Author Topic: 78 GL1000 Conversion  (Read 567 times)
Offline sethmcalister
« on: September 27, 2014, 10:51:41 AM »
Hey guys,
Picked up most of a front end off a 78 GL1000 for a great price ($65)...came with wheel, calipers, forks, MC and one rotor. Did not have the speedo drive unit, triples and was missing one of the rotors.
I am curious if I can use my 750 steering stem and have a friend, or somebody on the forum make some triples?  I'm not setting any major barriers here, but am I forgetting something obvious?
I was going to convert to an acewell or something with a magnetic pickup I think so the speedo drive unit isn't essential, but I'm guessing I'll at least need a spacer, right?
Sent from my Nexus 5 using Tapatalk
Offline Old Scrambler
Re: 78 GL1000 Conversion
« Reply #1 on: September 27, 2014, 12:45:15 PM »
I'd look for a GL1000 triple unless you want a very custom look and are willing to PAY
Yes, to the spacer. The rotor should be available............sometimes on a bent rim.
When you take the forks apart to change the seals, be sure to note any wear in the tubes at the seal area.  If evident but not serious, you can rotate the tubes so the wear area is to the side for extended use.  Sometimes the great deal includes a set of tubes that are gouged from lack of fork-oil and worn seals.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline dusterdude
« Reply #2 on: September 27, 2014, 03:07:22 PM »
A 75-76 front end would be the hot ticket but good luck anywho
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #3 on: October 02, 2014, 12:22:39 PM »
I'm fine with the custom look and I had mentioned that I have a machinist friend which will cut down on the costs.  I can pick up a GL1000 triple cheap enough, but I don't like how high the risers are on the triples anyway.  As long as you think I can use the 750 steering stem and machine up some triples to fit then I may look into that.  If it's too cost prohibitive or work intensive I can just pick up the triples.
Thanks guys.
