Author Topic: Forking Motor Oil  (Read 14252 times)
Re: Forking Motor Oil
« Reply #75 on: December 12, 2014, 01:03:28 PM »
never overfill.
« Reply #76 on: December 12, 2014, 02:27:44 PM »
so you can infact use lower than the manual spec oil level?like I said not 50% less or such,and it doesent matter brand or road or dirt,show me where you must never ever use less than the spec level?most manuals say do not overfill!pretty feeble argument against never using less fork oil so far.
Dave,  yes you can use very small amounts less to get the manufacturers specs or to balance both fork legs,  as long as you know how much air is in the forks, you know the limits of the travel, you know how to measure sag , you are basically adept at modifying suspension, there is a very fine line between getting it right and getting it wrong, as your link clearly states, most people wouldn't have a clue as to how to do this properly, the fork oil level shouldn't be used to soften the suspension. Originally you said 20-30mm mate, that just under an inch to just over an inch and I wouldn't take that much oil out at all, the only reason i would take a small amount of oil out is to get the forks to the manufacturers specs or the specs of the suspension being used. I can't find one link online where it says this is acceptable to do on a road bike anywhere, the only information i read was all based around the manufacturers specs and making minute adjustments for racing, to make both forks perform the same, nothing for a street bike, other than to achieve the correct suspension travel, once the correct level is achieved, alterations to viscosity is the way to alter the feel..... I'm going to have to agree to disagree with you mate.... ;)
« Reply #77 on: December 12, 2014, 05:15:13 PM »
I said 20ml or ccs mick,relax!the spec is 160 I might have 140ml in mine,i cant believe this #$%* is still going on?
Offline goldarrow
  • one day, i'll be an
« Reply #78 on: December 12, 2014, 05:20:59 PM »
78 posts and still deciding on oil to use??? Wow
CB550 K0
« Reply #79 on: December 12, 2014, 05:29:41 PM »
ah but with a twist!how much,not what brand,lets make it official?only I dave500 can use less than the spec amount of oil in these forks forthwith?
« Reply #80 on: December 12, 2014, 05:40:33 PM »
80.
I use a little more oil when I make popcorn and then butter is not necessary.
« Reply #81 on: December 12, 2014, 06:27:23 PM »
lets all read reply #3 again?especially the line"dont over think it all"
Offline goldarrow
« Reply #82 on: December 12, 2014, 06:39:03 PM »
Here's forking oil for $3/qt. eye balling the level on the side of the bottle as you pour in the forks.  :)
CB550 K0
Offline gregripko
« Reply #83 on: December 12, 2014, 09:12:36 PM »
I just use measuring cup and that seems to work well..... I was cleaning out my tool box and found some Honda fork 10w oil.... Nice surprise
Offline Christo
« Reply #84 on: December 13, 2014, 03:08:33 AM »
If i put extra air in my tyres, will that make up for the less oil I put in?
74 CB550K
Offline gregripko
« Reply #85 on: December 13, 2014, 10:04:08 AM »
Speaking of tires..... How often do you guys have to pump them up on average? I feel like my pressure drops pretty quick.... Not immediately but not like my car
« Reply #86 on: December 13, 2014, 11:44:59 AM »
i pump my front tyre evry spring..the rear holds for 4 years now... ::)
« Reply #87 on: December 13, 2014, 11:58:56 AM »
im not going there,theres enough hot air in this thread already!
Offline flatlander
« Reply #88 on: December 13, 2014, 12:33:01 PM »
hot air? i fill my tyres with helium to counteract the effects of gravity on unsprung parts of the bike.
Offline gregripko
« Reply #89 on: December 13, 2014, 01:29:46 PM »
Thought this was kinda interesting... My clymers manual recommends 6.5oz of ATF for the CB550 in one section and then recommends 5.4oz of 10W-30 Oil in another section. It's as if they've compensated for the lighter weight of ATF by increasing the amount or its a mistake.
UPDATE: I guess different amounts are due to different fork type:
CB500 K0-2 : 5.4 (160cc)  Replacement  /  5.3~5.6 ozs.  (155~165cc) at disassembly
CB550 K0-2 (1974-76) : 5.4 ~ 5.6 ozs. (160~166cc)
CB550 F0-1 : 5.4 ~ 5.6 ozs. (160~166cc)
Cb550F2 and CB500/550 K3 (77) -  4.8-4.9 ozs. (145-150cc)
« Last Edit: December 13, 2014, 02:08:20 PM by gregripko »
« Reply #90 on: December 13, 2014, 02:11:04 PM »
80.
Oil this lot Steve... ;D ;)
Offline flatlander
« Reply #91 on: December 13, 2014, 02:18:19 PM »
the honda manual for the 500 and 550 recommends ATF.
for the 550:
p. 137 CB550K
Front fork oil capacity: 6.3-6.5 oz. 185-191cc
p. 157 CB550F
Fill the fork pipe with ATF up to the specified level mark.
Capacity: 165-170cc (5.6-5.8 oz.)
to fill dry fork assembly
same page:
oil change
… and fill the fork pipe with new ATF from the upper side up to the specified level mark.
what does this tell us?
  • the K versions take more oil than F
  • small variation in oil level is ok even by honda
  • honda and clymers manual recommend different amount - i'm not even gonna bother checking my haynes...
  • you need less oil when re-filling a fork after draining than after re-assembling a dry fork.
  • just check the hight of the air chamber before draining to have a reference, then refill to the desired hight with not too much less oil then recommended, and not so much that there's no more air.
all this is not religious dogma. if you find the ATF to light or heavy, just switch to a different weight oil and see how you get on. height of the air chamber can also be varied slightly.
« Reply #92 on: December 14, 2014, 03:25:51 AM »
or make a mix of atf ,and hydralik oil vith a heavyer number...if klean atf are to thin.
.easyer then bay 3 vrong types before hit the right type oil..
« Reply #93 on: December 14, 2014, 11:35:15 AM »
how about sewing machine oil?it has to be singer sewing machine oil though.
« Reply #94 on: December 14, 2014, 11:52:56 AM »
Just talking to another member here about this subject and came into something I hadn't mentioned yet, when we were setting up my mates race bikes front suspension, one thing he did was too mix viscosities to get more flexibility on fork adjustment, like mixing equal amounts of 5 weight and 10 weight to get roughly 7.5 weight, that is another option I would consider when adjust a front end as well as modifying the holes in the damper to alter damping rates, all this should be done by someone with a decent amount of experience with front suspensions. After that suspensions became far more adjustable with multiple damping  and preload settings.
« Reply #95 on: December 14, 2014, 11:56:30 AM »
Offline flatlander
« Reply #96 on: December 14, 2014, 11:58:15 AM »
ok i'll stick to olive oil. needs to be extra virgin, though.
« Reply #97 on: December 14, 2014, 12:08:19 PM »
i have i done for years..and vritten it all over this forum....
« Last Edit: December 14, 2014, 12:10:45 PM by strynboen »
« Reply #98 on: December 14, 2014, 12:15:14 PM »
Sorry mate, missed that one... ;)
« Reply #99 on: December 14, 2014, 12:42:59 PM »
no problem...like ve have the same fit for the problem ::)...my vifes suzuki gn..just got perfekt after it got a coktail od hyd and atf..it vas a hell driver before..no kontroll of the front..
it can made a bad bike better...never perfekt
my cbx can newer run klean atf..and overfill make it hard as stone..mix fluid are the only vay to get it rideabel...vitaut to fit air "nippels"
« Last Edit: December 14, 2014, 12:45:49 PM by strynboen »
