Author Topic: Replaced handlebars lost spark Help???  (Read 5732 times)
Offline 2strokeTrush
  • Can you get that back together sonny?
« on: March 28, 2015, 06:23:47 AM »
So my side project 74 550 with a good 77 550 engine, came with 2 foot ape hangers on it. Obviously I had to change them out. So I put some lower bars on, wired up and all, but now I have no spark! All switches are working.  Bike didn't come with the clutch start wired kill switch thing so could this be a issue?  I have read you can bypass this, but unsure of how to.  Any help would be great! thanks;)
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
DH
Re: Replaced handlebars lost spark Help???
« Reply #1 on: March 28, 2015, 07:17:33 AM »
clutch start feature will inhibit starter circuit and cause no crank condition. check your kill switch circuit. it delivers power to the ignition coils. Black/white wire at coils should become live with kill switch in run position. If no power there, back track the circuit
and find out where the power is being interrupted. Look for loose or disconnected connectors. Are the points wires connected
Blu and yellow at the main harness, (vicinity of the rear brake lite switch)?
« Reply #2 on: March 28, 2015, 02:53:57 PM »
Thanks man I'll give it a go!
« Reply #3 on: March 30, 2015, 06:52:48 AM »
So upon further inspection i remembered i never checked the turn signals, these are not working now. IS it possible I have those wires mixed up with something that could inhibit the spark? Im going to investigate it right now
« Reply #4 on: March 30, 2015, 08:42:16 PM »
Thanks for the help it was indeed a bad ground. Unfortunately I like a idiot used starter fluid and the bike backfired while trying to start, igniting the carbs and melting the gas tank. Luckily no one was hurt ( except my pride ). The bike itself is alright the carbs burned but I believe are rebuildable. The wiring harness has melted and the original very beautiful pant burned off the tank. Not a good night but thanks again for the help
« Reply #5 on: March 31, 2015, 06:07:07 AM »
:-\ (slaps forehead and droops while shaking his head)
Tyler, a quick tidbit for you- when you diagnose a problem, remember that "more of the same won't change your luck". If you have a "no spark" issue, abandon fuel accelerants. These are strictly for fuel problems! I personally don't like starting fluid at all for this very reason. Very difficult to tell how much is too much, and with the induction filters off, a nice plume of flame likes to come back out the way it went in....
Delighted you aren't hurt, and if there's a way I can help on the paint, drop me a line.
Thanks Cal. Been pretty upset since it happened and now I am guessing I'll have to repaint the tank. Something I have never done. Any good threads you know of? I have a nice paint gun and a good air compressor so it's not impossible for me to do it. Just new to me
« Reply #6 on: March 31, 2015, 06:19:38 AM »
... igniting the carbs and melting the gas tank.
Holy #$%*e! Melted the gas tank, WTF?
DH
« Reply #7 on: March 31, 2015, 06:27:23 AM »
Man, I hate to hear that. Glad there was no worse damage, to you or your house/shop. Sorry about the bike. Hoping you can bring it back.
« Reply #8 on: March 31, 2015, 06:37:51 AM »
Melted the cap, petcock, chrome strip and petcock
« Reply #9 on: March 31, 2015, 06:38:02 AM »
Melted the cap, paint, chrome strip and petcock
« Reply #10 on: March 31, 2015, 06:38:53 AM »
Double edit post my bad
Offline wjustinleigh
« Reply #11 on: March 31, 2015, 09:10:31 AM »
I had stripped a tank and after painting it was surprised how 'wrinkly' it was, looks like there was significant amounts of filler direct from the factory.  I did this to two tanks ('71 and '72 cb500) and saw it on both tanks.  The first one I didn't really notice and painted it from the bare metal and was disappointed with the final.  Next one I had an awesome body guy straighten first, looked way better.  Still annoyed when I look at the first one and see the subtle waves in the tank.
Sorry about your bike, glad to hear it's rebuildable.
