: June 15, 2014, 10:47:13 AM »
Now just wondering about setting the timing . I did do a slight top end rebuild, the cylinder bores have been honed and new rings. Iv been doing a lot of reading about proper break in procedures and from what I gather I shouldnt really let it idle for any period of time, sooo how do I work around this to get the timing right?
Re: 550 - NO SPARK
« Reply #22 on: June 15, 2014, 11:41:39 AM »
Do it the static way as described in the manual.
Offline Anton
Re: 550 - NO SPARK
« Reply #23 on: June 15, 2014, 11:47:26 AM »
And then just wait until after I get a few hundred miles on her to set with timing light?
Re: 550 - NO SPARK
« Reply #24 on: June 15, 2014, 11:56:13 AM »
Others may comment on break-in procedure. I have no experience with that.
