Author Topic: CB750 Crank Primary Teeth Worn - OK to Use?  (Read 3798 times)
Offline rickman750
« on: December 27, 2014, 09:53:30 PM »
My cases are split, and we're in to scoping out the state. We've found the teeth on the primary drive sprocket are worn.
And now to my question - Is it usable? Or am I in for a replacement.
http://www.glasson.org/Pictures/nic750/Crank_primary_teeth.jpg
Offline goldarrow
  • one day, i'll be an
Re: CB750 Crank Primary Teeth Worn - OK to Use?
« Reply #1 on: December 27, 2014, 10:04:37 PM »
I would replace
CB550 K0
« Reply #2 on: December 27, 2014, 10:10:10 PM »
Yes, I wouldn't use that at all...
Nic
« Reply #3 on: December 27, 2014, 10:35:11 PM »
Mick, you know where to get a good one in Oz? I'm doing the job.
« Reply #4 on: December 27, 2014, 11:01:07 PM »
A replacement crank..?  I'll ask around Nic, I know a guy that may just have one..... ;)
Nic
« Reply #5 on: December 27, 2014, 11:13:13 PM »
Appreciate it Mick, this engine needs everything, hadn't factored in a crank but when I found the primary chain tensioner was held in by about 3 threads and flapping around in there I wasn't surprised when I saw the state of the teeth. Someone has been in there, I found other loose bolts in the cam area as well.
« Reply #6 on: December 28, 2014, 12:29:28 AM »
I've made a couple of phone calls, no luck yet, i'll keep trying though... ;)
Nic
« Reply #7 on: December 28, 2014, 01:10:55 AM »
Thanks Mick, they have plenty in the states but $200 shipping ::)
« Reply #8 on: December 28, 2014, 01:59:18 AM »
Nic, you are in Sydney aren't you..?  Try giving these guys a ring, they do hot Honda engines and may just have a crank lying around...I'll keep looking... ;)
http://www.robinsontoolmakers.com.au/big_bore.htm
Nic
« Reply #9 on: December 28, 2014, 03:10:07 AM »
I'm closer to Canberra mate but I'll give em a ring, thanks, I'll let you know how I go.
Nic
« Reply #10 on: December 28, 2014, 05:54:01 PM »
Replacement crank acquired, thanks Mick for your help.
« Reply #11 on: December 28, 2014, 06:55:32 PM »
Excellent... ;)
« Reply #12 on: December 28, 2014, 07:07:01 PM »
GREAT!!  ;D
Offline 750cafe
« Reply #13 on: December 28, 2014, 07:54:01 PM »
WTG Retro!  :D
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Nic
« Reply #14 on: December 28, 2014, 08:21:36 PM »
Ah yes well, actually, the crank was got from, ebay in the states.
Offline 750cafe
« Reply #15 on: December 28, 2014, 08:23:50 PM »
He tried to help anyway.  ;) :-[
How much/little did you have to shell out for it with shipping?
Eric
Nic
« Reply #16 on: December 28, 2014, 08:42:17 PM »
Eric
Too much.
Offline rickman750
« Reply #17 on: December 28, 2014, 11:55:58 PM »
Eric
Too much.
Seventy bucks........US........Plus shipping.
Now I'm worried about the big primary sprocket on the tranny input shaft......
Nic
« Reply #18 on: December 29, 2014, 12:26:43 AM »
Eric
Too much.
Worry not, I have inspected.
