Hello, I am starting to rewire my 400f due to the old wiring and connectors starting to fall apart. I decided to use a Motogadget M-Unit to control everything in order to decrease the complexity of the wiring. I drew up a wiring diagram and realized I still have a few questions I need to figure out before I start building the harness. Most of the questions I have are not related to the m-unit specifically though.
1. I figured that the neutral switch should be part of the starter relay circuit to keep from trying to start the engine while in gear, but it looks like it wasn’t originally. Should I add it to the starter relay circuit?
2. Are indicator lights (neutral/high beam/oil light) supposed to be added in series with a given circuit or in parallel?
3. When connecting the red power wire from the R/R (Ricks combined R/R) to the battery/main power, I am a little confused as to where it is supposed to connect. Should it go directly to the battery + terminal, before the fuse, to the battery cable before the fuse, the battery cable after the fuse, or to the + terminal on the M-Unit?
4. Does anything in my wiring diagram look incredibly wrong or stupid? I did take a circuits class once but I almost failed it so I am no expert.
Green lines represent grounds, blue represent small control wires (22 gauge probably) and other colors are power wires (16-18 gauge)
Thanks for any help!
