Author Topic: Help a Newbie  (Read 3254 times)
Offline rsank
Help a Newbie
« on: September 18, 2014, 03:36:35 PM »
My apologies if this was covered in another post but please point me in the right direction.
I got this bike a few days ago and the fool that I am, I thought the PO did a pretty thorough job on the bike, but I got stuck on my second ride with the main fuse blowing. I fixed that and cleaned up the fuse box, rode it again the next day with no issues.
Now I have a new problem. Took it out to ride today and:
1. It starts up fine. I warm it up for a minute and start out.
2. It dies just as I am leaving home.
3. I push it back and try the electric start. No juice.
4. Check the battery voltage and its showing 9V (it was a healthy 12.4 volt until yesterday).
5. When ignition is off, the battery climbs back slowly but since it has been through hell with attempted starts, it is now only at 11.8V.
6. When ignition is on and after the battery has recovered, I can kick start it but when I measure voltage across battery terminals, there is no charging, the voltage keeps dropping.
7. When voltage reaches about 7v, the bike dies, I guess from too little voltage for the coils.
8. Everything is stock on this bike. As far as I can tell, PO only replaced the spark plug boots and wires. The rectifier, regulator, blinker etc., look completely stock to me. They are pretty dirty on the outside too.
9. It was charging fine until yesterday.
10. After the episode with the fuse box, my main suspicion is dirty connectors, which I am going to start on today. Of course it could also be something else.
Can you give me some pointers on which connectors to clean?
After I clean connectors, I will go through the step by step diagnosis of charging issues. Inputs and suggestions please!
I also forgot to mention that when I measure the voltage across the battery terminals and engine is at 2k rpm, I do notice a higher voltage than at idle. So it appears that it is trying to charge but the voltage is not high enough?
« Last Edit: September 18, 2014, 03:44:11 PM by rsank »
Offline Pat_at_APE
    • APE Race Parts
Re: Help a Newbie
« Reply #1 on: September 18, 2014, 03:43:34 PM »
Let us know what model and year you are working on.  It's helps you get specific answers.
Unfortunately I'm no expert in this area.
My CB550 drained the battery until you got over 4000rpm so maybe you just need a good fully charged battery.  Before you go too far charge it up fully checking all the fluid levels and go from there.   If the battery was low it would not even start/run.
Good luck!
Pat at APE
Offline bjbuchanan
Re: Help a Newbie
« Reply #2 on: September 18, 2014, 03:52:16 PM »
Like Pat said, they don't charge at idle so it is definitely a contributing problem.
I am linking TwoTired's post on the subject. If you follow the steps methodically as written you can rule out and diagnose the exact problem. If you get no hits from his write then you have a bad wiring connection, really dirty wiring or a bad battery. If you have a bad battery then you probably can't test too good, the battery depletes too fast.
Make sure your battery is filled to the proper levels and charge to full voltage, rest for two hours then test again to see voltage. If it is under 12.5v it is bad.
http://forums.sohc4.net/index.php?topic=112853.0;nowap
Re: Help a Newbie
« Reply #3 on: September 18, 2014, 04:09:03 PM »
The stock bike doesn't need a warm up to drive.
May have a charging issue, may have an excessive drain issue.  Is the bike stock or modified?  If modified, list the mods, particularly anything electrical.  Coils, headlight, ignition, search lights, etc.
It still needs a good soak charge.  Which will have to be done BEFORE you do charging system checks.
At what RPM?  They won't charge at idle.  the stock bike needs over 2000 RPM to provide enough for just the standard electrical load.  Even higher RPM to charge the battery.
yep
Still have the points?  Replaced wires could mean the coils were changed, too.  The CB550 doesn't charge well with extra load from 3 ohm coils.
How do you know it was charging?
Clean connectors can only help.  But, you need to look at other things, too.
If any need cleaning, they all need cleaning.
