Author Topic: Ignition timing/spark advancer  (Read 5250 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: Ignition timing/spark advancer
« Reply #25 on: August 28, 2014, 04:43:48 AM »
You spend more of your time riding at full advance. Don't worry about it.
She's got no go. she sounds good, I can ride her out of the driveway, but If I try to do more than 10-15 mph, she just falls on her face. No acceleration.
sounds more like an air/fuel mixture imbalance (jetting or dirty carbs) to me....
Agreed. This wouldn't be caused by your idle timing being slightly off.
--Evan
1975 CB750K "Rhonda"
Offline dgedinyte
« Reply #26 on: August 28, 2014, 05:55:01 AM »
$#!+ really? She sat all winter with definately enough gas to fill the petcock. I emptied and cleaned it( not really, I just swished some new gas around in and dumped it a few times to get rid of any old gas and visible debris. I've never worked on one of those. But it sounds simple enough.
Sometimes it takes pain to shed the light of wisdom and understanding on things that the vision of knowledge itself would never have allowed us to see.
Offline evanphi
  • Apparently I'm an
« Reply #27 on: August 28, 2014, 06:14:20 AM »
If there was visible debris coming out of your tank after it sat, your petcock and filter (if you have one) would have that same debris in it.
--Evan
Offline dgedinyte
« Reply #28 on: August 28, 2014, 06:27:21 AM »
This is that moment when you just wanna take off work and fix your motorcycle. It was minimal and sedimentary but it was there. The inside of the tank looked good and I just now learned that there is a filter in there. I've never had cause to remove the petcock. I've only owned the bike for about four years, and she was always a strong runner. I've been doing dilligent maintenance but this is something I overlooked. You guys are awsome.
Offline dgedinyte
« Reply #29 on: August 30, 2014, 06:34:10 PM »
I started work on this thing again today. I must have gotten a little aggressive with the stud that the  spark advancer rides on when tightening the 10 mm nut. Yep, I sheared off just enough so that it's useless. I'm not sure if is the kind that is screwed or pressed in to the crank. Can anyone help me out? It's a 75 cb750k. Also anyone know the oem part name of that little beauty. I've heard it called several different things. I would usually look up a replacement to get a feel for how it is installed but I don't know what to call it.
Offline Tews19
  • I am no
« Reply #30 on: August 30, 2014, 06:40:36 PM »
I am not sure of the name. But if it just screws off I have a spare engine I may be able to take it off
1970 Honda CB750 survivor.
Offline dgedinyte
« Reply #31 on: August 31, 2014, 06:56:07 AM »
That would literally save my bacon. Obviously you can name your price. I would be eternally grateful!
Offline Tews19
  • I am no
« Reply #32 on: August 31, 2014, 07:06:32 AM »
It be free.
« Reply #33 on: August 31, 2014, 09:45:45 AM »
The shaft is a stud, threads in both ends. Part no. 30231300010   Not available
Do not forget the o-ring 6x2.3mm
pos 8, 14   http://www.cmsnl.com/honda-cb750-four-k5-usa_model483/partslist/E++07.html#results
EDIT: Yamiya750 has.... Japan They have plenty of goodies for a CB750. I'll order these next time...
http://www.yamiya750.com/index.php?main_page=product_info&cPath=21_55&products_id=55
http://www.yamiya750.com/index.php?main_page=product_info&cPath=21_55&products_id=56
« Last Edit: August 31, 2014, 09:52:24 AM by PeWe »
Offline Tews19
  • I am no
« Reply #34 on: August 31, 2014, 01:56:07 PM »
Dg, I checked the spare engine and it is sheared off. Sorry about that.
Offline dgedinyte
« Reply #35 on: August 31, 2014, 06:18:55 PM »
Tews19, no worries man. I sincerely appreciate the effort. PeWe Thanks for the info. At least now it doesn't seem like the world's end.
« Reply #36 on: September 02, 2014, 10:09:46 AM »
This thread made me to order one stud with o-ring from Yamiya together with other nice stuff!  ;D
Nic
« Reply #37 on: September 03, 2014, 12:30:44 AM »
I recently put a 2.5mil Oring on my points shaft, fitted well and easier to source and you'd need your head read paying $2.50 for an O ring of any size let alone one that small.
« Last Edit: September 03, 2014, 03:18:42 AM by Nic »