71 cb500
72 cb500
07 Bandit 1250
« Reply #12 on: March 31, 2015, 02:18:21 PM »
I may be using the wrong term as it may not have been filler but there was a substance that wasn't just primer that was used to fill in the slight waves in the tank for the original paint job.  They were definitely original paint - in one case rattle can over original.  I have pics somewhere, I'll post them.
The guy who worked out the waves was really good, does show hot rods as a profession, beautiful stuff.  Here's he tank after he got done with it - http://forums.sohc4.net/index.php?action=dlattach;topic=110879.0;attach=282912;image.  Had a big dent where the flash reflection is that he worked out of it with a metal hammer.  The other I had powder coated on the bare metal - which looked good as metal - but once powder coated you can see the imperfections.  Just saying if I was to do it again from metal like the OP I'd spend more time getting the surface right first.
71 cb500
72 cb500
07 Bandit 1250
« Reply #13 on: April 01, 2015, 07:55:23 AM »
OUCH  :o !  WOW
Tyler,you must be glad the tank didn't Blow;did you have a fire extinguisher ?
« Last Edit: April 01, 2015, 08:00:44 AM by grcamna2 »
« Reply #14 on: April 04, 2015, 11:24:31 AM »
Here's the spare from my bins
I don't think it will work:( thanks tho!
« Reply #15 on: April 04, 2015, 11:25:01 AM »
OUCH  :o !  WOW
I did but it wasn't close enough!
« Reply #16 on: April 04, 2015, 04:10:15 PM »
You had a few angels around w/ you that day  ;)
« Reply #17 on: April 04, 2015, 09:27:14 PM »
Considering my shop is in the basement of a church parsonage thats quite likely  ;D
« Reply #18 on: April 05, 2015, 05:09:52 AM »
Happy Easter Tyler
« Reply #19 on: April 05, 2015, 04:20:07 PM »
Happy Easter! Thanks for the help!
« Reply #20 on: May 28, 2015, 09:48:00 PM »
So I know this is a old thread and I thank everyone for the help, but rather then start another thread can I ask another question here???
I changed out to a new wiring harness and ignition switch ( 1977 to match the motor ) and replaced all the fuses in the electric panel, cleaned the area and grounded the harness by the coils, but cannot get any indicator lights to function, no power to any of the switches, nothing.   Expect when I go direct across the starter solenoid I turn the starter over.   When I rewired everything in the headlight is it possible something is that incorrect to screw everything up like that? Any idea would be great! thanks!
« Reply #21 on: May 29, 2015, 06:25:54 AM »
Id start with the key switch, since it brings power to the fuses. Voltage at battery, voltage at both sides of main fuse, then coming out of the key switch? Check in these places first. Then work you way from the key switch to the next connector.
Thanks as always cal. What do you mean by " comming out of the key switch? Just the connections?
« Reply #22 on: May 29, 2015, 11:51:18 AM »
Power starts at the battery, travels across RED thru the Main fuse. RED wire runs to key switch, then splits across Black, Brown, and Br/Wht. If RED isn't getting or distributing 12v thru the key, it's not going anywhere in the bike.
Check the fuse block on both sides. Then on backside of key switch, place your probes on the solder points of the Blk, Br, Br/Wht with Key ON to verify voltage (if you unplug the connection, you won't get current to RED). Make sense?
Yes thanks! No power to key, no power to fuse panel either. Only place I can get anything to register is on the starter solenoid hot comming off the battery
« Reply #23 on: May 29, 2015, 01:20:44 PM »
Here's the solenoid is this the correct wiring to it? I feel like it's not correct. I have 3 leads comming into the solenoid. One black to the starter motor and then one from the battery and one that goes somewhere else behind the panel. Is it supposed to be just two leads connected to the solenoid?
« Reply #24 on: May 29, 2015, 01:52:21 PM »
Then yes something is wrong, because I have 5 wires leading to the solenoid. 1 large gauge to battery positive, 1 large gauge to start motor, 2 small wires with bullet connectors and one more large wire gauge with a red tape on it. Where does this one go? Take a look at this picture
« Last Edit: May 29, 2015, 01:54:11 PM by 2strokeTrush »
