Author Topic: 466 project turned in to a 3+ year gig. now redoing the transmission.  (Read 18220 times)
Offline Jore
Re: 466 project turned in to a 3+ year gig. now redoing the transmission.
« Reply #125 on: April 13, 2016, 08:33:34 PM »
Seems that most of my picture links are dead, I'll change those later on, In the mean time it's good to be back, I finally closed up the case and installed the transmission, now it's just a matter of setting up the linkage correctly so I can try going through the gears. What do you guys recommend when doing that, if the transmission works out correctly I'll install the top part and later on do a bench test run.
This is my progress so far:
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
Offline Jore
Re: 466 project turned in to a 3+ year gig. Engine in frame!
« Reply #126 on: June 05, 2016, 09:23:02 PM »
I had a really good weekend, first I made some rough looking but functional paddock stands and between saturday and sunday I got the engine mounted in the frame, I'm so happy after 3 years not working, and 2 with the engine in pieces it starting to look like a bike again!
-I need a to redo the wiring and get a headlight for it, there's a place locally that sells some 5 inch round LED headlights with high and low beam settings, I'm thinking of getting one of those since they draw about 30w on high a bit less on low beam.
-The bike doesn't have any brakes for the moment, the rear has new brake pads, but I got to reinstall the linkage and lever. The front hydraulic lines are are garbage, so I need to redo those, I also have new front brake pads.
-The carbs are in pieces.
-The clutch is out, but I have new fiber discs and HD springs.
-Need to reinstall the airbox.
-Fix the front fender since it's all dinged up and find a solution for the rear.
And that's about as much as I have left before a working bike.
1975 CB400F owner
« Reply #127 on: June 06, 2016, 02:46:52 AM »
my fuel tap is leaking..and karbs dont hold the fuel line..one is overfloting and one is  mostly dry..
but you are on the right vay....to the road..
Offline Jore
« Reply #128 on: June 06, 2016, 09:57:05 PM »
Thanks strynboen, it's missing some things but yes, it's getting there.
1975 CB400F owner