A good battery does not gain or lose voltage rapidly.  It will take about 10 hours at 4000 RPM for the bike to charge a dead battery.  ...Which is why an off bike charger is usually employed for this purpose.  And that is where you should begin the investigation.
Charging system methodical verification checks, CB750, CB550, CB500, CB400, and CB350.
Begin with problem verification and characterization with recorded data.
A -- Fully charge a known good battery.  Let it rest for 2 hours, off the charger, and measure the battery voltage.  (Target is 12.6-12.8V.)
B -- Start the bike and measure the battery voltage at idle, 2000, 3000, 4000, and 5000 rpm.
C -- Repeat the measurements of B with lighting off.
The above tests identify charging system success, failure, or degree of "faulty".  The success voltages are listed in the Shop manual.
D -- Assuming the above indicates faulty, do check the RECTIFIER diodes with a diode tester or ohmmeter capable of testing diodes and uses more than .7 volts to make the test(s).
Of the twelve test made in D, six must read low ohms and six must read very high ohms.
E- assuming no faults were found in D,  Measure the white and green wires disconnected from the REGULATOR.  CB750s should 6.8 ohms - ish,  CB550s/350s/ and 400s should read 4.9 ohms- ish.
F- If there are no bullet holes or road rash/divots on the alternator case, the stator is probably good.  But, you can check for yellow to yellow continuity (.35 ohms) among all the wires, and that no yellow wire has continuity to the engine case.
G- Assuming no faults found in D, E, and F, measure the disconnected terminals of the REGULATOR.  The black and white terminals should measure zero ohms (subtract meter error if there is any).  Higher than Zero ohms, indicates internal contact contamination needing cleaning and attention per shop manual.
H - Assuming D, E, F, and G have not found faults. We can verify all the of the charging system minus the regulator is functioning correctly, by using a temporary jumper to connect the disconnected white wire (normally attached to the REGULATOR) and connecting the White directly to the the battery POS terminal.  Repeat the B and C tests.  However, if at any time the battery voltage rises above 15V, stop the test.  Such an indication would prove the charging system capable of maintaining a known good battery.  If this test never achieves 15V, then there is a wire/connector issue in either the ground path leading back to the battery NEG terminal, a wiring/ connector issue withe the rectifier RED path to the battery POS terminal, or you made a mistake in D through G.
I - (not used, can be confused with L)
J -  The only parts that remain to prove or expose are the REGULATOR (in active mode) and the electrical path between the battery POS terminal and the black wire that connects to the REGULATOR.
K - Lying to and starving the regulator
The regulator can only do its job correctly if it gets a proper voltage report of true battery voltage status.  The Vreg monitors the Black wire for this status.  Measuring the voltage lost between the Battery terminals and the Vreg connections identifies problems that are not really the charging system's fault.
Two connection paths must be checked, the Battery POS terminal to the Black wire connection at the VReg, and the Battery NEG terminal to the Green wire connection to the Vreg.  A volt meter can measure these losses directly by placing a probe between the two identified points, Black path and then the green path.  The numbers are summed and the error seen by the Vreg quantified.  Anything over .5V loss is cause for concern and anything over 1V is a certain issue to be corrected.  Each connector, terminal, fuse clip, or switch in the pathway can cause voltage reporting loss.
The regulator also passes the received voltage on to to the Alternator field coil to create a magnetic field within the alternator,  The voltage level determines the strength of the magnetic field and the maximum output capability of the alternator.  Therefore, starving  the Vreg of true battery voltage leads to reduced max output capability of the alternator.
L - regulator operation/verification.
  The Vreg sends voltage to the alternator field in response to measured voltage which is battery state of charge.  Any voltage at the battery of less than 13.5V sends full black wire voltage to the alternator's white wire.  The alternator output will vary with RPM, even if "told" to produce max power by the Vreg.  If the alternator has enough RPM to overcome system load, any excess power is routed to the battery which will raise the battery voltage (slowly if depleted and rapidly if nearly full).   When the battery reaches 14.5V, the regulator reduces the voltage to the alternator, reducing output strength and preventing battery overcharge.  If the battery exceeds 14.7V, the regulator clamps the alternator field coil power to zero (0V), effective shutting off the alternator.
Because, there is electrical load from the system, an alternator that is not producing power allows the battery to deplete and the voltage falls.  The Vreg responds by turning the alternator back on in accordance with battery state/ charge level.
The Vreg state changes can be monitored/verified by observing the battery voltage state, and the White wire to the alternator field.  (Two meters are handy for this.)  The "trip" voltages can be adjusted with the adjust screw, while changing engine RPM and electrical load that the bike presents to the battery/charging system to "make" the battery reach the voltage levels need for the set trip points.  IE. with load reduced (lighting off) and the engine above 2500 RPM, a charged battery will attain 14.5 V.  Anything above that and the adjust screw needs to be backed out to keep the battery safe from harm.
The shop manual outlines bench set up mechanical adjustments that should be performed on unknown or tampered units.  These should be resolved before final trip point adjust tuning.
Note that while the system is working, the Vreg can change states rapidly before your very eyes., changing 5 times or more while you blink.  Therefore, you may have to mentally average values measured on the White wire if your selected meter doesn't do that for you.
Offline rsank
Re: Help a Newbie
« Reply #4 on: September 18, 2014, 05:28:45 PM »
TwoTired and everyone else, thanks for the replies. Sorry, the bike is a 1977 CB550F.
I have printed out your diagnostic procedure so I will tackle it step by step.
Yesterday, I rode it and stopped at one place where I used the starter and it fired up immediately, so if I had the kind of excessive drain I saw today, I wouldn't have been able to make it back. I also measured the battery voltage (with a voltmeter not ammeter) before purchasing the bike but if as you say there is no charging at 2000 rpm (and seems to be confirmed by the shop manual) then it is inconclusive. One other thing  I noticed, the headlamp does brighten up as I rev to higher rpm.
TwoTired, how much current should be drawn when you turn the ignition key to the on position (mine has headlight always on). I noticed a pretty significant drop in battery voltage which maybe is normal with the load but your comment about excessive drain got me thinking about it.
Everything is stock, still has points style ignition. I have not removed the tank to double check the coils but PO says the coils have not been replaced.
There are no electrical mods.
I am starting to think maybe excessive idling caused the battery to go bad.  According to PO, the battery is two weeks old.
I'll start by getting the battery out and charging it overnight. I'll clean all contacts and check wires for any grounds. Tomorrow I will go over the checklist and report back.
God bless you guys for this fantastic forum!!   :D
Offline rsank
Re: Help a Newbie
« Reply #5 on: September 18, 2014, 05:49:20 PM »
Sh*t! Just asked the P.O, he says the coils are Accel. From what I see, they are only available in 3 ohm. Now that explains a lot.
Re: Help a Newbie
« Reply #6 on: September 18, 2014, 06:03:43 PM »
If you wish to keep the coils, then Contact Hondaman for a 1-1.5 ohm resistor to insert into the supply power feed (Black/Wht).  (Stock coils are about 4.7-5 ohms)
That will get the current draw back to near stock.
The Stock Cb550 draws about 10 amps when the key is switched on. There is normally about a 6 amp deficit at idle RPM (drawn from the battery). (The manual has omitted the minus sign in the chart.)  The alternator can supply 12 amps when it is in its best operating range.  This assumes that the alternator field coil (Wht and green) actually receives full battery voltage, which it may not with oxidized interconnectors and old dirty/worn switches, such as the key switch.  The rectifier and regulator are not functionally degraded by being externally dirty.  You can't see that with the side covers on, anyway.  ;D
Offline rsank
Re: Help a Newbie
« Reply #7 on: September 18, 2014, 07:24:18 PM »
Thanks for that information TwoTired.
:D No I took the side covers off for sure. I am newbie but not that much of a newbie... lol
Actually the connectors to the regulator seem to be alright.  Don't know what the state of the ignition cylinder and switch are but oxidation is probably a safe assumption. That should be my next target after diagnostics.
I am so dumb, I was looking towards the back of the tank when in front were these two huge bright yellow objects (Accel coils).
So if the charging system is normal, without bringing the coils up to 5 ohm resistance either by the series resistor or outright replacement, my battery will always be in deficit? Which means the bike becomes unreliable except for short distance rides?
Offline rsank
Re: Help a Newbie
« Reply #8 on: September 18, 2014, 07:29:03 PM »
Thanks for this clarification. The manual says 6.5 A at 1000 rpm and that's what had me confused.
Offline bjbuchanan
Re: Help a Newbie
« Reply #9 on: September 18, 2014, 09:45:41 PM »
You will have to be careful to keep the bike revving more often, you won't be able to lug and idle a lot. Pm me if you want Hman's resistor pack, I have one sitting around
Offline rsank
Re: Help a Newbie
« Reply #10 on: September 18, 2014, 09:53:46 PM »
Got it. I was being a dumbass and was trying to run the carbs dry yesterday plus with trying to get used to the new bike, I have been riding around the neighborhood. Stop signs, traffic lights, short shifting etc.
I'll pm you. I suspect I'm gonna need it because I ride like a granny.
Re: Help a Newbie
« Reply #11 on: September 19, 2014, 10:30:09 AM »
A volt meter will tell you the voltage lost between battery and Vreg.  While in operation put one probe on the Battery POS and the other on the Black wire Vreg terminal.  The meter will report the voltage potential existent between the two probe tips, which in this case, is the voltage lost by components in the the electrical pathway.
You will need to find the "break point" RPM where the alternator matches the bike's electrical load.  Monitor the voltage while you increase the revs.  Below break point the battery voltage will trend lower, indicating it is in depletion mode. (Below say, 12.6V, which is battery full and rested voltage).   Above break point, the battery voltage will trend higher indicating the battery is accepting charge.  With an idle of minus 6 amps (or more) loss and a charge level of 1 amp, you will have to keep the RPMs higher than break point in a ratio of at least 6 to 1, in order to keep the battery from running down.  You could also add a voltmeter to the bike to monitor while you ride, then hold the throttle open.  While in city traffic I use my turn signal flash rate to tell me when to add more average RPM, as the flash rate gets slower as the battery depletes.  While driving, you can use lower gears to keep the engine RPM up and your actual speed down.  Engine racing does not mean you are actually racing.  But, the battery is less likely to deplete at higher RPM.  Assumption is that you don't have some sort of undiagnosed electrical failure on your particular bike.
By the way, you cannot run the carbs dry at idle, because of the way the carbs are designed.  To avoid picking up sediment in the tiny pilot/idle jets, they get fuel from higher in the carb bowl chamber than the much bigger main jet orifice.  So, at idle the engine will die with about 1/3 fuel still remaining in the carbs.
The carbs have a drain screw if you really wish the carbs to be stored dry.
Re: Help a Newbie
« Reply #12 on: September 19, 2014, 11:19:05 AM »
I make the Resistor Pack now in 1.0, 1.5, and 2.0 ohms. The latter is for this very situation! ;)
Offline rsank
Re: Help a Newbie
« Reply #13 on: September 19, 2014, 01:26:13 PM »
Alright did the first part of the test:
1. Charged battery overnight and let it rest a few hour in the morning. Voltage 13.04V.
2. My bike doesn't have lights off option except if I pull the fuse for headlight and tail. I ran it with lights on.
3. Ignition on (Headlamp, taillamp, running lights, cluster lights on), battery voltage drops to 11.85V.
4. Kick start:
     1000 rpm - 12.36V
     2000 rpm - 12.5V
     3000 rpm - 13.61V
     4000 rpm - 14.69V
     5000 rpm - 15.1V-15.5V
Keeping the rpms at 5000 for a short time, increases the voltage to 15.5V and even letting the revs drop, it takes until it's back under 2000 for the voltage to reduce. And then it gets into this high range cycle where even at 3000 it is going back up to 14.9V. Should I be giving it a few moments to stabilize at each rpm measurement?
Youtube video (doesn't show 1000 rpm but I did that after the camera fell off the mount): http://youtu.be/pGmQOMMuJVU
So according to the manual, the voltages should never be going above 14.5.  Regulator Vreg problem? Also my regulator doesn't have black wires, green and red wires. I guess the red and green are  the ones to check?
Offline rsank
Re: Help a Newbie
« Reply #14 on: September 19, 2014, 03:16:01 PM »
Part 2:
Finally found the regulator..  ;D
The voltage cross both the Green and Black wire were the same 12.95V and the battery now shows 12.97V. So,  0.2V difference.
I think this means I just need to open the regulator and turn that adjustment screw to lower its output a little and see if it brings the charging voltage down to a good range?
Re: Help a Newbie
« Reply #15 on: September 19, 2014, 03:31:40 PM »
Part 2:
(Arms flailing.)  Danger, Will Robinson, Danger!!
Did you do the test described in post #11?
1. Very unusual for a lead acid wet cell battery to read more than 12.8V fully charged and rested after two hours.  I suspect you either have a measurement error, or a non-standard battery.  Confirm.
2. Very few can set the Vreg as well as the factory.  Most mess it up and eventually buy a replacement that can't be adjusted.  It is NOT something to tweak willy nilly, and needs certain conditions to properly set.  (And particularly bad to do if your meter has measurement error.)  It is really a pisser to learn your test equipment was faulty AFTER doing diligent adjustments.  BTDT.
Offline rsank
Re: Help a Newbie
« Reply #16 on: September 19, 2014, 03:59:22 PM »
 ;D
Ok have to read post #11 again, I don't think I really got it. When you said in operation, did you mean with  engine running?
With engine off and ignition off, I only tested with the Battery POS and green wire to get 12.95V, Battery NEG and black wire. Thought that was what measured any voltage drops in the line.
The battery is a lead acid 12 V 12AH Yuasa. I don't know, maybe my multimeter has some huge error. It does measure 1.5V batteries fairly accurately. Or my battery maintainer is overcharging it? I had it in the bedroom and didn't notice any electrolyte boiling or bubbling in there...  ;D
Ok, not touching the regulator in that case. If my meter is in error, then we may have good values here. I think I am going to set my multimeter in current mode and stick the probes into the ac outlet. We'll know if it's accurate or not.  :P
Offline rsank
Re: Help a Newbie
« Reply #17 on: September 19, 2014, 04:05:14 PM »
I have a regulated power supply, I will test my meter against that. It has an analog voltmeter on the face, at least they should be close.
Offline rsank
Re: Help a Newbie
« Reply #18 on: September 19, 2014, 04:12:18 PM »
So,  the meter seems ok. Just tested against the bench power supply. Got to go look at the battery again. I am 100% sure it's not an AGM because it has little green tops on it and you can see water sloshing around. Weird!
Re: Help a Newbie
« Reply #19 on: September 19, 2014, 05:46:27 PM »
Engine doesn't have to run.  But, the key switch should be in the run position, and placing run loads on the battery.
No wonder you had a low difference reading.  Voltage drop is related to resistance and current.  With no current, resistive drops will be minimal, quite unlike when you drive about and the bike is pulling 10 amps through inline resistances.
Ohm's law  V=IxE.
You have to measure battery voltage 2 hours AFTER you remove it from the charger.  It's not storing electricity, it's converting chemicals inside.  The conversion is two way.  Consumes power to convert one way.  Delivers power for the other way.  The chemicals take a while to fully equalize after being agitated by electrical input stimulation.  It's also why it does a bit of self recovery when near depletion levels.
I hope you have spare fuses for the meter.  ;D
Invest in some lineman's gloves, too.  ;D
Offline rsank
Re: Help a Newbie
« Reply #20 on: September 19, 2014, 07:28:38 PM »
Thanks Guys. TwoTired, I really appreciate your help, I've seen other posts where you have said the same thing over and over to different people. To do what you do takes a lot of patience and desire to help.
Ok, so after dinner I will turn the ignition on and do the regulator test. I have been scared to turn on the ignition with all that battery drain.
Offline bjbuchanan
Re: Help a Newbie
« Reply #21 on: September 19, 2014, 08:27:47 PM »
His secret is copy and paste :P
The rested battery is very important, you gotta KNOW that battery is a good battery. 2 hrs later and 12.6v, that's the goal.
Keep at it, be methodical
Offline rsank
Help a Newbie
« Reply #22 on: September 19, 2014, 10:32:02 PM »
Ok, here are some new results, hopefully I followed the instructions correctly:
Battery POS Connection to Regulator black wire - 1.85V
Battery NEG Connection to Regulator green wire - 0.14V
All this with ignition on.
I did this check at 8pm, battery has been sitting on the bike since 1 pm and it read 12.9v so with the error margin of the DMM, this should be within range?
The battery is not Yuasa as I said earlier,  Interstate Conventional CycleTron 12N12A-4A-1.
« Last Edit: September 19, 2014, 10:49:21 PM by rsank »
Offline rsank
Re: Help a Newbie
« Reply #23 on: September 20, 2014, 12:50:42 AM »
I think this might be leading me back to the problem I had on the second day of ownership. The main fuse overheated and the bike died on me. I had to get a tow back home and then replaced fuses and cleaned the fuse clips. Although the fuse box did not melt, the fuse clip for the main fuse could still be damaged. Since the black regulator wire goes through the main fuse, I will repeat the Battery POS to Reg black wire and reseat/wiggle the main fuse and see what happens.
Re: Help a Newbie
« Reply #24 on: September 20, 2014, 01:36:35 AM »
Re:  Your latest test results.
Your battery has all cells working.  To know how well it works requires a load test.  However, if it cranks electric starter, it is still good to use.  Do note that as starting batteries deep cycle, they wear out faster and gradually lose cranking power for start up.
The reported numbers show that the Vreg is being lied to about battery status by about 2 volts.  Further, as the Vreg can only pass to the field coil what it receives (at best), the alternator can't ever make full power.  Using your numbers, I calculate about 17% less output than what is possible.  If I assume 10 amps through the black wire distribution, I can also calculate 0.2 ohms have been added by oxidize or worn contacts/connections or about 20 watts lost to heat through that resistance.
Given that the alternator should be capable of, at least, 150 W @ 5000 RPM and about 50 W at idle, it's now down 17% (25.5W loss) and wasting an additional 20W in the distribution channel means you have an effective power generation capability of about 5 watts @ idle and 105 W at 5000 RPM.  Note that the bike's normal load is about 110 Watts, so is it any wonder why the battery steadily drains?  (Also note that 3 ohm coils increase ignition power consumption by about 30-40%, which places addition load on that main fuse, bringing it closer to meltdown.)
Certainly check the fuse clips for bright shiny connections and fierce clip retention.  You should need a tool to extract the fuse.  Also look at the back of the fuse block to check solder connections.  Don't try to re-solder with the clips while still in the plastic, as the plastic will melt.  The clips are supposed to "float" in the block so they can self align with the installed fuse.  The alignment maximizes clip to fuse barrel contact area for a lower resistance contribution.
You can use the same voltmeter trick to isolate where the bulk of the resistance/ voltage loss is, by placing the probe tips on either side of any device/component in the power path.  I'll take a stab that your key switch is the main contributor.  But, that doesn't mean there aren't 10 connections that each have a .05 ohm resistance.  The switch can be overhauled.   And in most cases, the V loss can be greatly reduced.
